| MINI2 Newbie Join Date: Mar 2006 Local Time: 11:35 AM
Offline | O2 sensor signal (High) wire.... which one? Looking for the 02 sensor signal wire... on the ECU side I have red,yellow,black, and black w/green.... on the sensor side I have 2 whites, a gray, and a black. I need to know for sure which is the one.... I would think that the two white ones would be the heater circuit.... which would leave the black and the gray. They line up with the yellow and the black on the ECU side, but opposite. Yellow goes to black and black to gray. Anyone? NFCooperS |
| MINI2 Master Join Date: Sep 2003 Local Time: 03:35 PM
Offline | That matches the Hanes pre-cat O2 sensor description pretty closely. It shows the following for O2 sensor pre-cat wires:
I'm going to GUESS the heavier wire (Black/Green) is the heater, but who knows? Get out a voltmeter and see. You should see a 0.0 Volt to 1.0 Volt signal. (Probably near 0.5 Volt when things are warmed up and running normally.) |
Offline | I had figured it out thanks.... went to Northamerican motoring and they backed up my guess. The black wire on the sensor/yellow wire on the ECU harness is the high signal path. I wanted to know for sure which one it was so I didn't have to splice/open a wire that I didn't want to. All hooked up and ready to go. For searching purposes, ignore: oxygen sensor wiring diagram schematic ecu air/fuel a/f gauge connection NFCooperS |
| Throttle Position Sensor Signal | Yellow/Black OneD | Engine & Drivetrain Tuning | 0 | Apr 30th, 2006 09:09 PM |
| Brake Light Sensor & Sensor replacement help needed | wrxtomini | Faults & Fixes | 7 | Apr 20th, 2006 08:55 AM |
| Connecting PIAA driving lights - Which wire is the high beam wire? | orbeamike | Exterior | 0 | Jul 22nd, 2005 05:52 AM |
| The green wire or red wire? | Sharkey | General Discussion | 2 | Nov 21st, 2003 12:39 PM |
| Vehicle Speed Sensor Wire | suprchrgdmini | Interior & Ice | 0 | Jan 4th, 2003 03:39 AM |
