| Still glowing in the Dark | OBX Header Should it glow red ? Hi I have just finished putting on a OBX header with a short flex connection mated with the standard cat . I have just taken it out for a fast run and thought I would take a look under the bonnet on the way back.To my surprise when I looked at the header it was glowing a nice cherry red colour. Is this normal because when I had the standard header I never took any notice and never looked ! It soon cooled down and looks OK. Anyone any comments ,do they all do it ? Regards Tony |
| On a Hellride Join Date: Jan 2006 Location: Amber Local Time: 04:31 PM
Offline | Quite common on performance cars driven hard. Take a look at this. http://trolltuner.com/viggen/Video/GenuineHot.wmv That was with a cast iron manifold which takes a lot more heat to cause it to glow. The glowing is generaly not an issue with quality manifiolds/headers since they are manufactured with high temp stainless steel. |
| New Mini Specialists | Turbo cars often tend to glow under full throttle. If you are worried about it then just check the engine bays regualrly to make sure that nothing has suffered from heat. If any problem develops wrap it in exhaust wrap it will protect the stuff around it. Andrey |
| | #7 (permalink) |
| Still glowing in the Dark | Hi asinn Did you find it easy to fit the heat shield back on ? I had to bend the sides out and straighten the top , it fits but only 3-5 mm clearence in places from the pipes.It has changed the exhaust note to a deeper tone not sure yet wether any performance gains . What kind of heat coating did you get. Tony |
| | #8 (permalink) |
| MINI2 Regular Join Date: Jun 2003 Location: Madrid, Spain Local Time: 10:31 PM
Offline | Does the obx header pass TUV?( sorry i dont know the equivalent of that in UK) Here in spain things are getting bad with the technical inspection of the cars and we need the exhaust system to be homologated for passing the inspection. Thanks El mini no es un coche, es mi vida (Mini is not a car is my life) |
| | #9 (permalink) |
| Still glowing in the Dark | I doubt the OBX passes TUV inspection as I brought it from America and I think it is manufactured in the Far East.I have put the standard BMW Mini cat on the end of it so it will definitely pass emission tests,When fitted you hardly see much of it once the heat shields are fitted. Regards Tony |
| | #11 (permalink) |
| MINI2 Regular | i am not sure it will pass the emission test or not, but obx is a exact copy of Supersprint, so i assume it does pass the test if u keep the orginal Cat on. with performance, i did notice some performance gain, but i also notice that the car stall much easier than b4, and also the fuel consumption went up a little. However I am using a AMD onecilck map that only take into account of my cat back exhaust, intake and pulley, i am in the process of getting it updated, hopefully that will add a few kw to the car. with the heat shield, i did have to bent the shield abit to fit it back in, but the exhaust sound the same, but after fitted the heat shield u can feel the engine bay is not as hot as b4. I used Jet Hot coating on the header.... i am quite happy with it, I have the supersprint cat back exhaust, after installing the header i do feel the exhaust is a little bit louder but just by a little, and when u down shift the exhaust make this popping noise.... which sound pretty cool...... |
| | #12 (permalink) |
| Still glowing in the Dark | I have checked the header again on the way home tonight ,a distance of 4 miles at speeds of only 30-40 MPH.I pulled onto the drive ,left the engine running and popped the bonnet.I could see the primaries from the headers where glowing a dull red in the dark.I cant see how it would be the cat restrighting the flow as it is a standard one welded onto the flexy coupling and the note of the exhaust seems louder.The pulses you can feel from the tail pipes seem very powerfull.Has anyone noticed their standard exhaust showwing signs of getting this hot. Tony |
| just installed obx header on my MCS | asinn | Engine & Drivetrain Tuning | 6 | Dec 25th, 2005 01:22 PM |
| obx header | asinn | Engine & Drivetrain Tuning | 20 | Dec 5th, 2005 10:00 PM |
| OBX racing header | asinn | Engine & Drivetrain Tuning | 1 | Nov 22nd, 2005 04:35 PM |
| Interior glow in a cabrio | EV Mini | MINI Convertible | 3 | Aug 14th, 2004 08:33 PM |
| Another Street Glow MINI | macncheese | Exterior | 7 | Apr 26th, 2003 06:56 PM |
