Adam's Polishes
Old May 20th, 2006, 12:26 AM   #1
ScottishcooperS
ScottishcooperS's Avatar
Local Time: 04:39 PM
Fitted my GTT manifold (loads of pics)
Hello dudes!
Just bought a GTT manifold from supercharged99 anyway my mate and me
decided we would tackle fitting it ourselves instead of paying someone else to
do it, im glad we did it ourselves learnt alot!
The only trouble we ran into was due to the state of two rusty bolts that connected
the manifold the the exhaust! They just wouldnt turn and they were just falling apart
with ever touch! was pretty disapointing really! Anyway out came the grinder and
the drill, and they were then replaced with some lovely new STAINLESS steal
ones
Here are some pics of our adventure:
GTT manifold:
Old and new:
1 of 2 rusty bolts that caused havoc:
One of many techniques tried to overcome these:
Eventually out came the grinder: (dont try this at home)
My mate hard at work:
Cooper s over the pitt:
GTT sports cat, fitted:
GTT manifold in position before heat shield replaced:
Last min check before strut brace etc replaced:
What we had to do: (some of which unnecessary!)
Remove the following:
Strut brace
Heat shields
Coil pack
Lamba sensors
Standard manifold (Finally)
Then:
Replace all gasgets
Fit GTT manifold
Replace lamba sensors
Modify heat shield
Iv probably missed some of the things we did, has been a long day!
The results are very good, more responsive lower down and feels generally
quicker! the sound is lovely considering the exhaust is standard
Willie
a l t a - j c w - e i b a c h - u l t r a - g t t
m i l l t e k - s p e e d l i n e
Last edited by MINIAC : May 24th, 2006 at 06:36 PM. Reason: Picture Posting Etiquette
Old May 20th, 2006, 02:59 AM   #2 (permalink)
gowest
gowest's Avatar
Local Time: 12:39 PM
Not the prettiest header in the world but it looks very functional. Is the cat Stainless and what is the exit diameter? I wish the dollar exchange wasn't so bad now.
Good job on the install.
2001 & 2002 SCCA, STS Pro Solo National Champion. 2003 SCCA, Solo2 Nationals 8th, co-driver (Courtney) 2nd in 03 & 04
2003 JCW 210, London Stainless Headers, custom cat back with 5" SuperTrapp, 15x7.5 SSR's and 16x8 ce28n's, Quaife, KW Comp 2 Ways
Old May 20th, 2006, 08:23 AM   #3 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Local Time: 05:39 PM
Well fitted guys, ! We use a ground down 15mm ring spanner & loads of WD40.,so no need for grinding off anything (yet !).
Go West ... note this was a secondhand item. Check our website to view it when new . Its the only TIG welded one I know of.
Best Regards Roland GTT
Old May 20th, 2006, 11:02 AM   #4 (permalink)
ScottishcooperS
Scotland yup second hand.
Yeah this is a second hand item guys! yeah we did use loads of WD40, and tried
heating them up! Just wouldnt give.
My mates Dad is a qualified welder and the first thing he said was:
"Thats a quality piece of kit, the've used TIG welding intstead of MIG - very tidy!"
And he doesnt give compliments easily haha!!
Here is the GTT manifold Brand new:
Willie
Old May 20th, 2006, 11:14 AM   #5 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Any chance you'd be able to record how it sounds with the new Manifold?
Global Moderator
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 20th, 2006, 11:17 AM   #6 (permalink)
ScottishcooperS
Any tips on how i could go about doing that LMB? i'd be more than happy to
share
Old May 20th, 2006, 12:33 PM   #7 (permalink)
uncle albert
uncle albert's Avatar
Good job that man!
Very tempted myself, although worried it'll be a bit on the loud side with my Milltek cat-back. Plus I've got a few other mods lined up first.
James
England Male View uncle albert's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 20th, 2006, 05:03 PM   #8 (permalink)
ScottishcooperS
Quote: Originally Posted by uncle albert
Good job that man!
James
Cheers mate!
Im thinking of getting a milltek and im in the same boat, dont want it to be
too loud!
Been out driving in my car today and the manifold sounds amazing, really
love it!!
Willie
Old Jun 27th, 2006, 01:59 PM   #9 (permalink)
venox22
only the brave!
venox22's Avatar
Send a message via AIM to venox22 Send a message via MSN to venox22
well fitted, only just managed to keep the grinder at bay doing mine!!!
One point, on mine there was about a 10-15mm gap between the cat-flange and exhaust centre pipe flange, when bolting the two together(with manifold bolted on at the head and the exhaust in its fixed position) i just used the 2 bolts to pull the exhaust and manifold together, did you have this problem???
Not sure if i will be causing extra strain on the manifold flex part??? Should i re-drill the exhaust centre mount plate so that there is less strain on the whole system??
United Kingdom Male View venox22's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 27th, 2006, 02:37 PM   #10 (permalink)
TallAndy
Taller Than You!
Send a message via ICQ to TallAndy Send a message via MSN to TallAndy Send a message via Yahoo to TallAndy Send a message via Skype™ to TallAndy
Whats your cat-back exhaust system? Mines JCW!
I had this exact same problem approx a 1cm gap we ended up using a flange spacer as tighening would put way too much stress on the flexi joint, possibly damaging it.
England Male View TallAndy's Chili Red & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Jun 27th, 2006, 03:16 PM   #11 (permalink)
venox22
only the brave!
venox22's Avatar
yeah mines a JCW cat back to
Think thats what i going to do then, where did you get the flange spacer??
Old Jun 27th, 2006, 03:22 PM   #12 (permalink)
TallAndy
Taller Than You!
I got mine from Lohen £6 i think...
I believe GTT also have them
Old Jun 27th, 2006, 03:47 PM   #13 (permalink)
venox22
only the brave!
venox22's Avatar
ok cool thanks for that!!
Old Jun 27th, 2006, 03:54 PM   #14 (permalink)
MiniBimmer
MiniBimmer's Avatar
Hello
Excellent work
You noticed much difference in the course of the car?
Best Regards
Portugal   Reply With Quote
Old Jun 29th, 2006, 06:37 PM   #15 (permalink)
ScottishcooperS
Hello,
Thanks mate. yeah i noticed a fair bit of difference, the manifold is off the car just now
as im getting warrenty work done, and iv noticed a big difference since taking it off
the car!
Willie
Old Jun 29th, 2006, 07:03 PM   #16 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Quote: Originally Posted by ScottishcooperS
Hello,
the car!
Willie
Think they'd notice?
Global Moderator
Old Jun 29th, 2006, 08:20 PM   #17 (permalink)
ScottishcooperS
The exhaust hanger snapped so i was'nt giving them any excuses not to fix it,
they would have just said you've been tampering with the exhaust so we aint fixing
it.
the car is back and all fixed free of charge so im gonna put heat wrap on the
manifold then put it back on.
Old Jun 29th, 2006, 08:51 PM   #18 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
it.
Wise move then.
Global Moderator
Old Jun 29th, 2006, 09:00 PM   #19 (permalink)
venox22
only the brave!
venox22's Avatar
yeah definatly more than just a sound difference, one of the best things i brought. Gonna go for the GTT JCW airbox upgrade next me thinks!!
Quote: Originally Posted by MiniBimmer
Hello
Excellent work
Best Regards
Old Jun 30th, 2006, 09:14 AM   #20 (permalink)
MiniBimmer
MiniBimmer's Avatar
Hello
Thanks for reply.
I´m thinking put 4-2-1 Sports Manifold + Intermediate CAT Pipe John Cooper Motorsport. In your opinion it is a good choice?
But first I go to put GTT JCW airbox
Note:I have Kit JCW 210Hp
Best Regards
GTT Manifold V JCW Motorsport Manifold chrisflyer Engine & Drivetrain Tuning 24 Sep 26th, 2007 03:14 PM
GTT CAI and Manifold fitted Sound Clip blaze1235 Engine & Drivetrain Tuning 13 Dec 7th, 2006 06:00 PM
Fitting GTT Manifold Help !! blaze1235 Engine & Drivetrain Tuning 11 Nov 14th, 2006 10:13 PM
## GTT manifold ## supercharged99 For Sale 8 May 6th, 2006 11:52 AM
