FOMSPORT
Old May 14th, 2006, 06:30 PM   #1
fone
fone's Avatar
Local Time: 11:22 PM
What is this tube for ????
While cleaning the engine compartment, I notice this tube/hose was very loose and came off without even pulling hard. There is no hose clip. This is on a MCS. Questions :
1) What is this ?
2) Should it be tightly connected ?
Old May 14th, 2006, 06:43 PM   #2 (permalink)
Richard22b
Yellow Mini Man
Richard22b's Avatar
Send a message via MSN to Richard22b
1) What is this ?
thats the engine breather. connects to the induction.
Old May 14th, 2006, 06:51 PM   #3 (permalink)
fone
fone's Avatar
Thanks Richard22b for the info. Should be that loose ? Or it doesn't matter ?
Old May 14th, 2006, 06:55 PM   #4 (permalink)
minisoopercooper
Some have THICK skins!!!!
minisoopercooper's Avatar
Send a message via MSN to minisoopercooper Send a message via Skype™ to minisoopercooper
doesnt matter - even the classic minis were only ever loose
↑↑↑ - Click me for the event of the year. - ↑↑↑
United Kingdom Visit my Blog at the Motorcade Male View minisoopercooper's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old May 14th, 2006, 07:06 PM   #5 (permalink)
mph999
... but it should be attached, so you'd better put it back ...
Old May 14th, 2006, 08:11 PM   #6 (permalink)
MINIMANIAUK
MINI2 Sponsor
you will get a most annoying tapping sound if it loose fit
Old May 14th, 2006, 08:35 PM   #7 (permalink)
Richard22b
Yellow Mini Man
Richard22b's Avatar
no worries. happy to help. and like everyone said doesn't matter as long as it is attached. usualy most hoses have a clip just to hold it a bit tighter.
Old May 14th, 2006, 08:36 PM   #8 (permalink)
Richard22b
Yellow Mini Man
Richard22b's Avatar
while we're talking about hoses here's one im unsure about. what's the thick hose below that hose in the picture.
Old May 14th, 2006, 10:01 PM   #9 (permalink)
fone
fone's Avatar
Thanks everyone for the info !
Anyone ???
Old May 15th, 2006, 04:05 AM   #10 (permalink)
k-huevo
Trailer Trash
Local Time: 05:22 PM
The lower tube is the fuel line.
I see that this is an early model; if the hose on the PCV is pliable enough to remove easily it may need to be replaced. Exposure to oil vapor and engine heat can soften the rubber causing it to collapse under vacuum (if there is a good seal to begin with). If this is the case it will make an elephant noise when you let off the accelerator. The later vent hose is made of harder rubber than 03 & earlier.
United States Male View k-huevo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 15th, 2006, 05:14 AM   #11 (permalink)
discodan
Local Time: 06:22 PM
mine was replaced under warranty at the dealership. meaning the hose along with the PCV valve. there may be a service bulletin on this actually you should all check with your dealers.
United States View discodan's British Racing Green & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Intake Tube ID? macncheese Engine & Drivetrain Tuning 3 Aug 28th, 2002 09:33 AM
