Visit Derek Woodman MINI
Old Jan 13th, 2006, 12:26 PM   #21
RedUn
MUGEN POWER
RedUn's Avatar
Local Time: 10:23 PM
Looking forward to the alta results roland
Japan Male   Reply With Quote
Old Jan 13th, 2006, 11:44 PM   #22 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Local Time: 09:23 PM
Old Jan 14th, 2006, 11:48 PM   #23 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Local Time: 07:23 AM
Send a message via MSN to St00ge
haha me too, i have an Alta CAI....anyone wanna swap me for a GTT CRI?
Old Jan 16th, 2006, 05:56 AM   #24 (permalink)
St00ge
St00ge's Avatar
Quote: Originally Posted by Jaffa Racer
Good work Roland, now I know why with just the GTT CAI it feels like she goes better.. because she does. Really 10 BHP per psi
i dunno about 10bhp per psi......
if i put a 17% pulley on my car, and run 17psi of boost consequently, does that mean i'll have over 50bhp extra? i doubt it....even with my CAI and MTH tuner.
Old Jan 16th, 2006, 09:01 AM   #25 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi Etalj,No what we are saying is on a high boost car (which will be demanding alot of air ) one psi extra ENTERING the SC can give UPTO 10bhp more at around 7000rpm compared to stock filter system.. You wont get the same on a stock car, nor will you get the same by going one psi more by 'going a bit smaller on the SC pulley', and unfortunately you dont get 10 bhp 'per psi'. (now that would be nice) Its all to do with improving volumetric efficiency .
Regards Roland GTT.
Our early tests gave 9bhp improvement on the rollers compared to our GTT 210 kit. As you know RR measurements are a little bit 'variable' even with the best will/operator/equipment in the world. A pressure and vacuum guages act as a' mobile real life conditions' flow bench. In other words a very valuable measuring & tuning device.
Best Regards Roland GT Tuning
Old Mar 3rd, 2006, 11:21 AM   #26 (permalink)
roland2003
Hi Guys, still looking for an MCS with Alta air filter on it to complete the comparisons.
Needs to be fitted with -17% pulley as used on GTT conversions , (or say a -14% JCW with a +3% GTT crank pulley)
Hooking everything up & testing will take under an hour. You can even sit in the car during the test if you like and see the vacuum guage (make sure we are not cheating too )
-£20 GTT voucher thankyou reward included!
Regards Roland GTT
Old Mar 3rd, 2006, 12:33 PM   #27 (permalink)
Haggi
forwards and downwards
a question for rowland regarding cooper air box mods ?
as im sure you are aware the cooper air box inlet has 2 resinator chambers on the pipe i know mini mania have already done a new air box but do not sell the pipe seperatley im considering a few mods to the stock air box (10mm hole in the bottom of the box and k&n high flow filter) what would you say the merits of these were over a 57i induction kit which is my other option
confusion, madness and disorder .............. my work here is done
Azores   Reply With Quote
Old Mar 3rd, 2006, 01:16 PM   #28 (permalink)
roland2003
Hi JWF. Thanks for the enquiry TBH I havnt spent enough time on 'non S' air filter configurations to advise specifically
. K&N elements are good quality, often 57i kits are alot more £ for an 'extra bit' you could do yourself (eg Renault 5GT kit). Holes that draw in hot air from the engine are generally not a good idea. You need cold air and lots of it.
Regards Roland GTT
Old Mar 3rd, 2006, 01:24 PM   #29 (permalink)
Haggi
Regards Roland GTT
thanks i know it sounds odd but theres a theroy among us cooper owners that the air benth the box is cool due to its location the hot air comes from the side and a small hole aids the iduction as well as being and emergency drain im going to run a few experiments next week
also one futher question how often should the filter elements be repaced
Old Mar 3rd, 2006, 01:39 PM   #30 (permalink)
roland2003
You can replicate the tests we are doing on the MCS's to see if you realy are removing any restriction. You need an accurate vacuum guage ,connected after the airfilter&before the TB. Use WOT in say third gear then take the reading at say 6000rpm. Then compare to stock. This realy is the best way to best in effect 'a real life actual conditions flow bench'
Even the effects of air entering the grilles and scuttle area are 'real life' .
Regards Roland GTT
Old Mar 3rd, 2006, 03:17 PM   #31 (permalink)
Haggi
Regards Roland GTT
Ive got a mate who dose motorsport engineering where I'm at uni so will see what gizmo's he has i think he will have all the necessary as he can use it as part of his research as well and will post the results back here
Old Mar 3rd, 2006, 09:28 PM   #32 (permalink)
MINI-Morgan
MINI Obsessed...
The holes in the bottom is a mod back from the old Nova days. Its considered that the air in the lower engine bay is cooler due to hot air rising and there isnt usually anything hot underneath it. Its worthwhile if you go through many fords though as a drainage hole.
Old Mar 3rd, 2006, 09:50 PM   #33 (permalink)
wibbly
In my Classic Mk 1 :)
wibbly's Avatar
Quote: Originally Posted by Mini-Morgan
Wish I knew how they all compared to the Promini kit I useto run.
I kinda miss my Promini
In some ways I think its better than my 10hp upgrade that I paid £450 quid for
| MINIaddiction | | For MIDLANDS Folk in their MINI's |
England Male View wibbly's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 3rd, 2006, 09:53 PM   #34 (permalink)
MINI-Morgan
MINI Obsessed...
What did you go for?? I put the promini one half way through a mini run.... then booted it out on to the dual carriageway and it made soooo much difference.
And that sound mmmm
Old Mar 3rd, 2006, 10:11 PM   #35 (permalink)
wibbly
wibbly's Avatar
And that sound mmmm
Works upgrade....
I swear I got back in the car after the upgrade and thought nice sound when the second flap opens but what extra power and looked over at the BMP sat in the passenger footwell where it had been dumped when they took it off
Old Mar 3rd, 2006, 10:59 PM   #36 (permalink)
MINI-Morgan
MINI Obsessed...
Works upgrade....
I dont think there's too much in it really.
Old Mar 21st, 2006, 09:48 PM   #37 (permalink)
MickCooperS
Hey Roland, What gain can i expect on a stock Cooper S with the GTT CAI ?
Old Mar 22nd, 2006, 09:41 AM   #38 (permalink)
St00ge
St00ge's Avatar
aha, i misread, my bad Thanks for that Roland...
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old Jun 1st, 2006, 01:57 AM   #39 (permalink)
dmh
Local Time: 05:23 PM
Roland-
How come your box does not have a top? I track my car and am concerned with the sealing capabilities since the engine does sway quite a bit.
Thank you,
Don
Old Jun 1st, 2006, 11:28 AM   #40 (permalink)
Jaffa Racer
Jaffa Racer's Avatar
Send a message via MSN to Jaffa Racer
the GTT CAI seals against the bonnet
HTH
Kev...
JCW SK Filter v JCW Cone Open Air Filter Peanuts Engine & Drivetrain Tuning 15 Mar 23rd, 2008 02:04 PM
New GTT/JCW Hybrid Air Filter Upgrade !+pics roland2003 GT Tuning 63 Jul 4th, 2007 01:46 PM
Cleaning GTT air filter jkjn Engine & Drivetrain Tuning 1 Apr 29th, 2007 03:39 PM
stock air filter, oily? HOINSEY_BOINSEY_28 Engine & Drivetrain Tuning 1 Apr 23rd, 2007 12:58 PM
JCW Owners: Do they use the stock air filter element? Mexibeetle Engine & Drivetrain Tuning 1 May 18th, 2003 07:47 PM
