Wipac
Old Feb 14th, 2006, 02:53 AM   #1
COOPER S KID
"Dare to be different"
COOPER S KID's Avatar
Local Time: 07:35 AM
oil cooler fitment
Hi guys , I just scored myself an oil cooler and i was interested in fitting this to my cooper s ! Does anyone know how i would go about hooking this up ......?? The only thing i can think of are those little adapter things that screw in before the oil filter and then the filter goes on top but where to find one ...??
any help or suggestions are greatly appreciated thanks heaps guys !
josh............
Old Feb 14th, 2006, 03:19 AM   #2 (permalink)
enzothemaddog
Un-Banned
enzothemaddog's Avatar
What sort of cooler m8, Madness, OEM Cooper....? RobboMcs (Oz Section) has a cooler in his MCS thats from a MINI Cooper. He might be able to help you.
What part of Oz you in? And if you dont mind me asking, What else have you got on your car to you wanting an oil cooler. Do you race?
Vatican City State   Reply With Quote
Old Feb 14th, 2006, 03:41 AM   #3 (permalink)
n00b
Twincharge???
n00b's Avatar
Becareful about the oil cooler fitment, I've managed to kill a radiator as the oil cooler was having an argument with the radiator.
Australia   Reply With Quote
Old Feb 14th, 2006, 04:38 AM   #4 (permalink)
smc
smcc
Local Time: 06:35 AM
location is important, at the front of the radiator then it will restrict cooling capacity for the coolant, at the rear of the radiator no point because the hot air from the radiator will not be of help for cooler thus may cause LO viscosity to drop.Best location is below the radiator just behind the front bumper I guess. If u are not into race I suggest not to install
Singapore Male   Reply With Quote
Old Feb 14th, 2006, 04:48 AM   #5 (permalink)
COOPER S KID
its a no name oil cooler and it is quite small the size is 280mm long x 120mm high x 50mm thick so it should be ok in the front bumper ! also i have a carzone bodykit so the airflow at the front is more than enough !!! im wanting to fit this more for looks as i only have minimal mods at the moment : MTH remap , Cold air intake , cat back exhaust plus i put the car in lots and lots of car shows i think it will look good in the front bar with anodized fittings and braided lines !!!
Old Feb 14th, 2006, 04:49 AM   #6 (permalink)
COOPER S KID
sorry enzo !!! im from melbourne mate !!
Old Feb 14th, 2006, 09:38 AM   #7 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Local Time: 08:35 AM
Hi,
As Nick (Enzo) mentioned I have an oil cooler, which is front mounted. This install is tricky, as it requires removing the small stock oil cooler, and installing a custom plate with mountings for the lines.
Also, once installed it is a ***** to get right, as the flex from the engine tends to stretch and wear the oil lines, which can rub on other components, and potentially break or leak, which is a major disaster
You definitely DO NOT want to run this with braided lines, as they have less flex or stress and will probably cause problems BTW, I think that was probably the problem with dairy boys cooler, as when I saw the car in Greendevil's days, it was definitely braided lines
Also there is no performance gain from this mod at all, apart from engine longevity on the racetrack.
Considering all these factors, and your stated aim of putting the car in car shows I would recommend you install the cooler, with nice anodised fittings and braided lines, but don't connect the lines, and hide the ends of the lines where no-one can see them
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 14th, 2006, 10:44 PM   #8 (permalink)
COOPER S KID
thanks robbo !! i was hoping i could just buy one of those sandwhich filter type things that goes on the block before the oil filter !! i actually thought about the engine movement and what would happen to the oil lines so i was gonna use braided lines and give them a bit of slack and cable tie them out of the way so they dont rub on anyhting............
Old Feb 14th, 2006, 11:09 PM   #9 (permalink)
COOPER S KID
robo i am havin a good think about what you said !! I like the fake idea to but deep down i would know it wasnt real......... im thinkin i still want to fit this , do you have anymore tips or hints ...?????
Old Feb 16th, 2006, 04:53 AM   #10 (permalink)
enzothemaddog
Un-Banned
Not trying to put you off or anything, but I just think you should probably not do this.
As you say, you're doing a show car, why not think about investing a bit into getting someone to make you a FMIC? You can find several pics around with some basic setups. It might lose you a bit of power, maybe gain but I dont think thats you're real motivation in what you want to do with the car.
In terms of looks you could'nt impress more with shifting an IC forward and it would be bigger and badder 'looking' than an oil cooler.
Old Mar 1st, 2006, 08:27 PM   #11 (permalink)
pocketrocketowner
Best Personal Regards
Local Time: 11:35 PM
The sandwich type fittings you are on about are NFG on the MINI as they are used on the standard type oil filters, which the MINI does not have. MINI Speed in the UK and MINI Mania in the US and the UK, sell a kit. I have not had any luck getting them to sell me the special adaptors they use.
I had queried Robbo, a very long time ago on this, I went as far as getting the tranny cooler he used but unfortunately never got an answer as to the engine side of the install.
I found his idea of using the Cooper auto cooler very neat indeed!
I do track and have raced my car, I find oil temps in the 250 Deg F to be too hot for comfort, but hey, the JCW Race prep boys tell me they never use coolers......
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
oil cooler in MINI (not S) intrigue182 MINI Cooper 9 Oct 1st, 2008 09:27 AM
oil cooler-Does it drain when when having oil change? yorobby MINI Cooper S 4 Sep 29th, 2004 01:00 AM
After Market Oil Cooler for MCS??? Redleg13 Engine & Drivetrain Tuning 2 Aug 13th, 2003 10:24 PM
First oil change> Do I have to drain oil cooler ? yorobby Maintenance & MINI Care 3 Sep 26th, 2002 08:44 PM
Is there an oil thermostat for oil cooler? jmardy MINI Cooper S 17 Jul 22nd, 2002 05:59 AM
