| MINI2 Regular | Fidanza Lightweight Flywheel. Does anyone have one of these in their cars? I'm interested in one... does it actually make any difference. Also i thought the mini had something to hold the revs? |
| New Mini Specialists | We run a Fidanza flywheel on our Cooper S show car. You will definately notice the difference. The car becomes a lot more rev happy. Drivability does change with fitting this, because it is lighter you will have to give it more revs in order to pull off from stand still successfully, which isn't ideal if you only drive your MINI through city streets. If you require further information & pictures you can find it at this link below. http://www.lohen.co.uk/shop/products.asp?cat=85 If you have any questions let us know, if you would like to try it first you will be able to in our Cooper S in mid July time if you would like to visit. Cheers, Nick |
| | #10 (permalink) |
| MINI2 Senior | A lightened flywheel is great, but be aware that daily driveability will suffer a little, especially around town and on hill starts...if you go with an undampened clutch disk with the flywheel, expect some drivetrain 'chatter' when sat at the lights. It is less noticeable with the M7 flywheel, and louder with the lighter Fidanza for some reason. Just my take on the whole issue after having two cars with lightened flywheels. There's also a sensation of less torque at lower revs; this mod is primarily aimed at the track goer where the revs are kept above idle pretty much the whole way around the track (unless you end up in the kitty litter!) Cheers, Henry |
| | #11 (permalink) |
| MINI2 Regular Join Date: Mar 2005 Location: Nailsea Local Time: 09:34 PM
Offline | Yeah say all that again, don't get a solid clutch as you will be stalling very often, i now run a spec stage 2 clutch that is dampened, very good but it comes from the states so i got stung on custums and had to wait a long time for it.......just like everthing else i have now bought Anyway a helix clutch is another good combo with the Fidanza but remember to fit the Quaife when the box is out....a 16hr job in a standard garage was a joke so always better to leave it in for a very long time I also + my idle RPM 150rpm to help me pull away and idle nicely. I wish i got Roland @ GTT to do it, as it was a totally cr*p job in a small garage ![]() |
| | #13 (permalink) |
| MINI2 Regular Join Date: Jun 2005 Local Time: 10:34 PM
Offline | Hello I think it is a good modification ![]() The Differential Quaife ATB also wanted to put, but my dealer it does not know if it gives to "install" in my car… Which of the following options are more indicated: Fidanza Lightweight Flywheel with Helix Performance Clutch kit? OR Lightweight Flywheel John Cooper Motorsport with Race Clutch Plate John Cooper Motorsport? Then when it is placed Lightweight Flywheel is advisable to also put a better Clutch. Correct? Fidanza Lightweight Flywheel Lightweight Flywheel John Cooper Motorsport ![]() Helix Performance Clutch kit ![]() Race Clutch Plate John Cooper Motorsport ![]() Best Regards |
| | #17 (permalink) |
Offline | Hello Thanks for the reply´s. Flywheel JC -- £336.17 + VAT Flywheel Fidenza -- £349 + VAT The difference is minimum... Do you know if Race Clutch Plate JC gives to daily use or is only for track use? The JC Clutch is cheaper than the Helix. The difference is of £149.05, still it is well different. Find that the JC is an bad optionClutch? Thanks Best Regards |
| | #19 (permalink) |
| MINI2 Senior | Unfortunately there will be a little more noise when the clutch is engaged, but that is part of the experience. There won't be much extra vibration though, at least not with the M7 flywheel which is slightly heavier than the Fidanza. Cheers, Henry |
| | #20 (permalink) |
Offline | Hello Thanks for reply me supercoopers. I have my stock Flywheel and I already have this noise when the clutch engaged. It was substituted by my local dealer and the noise continues… Beyond this “problem” it does not have no inconvenience with the placement of Lightweight Flywheel? Somebody already tried the Flywheel of John Cooper Motorsport or has some information about it? Best Regards |
| Fidanza flywheel and OEM clutch | Fisher | Engine & Drivetrain Tuning | 0 | May 8th, 2007 08:18 PM |
| lightweight flywheel | chrisflyer | Engine & Drivetrain Tuning | 1 | Apr 12th, 2007 12:21 AM |
| Fidnanza Lightweight flywheel | supernegro | Engine & Drivetrain Tuning | 0 | Mar 30th, 2005 12:02 AM |
| lightweight flywheel anyone? | SteveS | Engine & Drivetrain Tuning | 20 | Jan 11th, 2003 04:54 AM |
| Aftermarket Lightweight Flywheel?? | Garfield | Engine & Drivetrain Tuning | 1 | Mar 26th, 2002 08:16 PM |
