Think Mini
Old Jul 15th, 2002, 07:59 PM   #1
kb_solo2
kb_solo2's Avatar
Local Time: 01:28 PM
Wheel Studs
Has anybody replaced their wheel bolts with wheel studs? What length did you use? How far does the stud extend past the end of the nut on a stock MINI wheel?
Thanks for the help.
Picked up the car on Aug 6, 10,200 miles already IB/W Cooper, Rogue Exhaust, Magnecor Wires, K&N filter, Porterfield Brakes. Serious Autocross Fun
Old Oct 12th, 2002, 11:03 AM   #2 (permalink)
gowest
gowest's Avatar
Local Time: 05:28 PM
I'm looking to make this same mod. Will someone measure their stock bolts, full length, not just the threaded area, so I will know what to look for? My S has a week 42 build, so it will be another 6+ weeks until I get mine.
2001 & 2002 SCCA, STS Pro Solo National Champion. 2003 SCCA, Solo2 Nationals 8th, co-driver (Courtney) 2nd in 03 & 04
2003 JCW 210, London Stainless Headers, custom cat back with 5" SuperTrapp, 15x7.5 SSR's and 16x8 ce28n's, Quaife, KW Comp 2 Ways
Old Oct 12th, 2002, 12:06 PM   #3 (permalink)
motoring
Autox Monster
motoring's Avatar
Local Time: 02:28 PM
I purchased 40mm studs and nuts from BMP Designs. They are about 10mm too long for my purposes (can't put the centercaps back on), but depending on the wheel or spacer you use they might work fine.
IB/W MC with the really big checkered flag on top
2004 H Stock National Champion
United States View motoring's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 14th, 2002, 02:32 AM   #4 (permalink)
minimc
Local Time: 04:28 PM
Please forgive my ignorance regarding this subject, but what's the difference, and why would I/you care to change these. - Not being smart here, am really interested.
I myself have been pondering aftermarket wheels and have been cursing the 4x100 pattern - so few choices compared to 5 lug patterns.
Old Oct 14th, 2002, 02:53 AM   #5 (permalink)
motoring
Autox Monster
motoring's Avatar
What we're talking about are the bolts holding on the wheels. The MINI has bolts that screw into the hub and hold on the wheel. For racing purposes it is easier to use studs (just the threaded part of a bolt) permanently mounted in the hub and seperate lugnuts that hold on the wheel.
I agree the 4x100 bolt patern has some limitations, but I have heard that several wheel manufactures will be offering more styles in 4x100 due to the popularity of the MINI.
If you really want a 5 bolt pattern you can do what one of the aftermarket tuners did for their show car (Hamann ?) and switch the entire brake system (hub, rotor and caliper) to a compatable 5 bolt system $$$$
Everything is fixable
Old Oct 14th, 2002, 05:05 AM   #6 (permalink)
Mugami
Mugami's Avatar
One other consideration why the changing from bolts to studs. For the guys going to After market wheels. Its easier to get fancy designer lug nuts and locking lugnuts than ones in bolts. Just go to a local Autoparts store and try to find the bolts in chrome vs all the different Nuts you can find (no im not talking about the guys behind the counter)
02 MCS DS/W (Totaled November 02 on Fall Folage Run)
03 MCS DS/W (See my MINI Profie for extensive list of mods)
United States View Mugami's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 14th, 2002, 03:37 PM   #7 (permalink)
CSDan
CSDan's Avatar
Send a message via AIM to CSDan
Really-- I have found that there are PLENTY of wheels that fit--our bolt pattern is virtually identicle to a honda civic.
Daniel
Cooper S:
Now new and improved with Helix short shifter, Ghetto K&N HAI, Rota Circuit 8's w/ T1'S Proxies/Kosei K1 racing wheels with Falken Azenis(for Auto-X/Trackday), and H-sport springs. UUC rear sway waiting to install
Old Oct 14th, 2002, 03:53 PM   #8 (permalink)
AidenL
Nice TTs.........
AidenL's Avatar
Local Time: 09:28 PM
Send a message via MSN to AidenL
I'm actually wondering if I can use the bolts that came with my 15"s when I fit my new 17" S spokes later this week, or do I have to buy a new set........anyone done this already?
Global Moderator
Ireland Male View AidenL's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 14th, 2002, 05:13 PM   #9 (permalink)
minimc
Thanks for the info. How does one go about changing from bolts to lugs (how much work?)
As for the comment about wheel options... While there are a fair amount of 4x100 options there are numerous 5-bolt wheels that are not offered in 4x100.
I think you may have hit the nail on the head with your comment about 4x100 & Honda - in that most wheel mnfr's producing 4x100 aren't making them for the Mini. They are outfitting mostly boy-racer types & the styles that appeal to that crowd. There are SO many cars that fit THAT profile, so they follow the $ - not what looks best on our Minis.
IMHO
Most aftermarket wheels do not mesh well with Mini's organic form.
Old Oct 14th, 2002, 05:21 PM   #10 (permalink)
motoring
Autox Monster
motoring's Avatar
How To.
Installing wheel studs is very simple on the MINI.
Jack up the car. Remove the wheels. Screw the new studs into the 4 holes in each hub (use some thread lock) tighten. Put wheels back on. Screw on new lug nuts. Torque. Lower car.
Simple.
Some other cars require removing the brake rotor, etc. etc.
Old Oct 15th, 2002, 12:54 AM   #11 (permalink)
DaveNagy
DaveNagy's Avatar
How do you tighten the studs? (When you're initially threading them into the hub.) It doesn't seem like you'd have much purchase. Do you use a special tool, or can you thread the lugnuts onto the studs and then tighten the whole assembly?
Probably a dumb question, but there it is.
-Dave
Old Oct 15th, 2002, 01:05 AM   #12 (permalink)
benggolf
benggolf's Avatar
DaveNagy, thread two open nuts and jam against each other. Apply thread lock on the opposite end of the stud that will go into the wheel hub.
Use your wrench on the jammed nuts to screw in the stud. Presto!
2005 Mercedes Benz C55 AMG 2006 BMW Z4 M-Coupe - Premium Pkg. 2007 Honda Fit - Sports Pkg.
2005 V-Star 1100 Custom 2007 Honda 250 Reflex
Canada View benggolf's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 15th, 2002, 01:44 AM   #13 (permalink)
motoring
Autox Monster
motoring's Avatar
Actually the studs have a 6mm allen head. Just tighten with 6mm allen wrench.
Old Oct 15th, 2002, 01:29 PM   #14 (permalink)
minimc
Anyone thinking of replacing the Mini hubs outright?
Old Oct 15th, 2002, 03:54 PM   #15 (permalink)
motoring
Autox Monster
motoring's Avatar
i would be careful with replacing the hubs there may be distinct warrantee issues regarding the ABS system.
My .02
Old Oct 15th, 2002, 04:56 PM   #16 (permalink)
minimc
Point taken. ...but I was talking BMW for BMW... and not some hap-hazzard job.
Old Oct 15th, 2002, 05:33 PM   #17 (permalink)
motoring
Autox Monster
motoring's Avatar
It should work... one of the tuner companies has done it. You would also get the benefit of even larger brakes.
Old Oct 15th, 2002, 06:25 PM   #18 (permalink)
motoring
Autox Monster
motoring's Avatar
Check out Breyton, they have done the conversion.
http://www.breyton.de/
Old Oct 15th, 2002, 08:40 PM   #19 (permalink)
minimc
motoring
Thanks for the Breyton link!
Question though: How do you know that they've done the conversion? I can't find anything more than a photo of a Mini Cooper with 7x18 rims. ...And it does look FAT!
Old Oct 15th, 2002, 08:42 PM   #20 (permalink)
motoring
Autox Monster
motoring's Avatar
Look closely at the photo...5 bolt holes.
Wheel bolts/studs C15WKS Wheels, Tyres & Brakes 9 Feb 2nd, 2007 09:02 PM
Colour of wheel studs? Some different? MiniMpi Wheels, Tyres & Brakes 5 Jan 19th, 2006 03:13 PM
Change from wheel bolts to wheel studs updated norm03s Wheels, Tyres & Brakes 1 Jul 23rd, 2003 06:16 AM
17" S Wheel studs Pritch Wheels, Tyres & Brakes 1 Jul 2nd, 2003 07:26 PM
Wheel Spacers and Studs or Bolts gowest Wheels, Tyres & Brakes 6 Jan 5th, 2003 10:16 PM
