Visit Lohen!
Old Jul 24th, 2002, 03:32 PM   #1
HarryHBMCC
HarryHBMCC's Avatar
Local Time: 08:42 AM
Question Why are 15" tires 175/65 instead of 185/15? Winter tire thoughts
The outer diameter of 195/55R16 is much closer to 185/65R15 than it is to 175/65R15. Does anyone know why they downsized the standard 15" tires?
I'm looking into winter tires (I know, a long way off but it's fun to plan). The only winter tires (almost only tires period) that I've found in 175/65R15 are Vredestein Snowtracs, which are T rated. In 185/65R15, Vredestein has both T-rated Snowtracs and H-rated Wintracs, while Bridgestone, Dunlop and Michelin only have Q-rated winter tires in that size. I don't know how often I'll be over 160km/h in the winter, if any time, but I'd prefer not to have Q rated tires if possible.
I know Dunlop SP Winter Sport M3's (H rated) are available in 195/55R16 so an alternative to getting 15" rims and tires would be to put some M3's on my existing rims, though I might worry about salt damage to my 5-stars.
I want a narrower tire for winter which makes the 175 Snowtrac attactive. By the time you hit 185 width, it is just 10mm narrower than 195, not really much of a difference.
Any thoughts?
Harry
Canada View HarryHBMCC's Hyper Blue & Dark Blue 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Jul 24th, 2002, 03:56 PM   #2 (permalink)
Apial
Apial's Avatar
Local Time: 02:42 PM
Send a message via MSN to Apial
I use 195/55 HR15s Michelin Pilot Alpins. They are brilliant in snow. I wouldn't worry about the width. Narrow tyres are good for cutting through the surface snow to the harder surface beneath. Thats a good idea for tread patterns not designed to grip on ice and snow. Wider tyres do not sink in so much. This is good if you don't want to bottom out. Best is a grippy tyre that doesn't sink.
I found out that driving 4x4s in extreme weather fitted with winter tyres, wider is best. The skinnier winter tyres used to give up once the snow had formed a wedge under the axle. This would leave me digging for 45 minutes to free myself. Some of the drifts I was driving through were rib height.
As far as grip is concerned the Alpins are truly remarkable.
It will be the design of the MINI that will be your Achilles Heel in the end. You can not expect a 2 wheel drive car of limited ground clearance to cope with the deep stuff, but you will be amazed at what it can do once shod with a decent set of snow tyres on depths of about 6 inches.
The only warning is that snow chains can not be fitted to sizes wider than 175. This will be relevant if in your area there is a legal requirement for them to be fitted on mountain roads. I can not comment on studded tyres as they are not legal for road use here.For my driving review of Michelin Alpin tyres click here.
United Kingdom Male View Apial's Chili Red & Body Color 1st Gen MINI One Diesel Profile   Reply With Quote
Old Jul 24th, 2002, 04:24 PM   #3 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Arrow
Thanks for the review of the Pilot Alpins.
I guess I didn't think about the chains. I guess that might be one reason to downsize the standard 15's though I don't know how often they'd be used in the UK. Here in Ontario, at least in the south, I don't think either studs or chains are legal anywhere that I go. I'm not a ski buff so I don't generally head to the mountains in the winter.
If I can go 195 width then there is a lot more choice in H rated winter rubber. More choices...
Harry
Old Jul 24th, 2002, 05:10 PM   #4 (permalink)
Red & White Cooper 2
Local Time: 01:42 PM
You've got the question the wrong way round! The car was originally designed for the 15" wheels and tyres. Run flats were added fairly late in development. The 195/55R16s are too big - the greater diameter of the 16" run-flats eliminates the lower ride height given by the sports suspension. Why did they upsize the run-flats?
Old Jul 24th, 2002, 05:53 PM   #5 (permalink)
ezrally
ezrally's Avatar
Local Time: 07:42 AM
Lightbulb
The only snow tyre around (at least N. America) in a 165/80-15 is a Nokian Hakka 09,nothing special in compound but is good in all conditions esp. deep snow.
I'm getting 185/65-15 Hakka Qs which are one of the best "studless" snows around, and are almost narrow enough for my personal taste. Check them out-search Nokian Tyres.
Good Luck!
Jet Black MCS
Lapis leather
17s or 15s (winter)
no DSC
United States View ezrally's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 24th, 2002, 08:39 PM   #6 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Arrow
Hmm, I guess I didn't think of it that way! I just know that every tire place recommends 185/65R15s for those 15" wheels so I wondered why the stock tires seemed to be the odd ones out. I guess 175/65R15 is just an odd tire size for north america; of course, 195/55R16 is pretty odd too but not nearly as odd as the 15's.
Harry
Old Jul 24th, 2002, 08:53 PM   #7 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Good Luck!
I don't think I quite want to go to 80 profile tires. I just traded in a Geo Metro on the Cooper; the Metro had 155/80R13's on it and I could practically feel the tires rolling over on hard cornering. 65 or 70 profile is about the most I'd want on this car.
It looks like Nokian has some T rated snow tires in addition to the Qs. The standard tires are H rated so I don't think I want to go as low as Q. The Hakka 1's come in 185/65R15 and 195/65R15, both T-rated, so that might be another good option. Hakka 10's come in 175/70R15, T-rated though they look pretty heavy duty.
Harry
Old Jul 24th, 2002, 10:24 PM   #8 (permalink)
ezrally
ezrally's Avatar
I'm sure the winter tyre discussion and opinions will pick up when the weather cools off!
I have Bridgestone Blizzaks (WS 50-old tread pattern) and those are the first "studless" snow tyres I've had. They were 4 for price of 2 at Sears at springtime a couple of years ago. A closeout deal I think, that was the reason why I didn't get the Hakkapeliitta (went out to the garage to check the spelling again) Qs
I always got by on 08s,09s or 1s thinking the studless would wear out to fast but they don't if you corner lightly on pavement etc.
Once you try the "studless" option you really won't want to go back to the old compounds. I guess it depends on how much true snow/ice driving you do!
Jet Black MCS
Lapis leather
17s or 15s (winter)
no DSC
Old Jul 25th, 2002, 07:52 AM   #9 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Arrow
Last year it didn't snow much at all and I just had (new) all-seasons. On light amounts of snow all-seasons are fine but on a few of the bad storms I kissed my (now traded) car's steering wheel when I reached my destination. A hill was totally iced up on one occasion and when I crested the top all I could see through the white-out was flashing red emergency vehicle lights by all the cars crashed into the guardrails. I pressed on the brakes but there was nothing, no stopping ability at all, which probably turned out for the best as the car went straight instead of spinning which is what happens if just one wheel got some traction (no ABS or anything on this car, just new tires and brakes thankfully). There was enough space to get by at the bottom of the hill so I made it but for a while I thought I would be getting some insurance money on that car instead of a trade-in value...
I will definitely put on winter tires this year!!! I just have to decide between H-rated performance winter tires or more serious winter tires with handling penalties; 175, 185 width or 195 width; separate 15" rims or just put Dunlop Winter Sport M3s or Blizzak WS-50's on my existing rims.
Harry
Old Aug 2nd, 2002, 07:50 PM   #10 (permalink)
azul68
Local Time: 05:42 AM
Does anyone know if I could put 205/16/15's on my standard Cooper rims? Snow is not a problem where I am. These are what BMW provided me for my 1997 318i with 8 spoke rims, but I'm not sure if they are wider. Anyone?
Old Aug 2nd, 2002, 09:55 PM   #11 (permalink)
Bilbo Baggins
Bilbo Baggins's Avatar
Local Time: 09:42 AM
You need to check with the tire manufacturer to see what rim widths that tire will fit. Look for their web site.
'06 MCS SB/S R84s(Dunlop 5000, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 2nd, 2002, 10:13 PM   #12 (permalink)
ezrally
ezrally's Avatar
Go to Tire Rack.com, they have everything about fitments etc, plus alot of choices for the MINI- very comprehensive site...
205s will fit, not sure if that would tech. proper though. I've got 135s to fit on 6" wide wheels (w tubes) in a pinch.
Jet Black MCS
Lapis leather
17s or 15s (winter)
no DSC
175/65-15 OEM Tires MINIAC Wheels, Tyres & Brakes 11 May 2nd, 2008 10:19 PM
Who has 17" winter tires fitted? Impressions? SLEEPER Wheels, Tyres & Brakes 9 Jan 12th, 2005 09:34 PM
Winter tires - Switching from 17" to 15"? Stolix Wheels, Tyres & Brakes 2 Nov 25th, 2004 11:35 AM
Winter Tires 205/45-17" without spikes imse2 For Sale 0 Aug 20th, 2004 03:58 PM
What size is a 175/15 tire? Dreamin Wheels, Tyres & Brakes 2 Jan 27th, 2004 08:30 PM
