GizzmoUSA
Old May 29th, 2006, 05:35 AM   #1
BlueMax
BlueMax
Local Time: 11:06 AM
Unburnt fuel or oil spatter?
I drive an 04 MCS with the JCW kit installed 2 months ago (car has only done 18000 km). The engine is wonderfully response, smooth and sounds fantastic. I nursed it for the first 1000km's but have been close to redline on a number of occasions after "run-in". I am running it on 95 RON unleaded only (for about a month now, before that 93 RON unleaded which was the highest available rating at the time). A while back I noticed quite a few little black spots on the rear of the car but knowing how easily the rear end becomes dirty I washed the car and though nothing of it. It happened again and I wondered what I had driven through but after cleaning it the weekend and driving a short distance, the black spots were back again. I rubbed it with my finger and it was still wet. It seems to be a fine spatter of unburnt fuel or maybe oil. The insides of the exhuast tips and pipes are dry. I checked the oil level and it has not been overfilled. The correct spark plugs, injectors and ECU software have been installed. Anyone else have this problem?? Any comments/ideas? It never happened before the JCW install.
South Africa View BlueMax's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 29th, 2006, 07:19 AM   #2 (permalink)
Westy
Blackpool Rock
Westy's Avatar
Local Time: 10:06 AM
The main components coming out of your exhaust are CO2 & water vapour. Is it just water droplets with carbon soot in suspension?
Old May 29th, 2006, 08:31 AM   #3 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Local Time: 07:06 PM
Send a message via MSN to St00ge
sounds like oil. When you wipe it off the back, does it feel greasy?
You can get oil out the back if you have a leaking head gasket
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old May 29th, 2006, 08:41 AM   #4 (permalink)
brett
1st MINI Owner in QLD !!!
brett's Avatar
If you had unburnt fuel going out your exhust, you would have a flame going out the back. like the V8 Supercars do. Which would be great
1968 Mk1 Morris Cooper S 1310cc Downton Lake Green - White
1974 Leyland Mini 1098c Country Cream
2008 MINI Cooper S Chilli Pepper White - Black Roof
Australia View brett's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 29th, 2006, 08:43 AM   #5 (permalink)
St00ge
St00ge's Avatar
all MCS's get unburnt fuel in the exhaust, that's wat causes the popping noise.
Old May 29th, 2006, 11:45 AM   #6 (permalink)
BlueMax
BlueMax
Have any of you experienced it on your MCS's? The spots/specks are so small (pinhead size 0.5 - 1.5mm diameter) that it is difficult to establish if it is oil or lets rephrase - partially burnt fuel? Also the fact that the pipes are not at all oily makes me perplexed. I have also though about carbon soot being a possibility but how do I determine what it is exactly. It is not as if there is a huge black spray following me or smoke.I cannot see it being the head gasket - the exhaust manifold bolts to the cylinder head and the passages run to the valve holes. A leaking head gasket will not cause oil to get into the exhaust manifold are am I missing something? A leaking valve stem seal my cause it, but then again it is a brand new cylinder head??
Old May 29th, 2006, 03:43 PM   #7 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Only thing I can think of to determine if it's the exhaust is to put a rag over the exhaust and rev it up to see if you can get the same deposits on the rag.
Only way to tell what it is would be is to get it analysed I guess?
It was acceptable in the 80's
Old May 29th, 2006, 03:50 PM   #8 (permalink)
BlueMax
BlueMax
Will try that Root Ginger, good idea. It is very strange, at the moment it is slightly annoying, as long as it is not the sign of something bad to come. Wonder if blipping the throttle for the fun of it may have something to do with more "popping" fuel going through the exhaust?! Been blipping quite a lot since having the Works installed.
Old May 29th, 2006, 04:00 PM   #9 (permalink)
Root Ginger
Can't say I've ever heard of this problem before and I'm sure it would of come up. I've got a black Hartge S so wouldn't have seen any spots I guess on the dark body work.
Old May 29th, 2006, 04:01 PM   #10 (permalink)
Root Ginger
Just had a thought, do you use any gel or spray on the tyres?
Old May 30th, 2006, 11:39 AM   #11 (permalink)
BlueMax
BlueMax
I am not using any tyre gels or sprays, hate the way it slings off. I am not doing anything different than before the JCW install. I plan to try the rag idea tonight. I really do not think it is oil, a leaking piston ring will be noticable and will result in smoking and oil in the pipes I reckon. I am going to pull the spark plugs to see if there is some deposits on them. Interestingly I built an aircraft (my other toy) using a Rotax 100HP fourstroke engine and I have similar specks on the airframe/undercarriage area in the vicinity of the exhaust exists. Maybe we have crap fuel in South Africa. Been running 93RON unleaded on the aircraft engine. Thought I would get more views on this issue in this forum?
Old May 30th, 2006, 11:53 AM   #12 (permalink)
Westy
Blackpool Rock
Westy's Avatar
Do the spots dry or stay wet? If they dry then they will be water or fuel based, if they don't evaporate & stay wet then they will be oil.
Old May 31st, 2006, 05:15 AM   #13 (permalink)
BlueMax
BlueMax
The spots are easy to remove when still "fresh". Even fuel takes a while to fully vapourize. When left on for about 2-3 weeks I had to use a clay bar and polish to get some of it off. Normal water and car wash did not remove it. My feeling is it is fuel based. I am going to have a good look this weekend at anything that may cause this and report back on anything found.
Old May 31st, 2006, 05:33 PM   #14 (permalink)
Mike Edwards
Mike Edwards's Avatar
I get these on the viper stripes on my car - they don't come off. Seems to be soot.
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 1st, 2006, 03:41 AM   #15 (permalink)
Eds
Local Time: 03:06 AM
I noticed a very light amber stain (like a nicotine color) at the exhaust tip after I had my Shark Injector installed and moreso after hard runs. It is not wet though and I would classify it only as slightly soothy and thin. I guess it is because of the fuel enrichment made by the upgraded ECU.
Eds
Canada   Reply With Quote
Old Jun 1st, 2006, 05:27 AM   #16 (permalink)
BlueMax
BlueMax
I think the consensus is soot. We have only had 95RON fuel available for 3-4 weeks where I live and I have been using BP. Will be trying out Shell on my next tank due for fill-up by the weekend and see if this makes a difference. Never know what additves the various fuel companies use to up the octane rating. Issue may also be related to the bigger bore JCW tailpipes and the airflow around them as opposed to the std beer can shape. Mechanically there is nothing wrong with the car. Very happy with the JCW!
Old Jun 5th, 2006, 06:01 AM   #17 (permalink)
BlueMax
BlueMax
Did a systematic check over the weekend on the parts that were affected by the JCW installation. All spark plugs are correct and do not show any strange deposits. All wiring connections and injector installation seems fine. Very little oil in the intercooler flanges. I did find two bolts not properly tightened on the exhaust manifold and one bolt was missing altogether, do not know if it was not fitted or was loose and fell out? Installed a new bolt. Do not know if the ECU enriches the fuel mixture if there is a leak at the exhaust manifold.I also filled up with Shell 95. Still got some specks after some short drives over the weekend but subjectively it seems to be better. Will monitor it this week and plan to go to the dealer on Friday if the problem persists - and also give them a piece of my mind about the missing bolt.
Old Jun 5th, 2006, 04:20 PM   #18 (permalink)
St00ge
St00ge's Avatar
hope it all gets sorted out for you mate....
Old Jun 6th, 2006, 05:16 AM   #19 (permalink)
BlueMax
BlueMax
Thanks. I will post if a solution is found - hopefully soon!
Old Nov 1st, 2006, 12:52 AM   #20 (permalink)
Mr.Pedro
Send a message via MSN to Mr.Pedro Send a message via Yahoo to Mr.Pedro
Unhappy hhmmm..darn!!!
Man...i'm not sure though, i can see oil spots near the head gasket(like a leakage) all over the pully area too..it's black spots (plus checked the engine oil it's really black!!! being that it's juz been serviced recently. Adding to that, i got my jcw tuning kit fitted before 2500km(straight from the mini garage here in Melb wen i first bought it)...
Really curious, man..please, in need of some advice from u guys(expert) i have very little knowledge in this particular area..
Cheers.
Reputable & affordable place to get my oil/oil filter changed spmprnl MINI Cooper S 1 Feb 12th, 2007 03:39 PM
No oil 440 miles after 1st oil service!! lightbody Faults & Fixes 17 Mar 21st, 2006 07:17 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
Fuel Injectors and Fuel Pump NearlyNN Engine & Drivetrain Tuning 19 Jul 19th, 2004 03:56 PM
Revs, fuel consumption, oil use??!! Help Cooper drivers Richard Crofts General Discussion 2 Sep 18th, 2003 12:15 PM
