Mini Pirate
Old Jun 10th, 2006, 11:58 AM   #1
Maaij
Local Time: 10:38 PM
Pilot Coil Pack with stock plugs?
Hi,
I have got a Screamin Deamon Ignition Coil Pack with Magnecor Plug Wires, Red 8.5mm.
I was planning to get a set of Denso Iridium Spark Plugs (IK20). But MTH said they dont recommed me to instal these plugs. They said its very dangerous if I use it on my MINI. It will damage my car (about getting holes in the pistons because of the higher combustion heat). They said the Denso is designed for the US market and not for the European (because difference in fual quality. I use RON98/100 fuel).
Now I want to install the Screamin Deamon Ignition Coil Pack with Magnecor Plug Wires with the stock plugs.
My question: Is this possible without any risk for my MINI?
Netherlands   Reply With Quote
Old Jun 12th, 2006, 03:09 AM   #2 (permalink)
asinn
Local Time: 07:38 AM
Australia
i am using the IK22 plugs + the screaming coil and spark plug wires..... the car have been good... no major problems.....
the IK22 plugs suppose to be colder (its transfer heat faster) so it is opposite to what the guy told you.
regards
Alfred
Australia   Reply With Quote
Old Jun 12th, 2006, 05:25 AM   #3 (permalink)
n00b
Twincharge???
n00b's Avatar
Are you running a pulley? If you're then IK22 will be a better choice but it won't necessarily hurt your engine by running slightly hotter. This once again shows how knowledgeable MTH can be at times....aren't all plugs made the same?
In order to crack your pistons, surely it will take a lot more than a IK20 and a bad batch of fuel...or perhaps a wrong fuel map will be capable of?
Old Jun 12th, 2006, 08:22 AM   #4 (permalink)
Maaij
I have a normal Cooper (nonS) So no pully
Maby it has something to do about the MTH fuel map?
Advice on Ignition Coil Pack Aberdeen Al MINI Cooper S 2 Nov 18th, 2006 11:01 PM
Rusty / oxydized connectors on 3 & 4 coil pack. camini Faults & Fixes 4 Aug 10th, 2006 12:31 PM
40,000 Volt Ignition Coil Pack Billy Smart Engine & Drivetrain Tuning 6 Mar 7th, 2006 04:46 AM
Upgrading the Coil and plugs USACOOPER-S MINI Cooper S 6 Aug 26th, 2004 05:01 PM
Installed new HO coil and regapped my plugs obehave Wheels, Tyres & Brakes 3 Apr 27th, 2004 01:21 AM
