Performance Torque
Old Jun 15th, 2006, 12:26 PM   #1
Lohen
New Mini Specialists
Lohen's Avatar
Local Time: 09:42 PM
Send a message via Skype™ to Lohen
NEW TO LOHEN! Wossner Forged Pistons
Just released and now available to buy online or have fitted as part of a custom package: Wossner forged pistons.
If you are pushing the limits of the engine with higher boost or more compression then you will probably need to upgrade the pistons to forged items. These psitons are able to withstand more heat and have teflon coated skirts. They are available in standard bore (77mm) dimension and .5mm oversize (77.5mm). The kit comes complete with oil and seal rings, fixed pins and is a direct replacement for the standard items. Please see our website for further details here.
Priced at £499 inc.vat for a set. Available for the MINI One, Cooper & Cooper S.
Click Here To Visit Out Website
New MINI Specialists
www.lohen.co.uk
Old Jun 15th, 2006, 01:37 PM   #2 (permalink)
AndyH_MCS
AndyH_MCS's Avatar
Are you introducing new rods? Or are the standard items up to the task? What sort of boost pressure would warrant changing the pistons?
United Kingdom Male View AndyH_MCS's Electric Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 15th, 2006, 02:10 PM   #3 (permalink)
Rickys'S
Rickys'S's Avatar
The standard rods are good for serious power, just change your rod bolts,head bolts and head gasket.
ARP for the hardware and Cometic for the head gasket!
The Wossner Pistons from lohen are very good , but no need in changing them unless you run mega boost, maybe a twincharge system or a very small S/C Pulley
Old Jun 15th, 2006, 02:23 PM   #4 (permalink)
Hyper Active
Hyper Active's Avatar
Online
Quote: Originally Posted by Rickys'S
Our standard rods are good for serious power, just change your rod bolts,head bolts and head gasket.
Pistons are very good idea for more than 19-22 P.S.I of boost, but no matter what piston you have nothing is going to put up with loads of pinging (detonation)
Why don't you give it a REST for CHRIST SAKE . Your 2 pennies worth ran out long ago.
England Male View Hyper Active's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 15th, 2006, 02:41 PM   #5 (permalink)
Rickys'S
Rickys'S's Avatar
Hey steady,
Ive not had a go at anyone on this thread, I agree with Lohen totally about the pistons and they look very good
If i was to have a dig i would go to the correct thread!
Just Answering to a question asked wether our Rods need replacing!!
Im not sure if you Know, but a connecting rod is different to a Piston
Also i was helping rather than having a go
If this has got on your goat then i will delete my post, sorry for helping
Old Jun 15th, 2006, 03:16 PM   #6 (permalink)
AndyH_MCS
AndyH_MCS's Avatar
Don't delete the post. You have answered my question.
I was wondering if it is worth someone with mild mods (230bhp) changing to uprated pistons?
Would the pistons change the CR?
Old Jun 15th, 2006, 03:37 PM   #7 (permalink)
supercoopers
supercoopers's Avatar
Geez, living up to your screename perhaps?!
In all seriousness, Ricky is only trying to help. He has a load of FIRSTHAND experience about tuning the MINI and is not a keyboard jock. He has spent alot of his own money doing things that most only dream about. Both him and I have done the whole hog on the supercharged engine and are now moving onto ridiculous power domains where upgrading the rods is a serious consideration.
He is right about the standard rods, but being a scintered design, I would change them out if you are going to run 25psi+ I've gone with custom Crower rods, but that's because I don't want anything to let go at 8,500rpm+ when running stupid power
Cheers,
Henry
Old Jun 19th, 2006, 11:17 AM   #8 (permalink)
Lohen
Lohen's Avatar
Hi,
It is probably not worth you changing to forged pistons at the moment, due to the cost involved and all that you dont really have a demend for them. The compression ratio remains the same as they are a direct replacemnt for the stock items.
Andrey
www.lohen.co.uk
who is the cheapest for wiseco pistons? fozworth Engine & Drivetrain Tuning 1 Mar 25th, 2007 11:09 PM
Pistons/Rod bolts? Rickys'S Engine & Drivetrain Tuning 7 Jun 24th, 2005 01:31 AM
Where to get larger pistons for the S 911ETR Engine & Drivetrain Tuning 20 Nov 19th, 2003 01:12 AM
