| MINI2 Newbie | Steering Noises, Accel Noises, and others I'm having a strange quirk with my Power Steering. It's making a whining sound when I turn the wheel either way, and the furhter I turn, the louder it gets. I'm also having a grinding sound happen when I accelerate. It grinds for about a 1 second and about 5 - 6 times. Also, is it normal for my MINI to pull to the left when I break? Or is that a problem with alignment? Thanks -Michael T |
| MINI2 Master Join Date: Jul 2005 Location: Poole Local Time: 02:45 PM
Offline | no.1 the whining/buzzing is normal, the mini has an electric power steering motor. ![]() no.2 might need more info no.3 have you tested it on a level road, sometimes road camber can affect the car. ![]() |
| MINI2 Master | 1. The steering does make that noise. It's normal 2. It could be the manifold. I had mine replaced for a vibrating noise on acceleration 3. There have been numerous threads about MINIs pulling to the left under braking. Apparantly it's a feature. I hope it's not a water feature when driving along side a river. |
| Loving Mini adventures! Join Date: Jan 2006 Location: Glasgow Local Time: 02:45 PM
Offline | I get the steering noise and I find the steering to be very sensitive to road camber as mentioned before. Try it out on as flat a section of road as possible (theoretically a flat road doesnt exist), and if it does it, get the alignment done? Dave by the way: should the steering pump make the whine with the ignition only at position 1 - no engine running? I am getting a whir noise before starting engine and unsure if it is the pump? |
| Steering nosies and Braking noises | Jeenyus | Faults & Fixes | 5 | Feb 19th, 2006 07:41 PM |
| Steering noises | Hopester | Faults & Fixes | 5 | Feb 14th, 2006 09:38 PM |
| Noises..? | PwincessVicious | General Discussion | 8 | Jan 16th, 2006 11:15 PM |
| Steering noises ! | Lumspeed | General Discussion | 1 | May 14th, 2003 09:30 AM |
