| New Mini Specialists | NEW! Janspeed Manifold and removable high-flow cat Now available to buy: Janspeed Manifold with removable high-flow cat The Janspeed manifold with removable high-flow sports catalyst is one of the best available for the new MINI. The system uses a 4-1 downpipe design with increased diameter bore. As the cat section is removable it easy to change to a de-cat pipe (Available seperately). There are noticable power gains to be had by fitting the manifold and helps to improve mid-range power and torque. Price: £490 inc.vat The Janspeed De-cat pipe replaces the high-flow catalyst on the Janspeed Manifold and removable high-flow cat. The pipe is designed as a bolt on item and allows you to quickly change from running a cat to de-cat. Using a de-cat pipe further increases air flow and therefore improves bhp and torque across the whole range. The de-cat pipe is for off road or track use only. Price: £58 inc.vat For more information please see our online store at www.lohen.co.uk Cheers, Nick |
![]() Winner MM best MINI ONE! Join Date: Jun 2004 Location: St Leonards-on-Sea Local Time: 10:52 AM
Offline | Hi , i have been thinking of getting a sports manifold, is there any more information hwere i can read up about them? I was thinking of getting one of the chips but i dont think that will be any good for me as i want to improve the torque etc at lower revs ranges where the chips dont seam to offer that. |
| | #7 (permalink) |
| MINI2 Regular Join Date: Jun 2003 Local Time: 09:52 AM
Offline | I would imagine that the cat has been put on upside down... and on the manifold it looks like its the wrong way too but theres loads of spare length in the o2 sensor wire anyways so shouldn't cause any problems... Just a little slip up by whoever has done the pics/attached the cat... i wouldn't worry tho JonnyC ![]() |
| | #8 (permalink) |
| Mini Mod Join Date: Sep 2002 Local Time: 05:52 AM
Offline | Pointing straight up would be bad as well. On second look the rear flange is 90º out so maybe there is something odd going on. I just want to be sure this doesn't represent the final product. |
| | #13 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 10:52 AM
Offline | Looks similar but differs in that the GTT product uses TIG welding throughout ( mostly mig on the janspeed one) and the GTT secondary pipe diameter is 6.5 mm larger in diameter than the Janspeed. New GTT 'fat cat' GTT Mk2 manifold coming very soon! Regards Roland GTT ![]() |
| | #14 (permalink) |
Offline | If I recall correctly secondary pipe diameter will affect the rpm where the header is most efficient thereby affecting the torque range. Would not the larger pipe be more applicable to higher rpm requirements like tracking whereas the smaller diameter would be more effective on the street? All of my experience with this is on NA V8s so I'm not sure of the influence these dimensions will have on our little SC'd motor. Thoughts from Lohen and GTT, and anyone else for that matter, would be appreciated. |
| | #15 (permalink) |
Offline | Hi Obe,The primary length in conjunction with exhaust valve timing effects the rpm at which the 'cylinder scavenging' occurs.The minimum 'calculated' primariy diameter for this car should be 1.5 " and secondary 2.75" (I know thats very big!). We currently use 2.5", the new version will be 2.75". The secondary should be the same dia.as the system as is part of it as far as the gas is concerned. The bigger diameter the secondary the better the scavenging ie a bigger negative pressure pulse travelling back up to the cylinder to not only suck out the last bit of exhaust gas but also suck more inlet in . Remember both inlet & exhaust valves are open at TDC 'valve overlap.' allowing us to take advantage of this sucking effect. Turbo cars benefit from a very large diameter first section of exhaust,even if it then reduces down in diameter further downstream. It allows the turbulant flow to break up into a laminate flow reducing backpressure. Basically gas corkscrewing down the pipe has to travel much further . I'll put more input into this on the new thread I'll start soon regarding our new Mk2 sports cat &manifold.And yes the system in an ideal world needs to be 2.75 (3" ) idealy too. Regards Roland GTT ![]() |
| | #16 (permalink) |
Offline | Thanks. Maybe once again an NA thing but larger primaries also reduce gas velocity faster than smaller diameter tubes. This affects primary and secondary tube length. All this in turn impacts the effective optimal rpm at which the header is most efficient. Correct? |
| Noise from Milltek Manifold + Hi-Flow Sports Cat | Fiacra | Engine & Drivetrain Tuning | 5 | Feb 3rd, 2005 01:54 PM |
| Milltek Manifold and High Flow Cat | stevenrsturbo | Engine & Drivetrain Tuning | 11 | Apr 6th, 2004 07:53 AM |
