| MINI2 Newbie Join Date: Mar 2006 Local Time: 09:00 PM
Offline | How to get the exhaust manifold OUT??? Hey guys, installing turbo kit... have the exhaust manifold completely disconnected, now how in the heck do I remove it from the car? Up it catches the heat shield/coolant reservoir/valve cover, down it's caught by the black brace...... anyone? NFCooperS |
Offline | Nevermind guys, figured it out.... found another post on it too after another hour of searching.. Anyone who needs to know in the future: Remove the driver's side heat shielding FIRST (turbo install guide says to do it after removing the manifold), then angle it out and down through the bottom. For searching assitance, disregard: exhaust manifold removal header replacement problem NFCooperS |
Offline | Yes twincharging, Alta kit, looking for 20psi Full Alta Kit Alta Whamadyne Intercooler w/ sprayer JSCspeed DTEC computer with knock-lite and boost control MSD ignition Custom (non)cat back exhaust slotted/drilled rotors Axxis pads stainless lines LOTS OF FUN Hehehe NFCooperS |
| | #6 (permalink) |
Offline | The folks at Alta seem to think that up to 21psi can be had safely on the bottom end with their larger intercooler while being sprayed. I also have the added backup of the boost controller and a knock-lite to let me know if I'm pushing it to hard.... but we'll see where I get to! Bottom end might be being rebuilt in the next year... sooner if I blow it up! NFCooperS |
| | #7 (permalink) |
| MINI2 Regular Join Date: Aug 2004 Local Time: 08:00 AM
Offline | hehe, a key to makeing the engine last is low enough air temp and enough octane in fuel + right timing, if it knocks to much it blows. I tried 30psi on a stock BMW 2.8 when WG hose melted.. it went bang ![]() |
| | #8 (permalink) |
Offline | I plan on starting with minimal boost, maybe 16psi... and turning it up slowly using the boost controller. Maybe mixed gas for a few test runs to see how much I can turn it up, but at least premium all the time. Almost everything is on right now, relocating the power steering was the biggest PITA. Now it's all the little annoying clamps and tiny hoses and electrical wires for the gauges.... NFCooperS |
| | #10 (permalink) |
Offline | No new head.. and backpressure would be downstream of the turbo, not upstream. 16psi is just that.... 16psi. With bigger exhaust valves, more efficient plumbing, etc etc, it will just be easier to make the 16psi. This is a basically stock 04 Rally edition S. I'm seeing how it responds to this upgrade, from here it may be nitrous, and eventually Im sure a full engine buildup. For now, this is the money I have to put into it. NFCooperS |
| Exhaust manifold | 1andy | MINI One | 6 | Jun 4th, 2007 11:50 AM |
| Exhaust manifold needs replacing? | matt_s | Faults & Fixes | 2 | Nov 5th, 2006 01:44 PM |
| Exhaust Manifold Design?? | venox22 | Engine & Drivetrain Tuning | 3 | Aug 16th, 2006 08:50 AM |
| exhaust manifold | rhinolad | Engine & Drivetrain Tuning | 4 | Apr 28th, 2005 09:38 AM |
| which manifold and exhaust system | gillsg | Engine & Drivetrain Tuning | 16 | May 30th, 2003 10:06 PM |
