| MINI2 Regular Join Date: Mar 2005 Local Time: 10:37 PM
Offline | Modded air flow for K&N Typhoon intake. Hi I have modded my air flow for the K&N Typhoon intake. 1: This is without modden airflow: ![]() 2: This is modded with a 60mm tube: ![]() 3: This is modded with a 70mm tube: ![]() A close up: ![]() What do you think? Which one is best to use? |
| MINI2 Regular Join Date: Nov 2005 Location: Aberdeen Local Time: 09:37 PM
Offline | That will suck in too much hot air in my opinion! Although you have a direct cold air feed, the filter is still in the moddle of a very hot engine bay and will suck in alot of hot air from it which may result in a loss in perfromance. a l t a - j c w - e i b a c h - u l t r a - g t t m i l l t e k - s p e e d l i n e |
| | #13 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 09:37 PM
Offline | I think that unless the intake is sheilded most Cooper intakes don't give much power as they suck far too much hot air. The pipe viper is sheilded a bit, and i have been told the mini mania do a cold air intake for Cooper. Personally I would improve the flow to the stock airbox witrh some mods, put a piper/K&N or similar rplacement filter into it and then change the feed pipe from box to engine to a smooth bigbore pipe....this would give better performance especially if the inlet to the stock airbox was modded to improve size and flow of air. Essencially a home made CAI for the cooper....Why someone doesn't make something like the Alta or GTT unit (Cooper S) for the Cooper I just don't know! madness. Someone who is competant could create a really good CAi for the cooper based on a K&N/Piper intake but with a method of sealing from the warm air in the engine bay...You could make a killing if you sold it. R |
| | #14 (permalink) |
Offline | Not a bad mod youv'e done though (yours too beastmaster) Pretty ingenious. Maybe theres someone with some metal work experience to fabricate a sheilding box and some spare classic mini rubber door seal spare to seal it to the underside of the bonnet...instant CAI for the Cooper! Bet that would show some results. |
| | #15 (permalink) |
| AJO' !!! | this is a good idea. I see you're well informed about all the induction kits for one/cooper... well right now I have a classic pipercross panel filter and I'm very happy of it's cost/performance-noise ratio but I'm starting to look at something more... more power, more noise... little money! the viper kit from pipercross is like the bmc cda? what would you fit to your mini? ![]() |
| | #16 (permalink) |
| MINI2 Regular Join Date: Apr 2003 Location: Brussels Local Time: 11:37 PM
Offline | Hey Maaij - I think it's a good idea what you did. What did you go for in the end and did it prove to be resistant (vibration, heat) - no melting of the pipe? No chance of water being sprayed directly on your typhoon? I have the typhoon as well and love it! |
| | #17 (permalink) |
| flashingMINI's | Viper Vs K&N Typh Hooked OBD Software upto 2 Mini Ones. 1 with typh and one with Piper X Viper. took cars out same day same route etc Air intake temp .... K&N = High of 43 Deg ( Low of 22 Deg ) Viper = Hight of 24 Deg ( Low of 14 Deg ) I Know what one i Use! ![]() |
| | #19 (permalink) |
| MINI2 Regular Join Date: Apr 2004 Location: Berkshire Local Time: 10:37 PM
Offline | Very impressive solution. I was wondering if anyone could tell me off hand the ID (Inside Diameter) of the modded air tube section as I am planning to do the same to my mini one. On another subject I have recently put a typhoon in my one and I am very pleased with the results , does anyone know how to mount the filter so it does not wear into the bonnet lining?![]() |
| Air Intake Panel Filter / K & N typhoon effects on performance and insurance | TShaw | Engine & Drivetrain Tuning | 5 | Aug 22nd, 2007 04:54 PM |
| K & N Typhoon Cold Air Intake | bbrad | MINI Cooper | 9 | Apr 23rd, 2006 08:26 AM |
| K&N Typhoon Cold Air Intake | benggolf | Engine & Drivetrain Tuning | 4 | Apr 8th, 2003 12:22 AM |
| K&N Typhoon intake for the S | rocketpop | Engine & Drivetrain Tuning | 6 | Dec 21st, 2002 02:09 PM |
