Mini Pirate
Old Jan 5th, 2006, 02:32 PM   #1
Luverly Lesley
Bog Roll Specialist
Luverly Lesley's Avatar
Local Time: 09:20 PM
Send a message via MSN to Luverly Lesley
do resistor chips work?
i just spotted a resistor chip on ebay which promises up to an extra 20 bhp! has anyone tried these and do they work?
Northern Ireland Female View Luverly Lesley's Solar Red & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jan 5th, 2006, 02:53 PM   #2 (permalink)
Luverly Lesley
Bog Roll Specialist
my friend got one for his nova, but hasn't got it in yet! might see how that goes when he finally gets round to it!
Old Jan 5th, 2006, 03:16 PM   #3 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
From my understanding they work by fooling a sensor attached to the ECU thus into pushing more fuel through to burn, creating bigger burn and more power. The problem is the "fooling" bit...Don't touch anything that fools the computer into doing something. The ECU has set perameters for fueling for a reason, fuel increase should be accompanied by either colder air or more air through forced induction not just by fooling a sensor into telling the ECU that there is more of one or the other...thats just plain dangerous as the fuel/air mix is wrong and will jsut do damage in one way or anouther...my advice is steer well clear. Do the job right...you want 15-20 bhp more go for an induction kit full exhaust system+remap...
If it sounds too good to be true then it usually is
R
Old Jan 5th, 2006, 03:24 PM   #4 (permalink)
Cooper_si
the DASH LIGHT king ? ;)
Cooper_si's Avatar
Send a message via MSN to Cooper_si
I dont trust these resistors at all !! Richard makes some very good points too.
We always treat each MINI as in individual, as no two MINIs are alike !
THE Legend who helps ALL MINI owners
Old Jan 9th, 2006, 08:49 AM   #5 (permalink)
Beezerk
Beezerk's Avatar
Local Time: 10:20 PM
Don't the resistors simply bypass the temp sensor, so the ECU thinks the engine is cooler/warmer that it actually is? Sounds good in theory, but what if your engine is over heating, you'll be knacked!
Power Resistor of Justice! TallAndy Engine & Drivetrain Tuning 13 Jan 30th, 2006 08:21 PM
Stone chips from JCB on the way to work Bonjour General Discussion 6 Jan 27th, 2004 11:12 PM
Airbag resistor value: 3.9 Ohms ? For sure ? GDeschodt Interior & Ice 2 Nov 24th, 2003 01:52 AM
