Old Feb 12th, 2006, 11:10 PM   #1
ScottishcooperS
ScottishcooperS's Avatar
Local Time: 09:10 AM
Scotland Track days
Hey all !!
Iv got a track day coming up on the 19th, ill just be on the 1.4 mile I was just wondering if anyone has any tips on preparing for such an event to get the best out of the car and a start on the other cars?
  • I fill up with optimax so ill be doing that anyway
  • Was thinking about more octane points and i notice Lohen do Millers oil feul treatment and there is a +4 octane points one, has anyone tried this?
  • Also ill be checking my oil levels too make sure they are okay
  • The back seats will be coming out
  • And she will be getting washed and waxed
All tips and experiences will be much appreciated! I got 15.3 sec on the 1/4 mile when my mcs was standard so im hoping to beat that
Willie
a l t a - j c w - e i b a c h - u l t r a - g t t
m i l l t e k - s p e e d l i n e
Old Feb 13th, 2006, 08:21 AM   #2 (permalink)
yogi
yogi's Avatar
Half fill the tank and save weight.
Old Feb 13th, 2006, 04:39 PM   #3 (permalink)
ScottishcooperS
cheers guys!!
Old Feb 13th, 2006, 05:46 PM   #4 (permalink)
supercoopers
supercoopers's Avatar
Local Time: 10:10 AM
ScottishcooperS,
When was the last oil change on your car? If it was more than 3-5K ago then I would personally have an oil change done before the trackday (I do them myself; dead easy ) and also after the trackday. If you wanted to skimp on one of the changes, the pre-trackday change is not THAT essential, but dump the oil after the trackday if you are doing sustained mid-high RPM runs.
The stock MCS oil cooler keeps the oil at 210-235 deg F on track and the high levels of constant heat may have detrimental effects on the lubricating quality of the oil.
As has been mentioned, whilst on track run with roughly 1/2 a tank of fuel but be careful not to run out while you're on track...your car's economy will be somewhere around 12mpg while you're caning it remember Just bring a 'Jerry' can or two of Optimax; an extra 20-30 Litres should suffice again, depending on how long the day is. If there is a petrol station near the track, don't worry about carrying petrol about!
Most important of all, race your own race if you know what I mean. If this is your first outing on track take it easy for the morning while you accustom yourself to the track and the characteristics of your car. Don't be disheartened if you are not keeping up with others, you don't know their experience level nor car mods etc, so just enjoy the experience in you own private way, and give a wave when a loon such as myself overtakes you on two wheels
Have a great day out!
Henry
Old Feb 13th, 2006, 07:59 PM   #5 (permalink)
ScottishcooperS
Scotland
Quote: Originally Posted by supercoopers
ScottishcooperS,
Henry
Yeah my oil change was more than 5000 miles ago so i may change it but i think i defo will after it.
Its not my first time on the 1/4 mile, but im still learning so im taking everything on board
Willie
Old Feb 13th, 2006, 08:52 PM   #6 (permalink)
yogi
yogi's Avatar
How about turning off the traction and letting a few psi out of the front tyres for more grip? What was your terminal speed last time? In my Boxster I can't remember my time, but saw about 100 when I crossed the line.
Old Feb 13th, 2006, 09:22 PM   #7 (permalink)
ScottishcooperS
Yeah i always turn off the traction control. Never heard of the tyre pressure tho?
I crossed at about 92 MPH i think.
Willie
Old Feb 13th, 2006, 10:59 PM   #8 (permalink)
Paul Webster
Paul Webster's Avatar
Do they prepare the track??
Do they glue the track?
Did your 60ft vary during the day??
What do you shift at??
Have you been on a rolling road??
It's not how much you spend but how well you spend it
Old Feb 14th, 2006, 11:38 AM   #9 (permalink)
ScottishcooperS
Scotland
They do prepare the track
Not sure about glue
Yeah it was my first time so everything was pretty up and down!
What do you mean shift at?
Never been on the rollers no
Old Feb 14th, 2006, 07:53 PM   #10 (permalink)
Paul Webster
If they do prepare the track then you want to be first up there because most street tyre cars lift the rubber up off the track.
It is a rule off thumb to shift at 500rpm above your peak rpm, without a rolling road session you wont be able to tell that.
The only other way is to try shifting at 6500 on a couple of runs then 6800 on a couple.
Good Luck
Old Feb 14th, 2006, 09:56 PM   #11 (permalink)
ScottishcooperS
Cheers mate. ill bare all that in mind .
Old Feb 15th, 2006, 07:39 AM   #12 (permalink)
FunkyJMan
MINI Mover
FunkyJMan's Avatar
Send a message via MSN to FunkyJMan Send a message via Skype™ to FunkyJMan
Which strip are you going to? I only know of Crail up there?
England Male View FunkyJMan's Pepper White & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 15th, 2006, 11:04 AM   #13 (permalink)
ScottishcooperS
Scotland Crailraceway
Yeah it is crail that im going to mate
Its a neminiscotland mini meet, there are a fair few of us going!
Old Feb 21st, 2006, 08:48 PM   #14 (permalink)
Paul Webster
How did you get on then???
Old Feb 22nd, 2006, 01:59 PM   #15 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi heres some advice on how to get a good time.;-20psi max in the front tyres, 45psi in the back, traction off, get the car only 'just into staged' (ie as far BACK as possible), hold 4000rpm clutch pedal on the floor NOT on the biting point, let the other car go, count to 3 to compose yourself, let the clutch out quickly and fully, control the wheelspin on the THROTTLE by watching the rev counter and maintaining revs between 4-6K, do full throttle gear changes at 6200rpm, dont put it in second just because your rev counter says 7000rpm, you are probably only doing 8mph hence the point about controling the spin with your right foot (never the clutch) .You will bog down if you change at 8mph!
Regards Roland GT Tuning
ps your reaction time can read 34minutes and 23 seconds, your run time can still read 13.9 seconds though (example)
Old Feb 23rd, 2006, 08:21 PM   #16 (permalink)
ScottishcooperS
Scotland Crail
It was poor weather conditions so the times were poor as the track was wet and
had no grip. I beat everything i came up against except a cooper s works, but it
only beat me once and i beat it more Was a good day out tho and was more
a day for racing other cars rather than the clock because of the conditions.
Some pics of the day
Minipaul and me going head to head
On the way down
Cheers for the reply Roland.
When track days go wrong.... Tonyt3 General Discussion 24 Aug 10th, 2006 09:32 PM
Track-days bigalloys UK & Ireland Discussion & Event Planning 4 Dec 9th, 2003 07:39 PM
Track Days ERIN OLSON Australia 5 Oct 6th, 2003 02:41 PM
JCW CS 3 days at the track Dawing Engine & Drivetrain Tuning 1 Sep 18th, 2003 06:33 PM
Track days and insurance?? MarkW19 Finance & Insurance 2 Aug 28th, 2003 04:52 PM
