Wipac
Old Feb 13th, 2006, 04:35 PM   #1
Carcass
Local Time: 04:32 PM
Alternator Pulley Removal/Replacement
I hope to very soon replace my SC pulley with a -15% unit. I have purchased a larger replacement alternator pulley as well. This should allow the use of a standard belt.
Are there any tricks or tips to removing the alternator pulley?
What size/type of fastener holds it to the alternator?
Reverse threads?
Thanks in advance!!!
DS/B MCS Stripes, Black Leather, Sport, Premium, Navigation
Old Apr 6th, 2006, 03:31 AM   #2 (permalink)
Miataman
I'm thinking no one has done this.
Some how, some way, it is going to happen.
03 Cooper S DS/W,Sport/Prem,PB-L,NAV,Alta,H-Sport,MINI Tuner
99 Miata 10AE #1288 SCCA Solo 2 CS 58
United States View Miataman's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 6th, 2006, 04:17 AM   #3 (permalink)
MiniFr34k
fr34king n00b!
MiniFr34k's Avatar
Local Time: 07:32 AM
whats an alternator pulley meant to do?
Old Apr 6th, 2006, 04:22 AM   #4 (permalink)
n00b
Twincharge???
n00b's Avatar
It's not no one have done it but they're not on here that's all
Try http://www.northamericanmotoring.com/
During the SC pulley installation the alternator pulley doesn't required to be removed and there's no point anyway. Even when you changed the oversized crank pulley (2-4%, whatever one you like) it still doesn't mandate the change of an undersized alternator to correct its driven speed, given that the alternator as it names implies is alternate ie it's not running 100% of the time, only switch itself on when it detects voltage drops to a certain level. Plus overdriving it by a mere few percent isn't likely to significantly reduce its life anyway as it should still be well within its tolerance.
(congrats to Paul though, his SEO works a treat! M2 must be ranked pretty darn high on search engines just noticed theres a fair few Americans popping in suddenly)
EDIT: I got a few things wrong up there...correct me please
Australia   Reply With Quote
Old Apr 6th, 2006, 04:26 AM   #5 (permalink)
Miataman
It is slightly oversized to underdrive the alternator and to take up the slack in the drive belt when an undersized super charger pulley is fit. This allows the use of the stock sized belt. It is also supposed to be lighter. Some people are using a larger crank pulley but the stock pulley is damped to absorb engine vibration. Some people don't recommend an undamped crank pulley.
Pulley removal tool Blusox Engine & Drivetrain Tuning 3 Sep 28th, 2006 04:08 PM
tracking rod removal and replacement scooperman_uk Maintenance & MINI Care 0 Aug 11th, 2006 08:39 PM
tracking rod removal and replacement scooperman_uk Wheels, Tyres & Brakes 0 Aug 11th, 2006 08:38 PM
Pulley and Removal GeoffMM Engine & Drivetrain Tuning 2 Dec 31st, 2005 03:22 AM
Pulley removal tools mini_man Engine & Drivetrain Tuning 2 Oct 15th, 2005 06:42 PM
