Visit Lohen!
Old Dec 13th, 2005, 11:21 AM   #1
roland2003
MINI 2 Sponsor GT Tuning
Local Time: 09:21 PM
Jcw SC pulley, only -11%!!!
Hi Guys, an interesting one this,we have a jcw car for some work, the SC pulley appeared bigger than normal so we decided to measure it up accuratly. Measured at the top of the V groove form, stock pulleys measure 65.4mm diameter, this JCW one measures 58.1mm diameter. Thats a decrease in diameter over stock of just over -11%. No wonder the car is so slow . They are normally typically -14.5%
Regards Roland . GT Tuning
Old Dec 13th, 2005, 11:23 AM   #2 (permalink)
C11 XFF
Its a Mini Adventure....
C11 XFF's Avatar
Local Time: 10:21 PM
Interesting, what year is the car ?
United Kingdom Male View C11 XFF's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 13th, 2005, 11:24 AM   #3 (permalink)
TallAndy
Taller Than You!
Send a message via ICQ to TallAndy Send a message via MSN to TallAndy Send a message via Yahoo to TallAndy Send a message via Skype™ to TallAndy
That is interesting. I have a Works 210 (05 coopers) I've raced *ahem* a little with Mr Colink with his GTT 220 and theres hardly anything init very closely matched.
If you use a 15% reduction pully and the JCW is only 11% how do JCW claim 210 surely air filter / spark plugs and that new cylinder head dont do that much, the exhuast is only cat back so i wont do that much?
England Male View TallAndy's Chili Red & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Dec 13th, 2005, 12:12 PM   #4 (permalink)
roland2003
Normally jcw is -15% and quoted at 210bhp. This one has -11% pulley and feels alot less than 210bhp. Not for long though JCW210 conversions (-15% pulley ) on the rollers on the same day as a GTT210 produce almost identical power.
Regards Roland Gt Tuning
Old Dec 13th, 2005, 12:21 PM   #5 (permalink)
TallAndy
Taller Than You!
Ok so JCW pullys are normally 15% that would make sense.
Is that one your working on the old JCW 197 BHP?
Old Dec 13th, 2005, 12:24 PM   #6 (permalink)
roland2003
No its a March '05 car with JCW210 .
Old Dec 13th, 2005, 12:36 PM   #7 (permalink)
TallAndy
Taller Than You!
I seem to remember a thread somewhere that found that all JCW pullys where about a 12% reduction.
Old Dec 13th, 2005, 12:39 PM   #8 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Local Time: 07:21 AM
Send a message via MSN to St00ge
i've heard almost consistently that the JCW has a 14.3% reduction pulley
Old Dec 13th, 2005, 12:54 PM   #9 (permalink)
TallAndy
Taller Than You!
So an 05 JCW has 11% smaller pully, maybe thats a mistake but I cant see how they could get the pully wrong standard part etc. SO surely that must mean that all Works cars have an 11% smaller pully.
This brings me back to my previous point, how can my car easily keep up with a 220BHP one with a 15% smaller pully
Old Dec 13th, 2005, 01:14 PM   #10 (permalink)
St00ge
St00ge's Avatar
you have a car that has more mods than a GTT220. You have a better head, exhaust, injectors, induction kit
Old Dec 13th, 2005, 04:02 PM   #11 (permalink)
Andy@Ross-Tech.com
Andy@Ross-Tech.com's Avatar
Local Time: 05:21 PM
Send a message via AIM to Andy@Ross-Tech.com
That's pretty odd. Every JCW pulley I've seen has been 56.1 mm. Maybe Eaton slapped the wrong one on there.
BTW, here's an interesting little snippet from the Bosch Automotive Handbook about pulleys. For a standard 6-rib DIN 7687, the effective diameter is the diameter of the pulley peaks plus 3.2 mm (0.126" for you sliderule types ). This of course applies to both the drive and the driven pulleys.
So, stock:
(5.460+0.126)/(2.58+0.126)=
5.586/2.706 = 2.06
This matches up nicely with the MINI tech documents.
Using my calculations, the percentage increase in blower speed for each pulley over stock is:
stock: 0% (duh!)
jcw: 15.8%
p&d "15%": 16.8%
p&d "17%": 19.4%
p&d "19%": 23.2%
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Dec 13th, 2005, 04:16 PM   #12 (permalink)
twouptons
What's this button do?
twouptons's Avatar
Local Time: 04:21 PM
stock: 0% (duh!)
jcw: 15.8%
p&d "15%": 16.8%
p&d "17%": 19.4%
p&d "19%": 23.2%
So I wonder when the efficiency of the blower starts to drop because of excessive speed...
At some point, the blower will blow less with an increase in speed, which would lead to a drop in top-end power.
Has anyone done a set of flow rate measurements to correspond with the different pulley sizes?
-Eric
United States View twouptons's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 13th, 2005, 04:31 PM   #13 (permalink)
Andy@Ross-Tech.com
Running the supercharger faster than stock has two undesireable side effects. First, the air is heated to a greater degree so the engine is more prone to detonation. Second, drive power of the supercharger goes up so less horsepower makes it from the crankshaft to the wheels. Here are some graphs of a stock Eaton MP45 blower (not exactly the same as ours but similar):
-Eric
Old Dec 13th, 2005, 05:24 PM   #14 (permalink)
roland2003
The pulley (now removed ), has the ID 315 0 58 XL stamped on it. Could be the last 2 digits refer to the diameter ie 58mm? The XL for extra large (ha ha) ?
Old Dec 13th, 2005, 05:48 PM   #15 (permalink)
TallAndy
Taller Than You!
LOL
What size is the stock pully (diameter is mm?)
Old Dec 13th, 2005, 05:52 PM   #16 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 01:21 PM
Online
2.58in = 65.5mm
Old Dec 13th, 2005, 05:55 PM   #17 (permalink)
TallAndy
Taller Than You!
Interesting do we know what the ID is of a stock pully? Maybe its
ID 315 0 65 XL?
Old Dec 13th, 2005, 06:28 PM   #18 (permalink)
Tonyt3
Track addict
Tonyt3's Avatar
Thing is Roland, if the guy with the JCW 210 is getting his car re-tuned with you to a decent level, really speaking, you should first send the guy back to JCW so that the error can be seen, and that he can either get his money back or get it fixed proper.
I'd be fecking insenced if this occured with mine. Think I'll just go measure my pulley just in case.....
Can you measure it whilst still attached to the car... suppose not...
Old Dec 13th, 2005, 08:30 PM   #19 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Very interesting thread. Dont suppose JCW has reduced the crank size instead a bit??
Right answers please to this one, i've always wanted to know whats best and causes most usable HP. Either 19% reduction pulley or 17% pulley with 2% crank pulley??
Now theory has it that a bigger pulley means less force to turn the SC so getting 19% smaller will make the SC much harder to turn and put alot more load on the belt. But changing the size of the crank pulley will cause more work to drive everything else aswell as the SC. And personal experience anyone can add to work out what is the best way to do it??
Old Dec 14th, 2005, 10:11 AM   #20 (permalink)
roland2003
Tony Not only the pulley size error but 2 days at dealer with small running fault only to be told 'upstream sensor faulty ,we havnt got one, so weve just cleared the code' .Fault still there, we get the car in and find its not the sensor (which is correctly telling the ecu 'low input from upstream map sensor') it turns out its the small pipe that operates the JCW airbox flap is not connected so flap not working and its drawing in unfiltered air from the wrong side of the throttle body! Time taken to diagnose & fix at GTT; 30 minutes- no parts needed. On top of that one of the bolts that holds the rocker shaft had its hexagon head almost completly rounded off from when the JCW head was fitted. Thats 3 faults from one JCW conversion.
Would you want it to go back again? Maybe yes maybe no.
ps To all you JCW fans , please dont grill me , Im merely pointing out what we have found on one car. You can make your own minds up if at £3500 its ok.
No ones perfect even we make mistakes, but hopefully less of them !
Regards Roland GTT
JCW Pulley is actually a 13.43% Reduction Itzamazn Engine & Drivetrain Tuning 20 Jun 29th, 2005 08:23 PM
Pulley/JCW Flying Dutchman Engine & Drivetrain Tuning 5 Mar 3rd, 2005 10:16 PM
