| MINI2 Newbie Join Date: Dec 2005 Location: my house ;o) Local Time: 09:44 PM
Offline | 15% Pulley with Standard Map Any1 running a 15% pulley with the standard ECU map? installing the pulley at the wkend, so wondering how much difference in makes to the cars performance and also about engine wear issues, as i've been told it makes cause problems cheers rob |
| MINI2 Senior Join Date: Jul 2003 Location: Nottinghamshire Local Time: 10:44 PM
Offline | As I understand it no problem using the std map..... however benefits to be had with a correct map. You also want to now change your spark plugs to be one heat range colder see this link.... http://www.mini2.com/forum/engine-drivetrain-tuning/93816-ngk-spark-plugs-information.html Cheers Perm |
| MINI2 Regular Join Date: Apr 2005 Location: Melbourne Local Time: 07:44 AM
Offline | I have been running 17% with standard ECU sw and it ran fine with much more power and torque. Only changed because I bought the upgrade kit which gave me JCW intake and injectors and JCW software. |
| | #10 (permalink) |
Offline | yep, to about 2 1/2 hrs. not a problem would advise any1 to have a go. Don't think you need the special tools that you see . a good pinchbar to take tension off the belt. then a bearing puller (not sure if these are cheaper than the purpose tools advertised) to remove the pulley. I bought a tool but think i was not needed JOBS A GOODUN ![]() |
| | #14 (permalink) |
| MINI2 Newbie Join Date: Dec 2004 Location: Bangkok Local Time: 04:44 AM
Offline | I have been running with Alta 15% pulley more than 6 months, together with Alta CAI, Alta exhaust, Ignition upgrade, no problem so far.. However; recently I got my JCW injections (Great improvement) and I spoken to my local MINI tuning house, they can upgrade the ECU with Superchips new firmware to suit my modification.. Try local tuning house for Superchip upgrade! Plys |
| When is the standard pulley belt replaced? | Parc77 | MINI Cooper S | 5 | Apr 24th, 2007 05:31 PM |
| just got pulley and new map,attached dyno graphs | claudeG | Engine & Drivetrain Tuning | 7 | Sep 8th, 2006 10:16 AM |
| Pulley upgrade without re-map... Worth doing??? | jonnyc | Engine & Drivetrain Tuning | 5 | Sep 16th, 2005 10:59 AM |
| MCS pulley/re-map | cordial | Engine & Drivetrain Tuning | 4 | Aug 12th, 2003 08:41 AM |
| How many have a smaller pulley & no ECU re-map? | TonyB | Engine & Drivetrain Tuning | 22 | Apr 26th, 2003 12:57 AM |
