| Cooper S Owner Join Date: May 2006 Location: New Jersey Local Time: 05:45 PM
Offline | TwinCharging my Mini Just wondering if it is smarter just to buy the Alta "Twurbo" kit, or attempt to custom fabricate my own. I have the skills to do it I just dont know if its really worth my time and energy to go through all of the measuring and cutting and welding to get the job done right. My guess is that custom fabrication would be cheaper, the only problem is that my car would be out of commision for a long time. versus paying the 3600 for the "Twurbo" kit, installing it myself (which would still take at least a weekend) I dont know if the price difference is really worth it. What do you guys think? ![]() ...::::Johnny Rocket::::... ![]() |
| Sing-a-long MINIer Join Date: Jan 2004 Location: Hampshire Local Time: 09:45 PM
Offline | Personally I don't have the skills to produce a turbo kit, so I would purchase one should it be the sort of thing i was after. Pro's of building your own:
Your choice though of course... and good luck with what you decide ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| MINI2 Master Join Date: Mar 2005 Location: Reading Local Time: 09:45 PM
Offline | I thought twincharging was REALLY expensive. $3800 for the kit, plus at least a bigger intercooler. Anyone know how much fitting would be? Surely can't be that much. Not that I'd do it anyway. Not yet. Can't justify it. No. Must resist. Maybe in a few years though... edited - OK, just read another post. New gearbox in there as well if you want to go over about 250bhp, which would cost a stack, and various other engine mods. Someone quoted £7k ish in the other thread. That's a lot of cash! Wish i had the knowledge to work on my own car. ![]() |
| YozzaSport Clio Vs1.2 Cup | but when you do something like this you do it with the intention of making a car that much quicker than standard that you have to uprate lots of other components. If someone was serious about modifying a car that much then you are already aware of what needs uprating, so £7,000 would be about right for: Engine Mounts Engine Pipework The Twincharger Kit The ECU The Loom The Fitting The Dyno/The Mapping The Clutch Stengthening the box The Flywheel Exhaust System etc... etc... it all adds up quickly When you have the completed package there is absolutely nothing that can prepare you for the missile like performance and there is nothing like over taking supercars in something that is seen as a hairdressers car or a shopping trolley. trust me... /y0z |
| | #7 (permalink) |
Offline | Well yeah... here was my plan so far... :::::::::::::::::::::::::::::::::::::::::::::::::: ::::::::::::: Engine Upgrades Stage 1 - Cold Air Intake: Custom Fabrication - Throttle Body $479 - 15% Supercharger Pulley: $139.95 o Stock Pulley Removal Tool Rental $1.00 w/ $100.00 Deposit - Short Shift Kit: $89.95 - Plasma Booster (For better spark): $269.95 - Performance Spark Plugs: $5.95/ea to $14.95/ea - Exhaust System: Invidia or Borla : $400 to $800 - Red Nology Coolwires Spark Plug Wire Set: $104:55 o Or Red Nology Hotwires Spark Plug Wire Set: $199.00 Stage 2 - Oil Catch Can: Custom Fabrication - Ultrik Stage 2 Cylinder Heads: $2495 - Cylinder Head Gasket & Head Bolts: $249.95 - Performance Cam Shaft: $399.95 to $579 - Ultrick Performance Valve Set: $359 Stage 3 - 380cc to 420cc fuel injectors: $113/ea. - Light Weight Crankshaft Pulley: $209.95 - Light Weight Aluminum Fly Wheel: $499.95 - Ultrik Water-To-Air Intercooler: $1795 - Stage 2 Performance Clutch Kit: $449.95 - Intake Manifold: Custom Fabrication - Exhaust Manifold: Custom Fabrication - Down pipe: Custom Fabrication - Garrett T3/4 Turbo: $170.00 to $400.00 Suspension Upgrades - Bilstein/H&R Shock, Springs, & Swaybar Kit: 958.75 Not So Optional Upgrades - Promini Instrument Console (Boost and other) 475.95 o OR Custom install the boost gauge into the dashboard: Cheaper - Aquamist system - ECU Upgrade to compensate for higher boost - Bigger drilled & Slotted brakes & Calipers Optional Upgrades - Interior work - New Sound System - GPS Navigation - Carbon-Fiber Dash Components ...::::Johnny Rocket::::... ![]() |
| | #13 (permalink) |
| MINI2 Newbie Join Date: Oct 2004 Location: Bremerton, WA, USA Local Time: 02:45 PM
Offline | I'm looking into the Alta kit at: http://www.jscspeed.com/mini/mini_ba...it_coopers.htm Has anyone installed this kit yet and what type of performance gains have you seen (this web site claims up to 400 HP). Also, would the Alta kit above be "safe" for the car, or should additional parts be installed to be up-to-par with the upgraded parts (right now I have a MCS, JCW 195 & 210 Kits, JCMS Cat Pipe and Manifold, Dinan Cold Induction Filter). - Jeremy P. Seda - Bremerton, WA U.S.A. |
| | #14 (permalink) |
| MINI2 Newbie Join Date: Sep 2003 Location: Dover Local Time: 05:45 PM
Offline | If you BUILD the engine, the kit can produce up to 400hp. I was told that the internals would have to be beefed up if you get around the 275-300hp mark. Alta claims approx 220-230 wheel hp out of the box. Im planning on getting the kit. My plans are install the kit, get a Turbo timer, Electronic Boost Controller then a Apexi SAFC. I would like to run about 18-20 lbs, but was told I would need bigger injectors, and a fuel pump. |
