Wipac
Old Apr 26th, 2006, 12:15 PM   #1
Blusox
Local Time: 10:31 PM
OK, is this fact or fiction??
Right, first of all it breaks the ebay rule of:
"if its too good to be true then it isn't!"
But it ain't too cheap and there is some science behind it. So is this fact or fiction?
http://www.electronicturbosystems.com/3.htm
Can this replace the whole s/c and manifold system and be plonked on a cooper??? Any one done this or got one?
I need opinions please. Not sure about getting one unless a dozen or so people reply and say its magic!!! Otherwise I'm just interested what some of you more techie guys think.
United Kingdom View Blusox's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 26th, 2006, 12:49 PM   #2 (permalink)
bclinch
there are several kits like this up for sale it is a air filter with a 12volt fan on the inlet pipe cant see how it adds any more power as the performance filter cone is already on there and i would be pretty certain it would not add 20bhp there is only a certain amount of air a standard throtle body will take in any way personally i wouldnt buy it butter off just getting a filter on its own in my opinion.
Old Apr 26th, 2006, 01:05 PM   #3 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
It's just a powerful hairdryer
I've seen these on ebay from the same guy:
http://cgi.ebay.co.uk/supercharger-turbo-nissan-skyline-200sx-300zx-pulsar_W0QQitemZ8057838722QQcategoryZ36680QQrdZ1QQ cmdZViewItem
You might like to have a read of this, especially the "testemonial" at the bottom. I laughed at the comment it places no strain on your battery as it only requires 40A - could have been a typo!!
But he has a rival selling them for around £100:
http://cgi.ebay.co.uk/SUPERCHARGER-Mazda-MX3-MX6-The-Original_W0QQitemZ8059942607QQcategoryZ32094QQrdZ1 QQcmdZViewItem
They consist of an in-line centrifugal fan. I would think they are simply ON or OFF with no actual speed control, although there is a hint that the Mk4 version will be controllable, and they rely on the ECU to adjust to the correct air/fuel ratio.
If they can force more air into the engine I suppose they must work to some degree, just like square wheels might.
You might need to ask, if they work, why manufacturers don't fit them instead of resorting to complicated belt driven superchargers or exhaust driven turbochargers.
You might also like to ask;
Would you pay £300 for something that was available for £100.
Would you really want to fit it to your expensive car, if you think it's too good to be true it probably is.
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 26th, 2006, 01:43 PM   #4 (permalink)
Blusox
you guys have pretty much said what I was already thinking, just wanted some confirmation
Old Apr 26th, 2006, 02:42 PM   #5 (permalink)
Jim Ray
AprilWhine's Fuzzy One
Jim Ray's Avatar
Local Time: 02:31 PM
Total fiction. Your engine is a 1600 cc air pump turning about 3000 rpm. You will be trying to suck air through a blockage with that device.
Old Apr 26th, 2006, 02:44 PM   #6 (permalink)
Lohen
New Mini Specialists
Lohen's Avatar
Local Time: 09:31 PM
Send a message via Skype™ to Lohen
In principle it should work on cars with poorly designed inlet systems, but i would not expect much from it. I would be very surprised if this system could deliver as much boost as a well turbo/super charged system, and if it will be durable over a long time. You clearly wont see the same gains if you use that to replicate the cooper s set up.
Andrey
Click Here To Visit Out Website
New MINI Specialists
www.lohen.co.uk
Old Apr 26th, 2006, 05:27 PM   #7 (permalink)
wturf
WTURF
wturf's Avatar
Local Time: 05:31 PM
The MCS uses a "positive displacement" supercharger. This means that two intermeshing, driven rotors take air into a housing and compress it. Air cannot escape anywhere but forward into the engine. The amount of pressure delivered is measured in psi (pounds per square inch) versus what a simple blower can do in terms of "inches of water column pressure". One psi is equal to 27 inches of water column pressure.
Another analogy is to think of a race car travelling at say 100mph with a "ram air intake" on top of the carburetor (or F.I). The air velocity encountered exceeds what some little blower will deliver. I dare say this race car will benefit some, but not much from this configuration.
Don't waste your money, or stated another way- you get what you pay for.
United States Male View wturf's Dark Silver & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
American 2005 MCS Features - Fact or Fiction ? MadHatter MINI Cooper S 8 Oct 12th, 2004 04:32 AM
"learning" ECU/throttle response - fact or fiction? KenL General Discussion 12 Oct 30th, 2003 12:26 PM
2003 Sport Steering Wheel...Fact or Fiction? MiniMoke MINI Cooper S 79 Nov 7th, 2002 07:35 PM
