Carccessory.com
Old Jun 16th, 2006, 01:38 AM   #1
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Local Time: 09:40 PM
What diameter is the supercharger pulley? And reduction pulleys?
I wanted to check what size supercharger pully I have on my Hartge MCS. I think it's a 15% pulley but I know that the conversion has been messed with further by the previous owner so I want to measure the pulley.
I've looked at some previous threads but couldn't find the info I needed. So what diameter is the stock pulley or what size would a 15% pulley be in mm please.
It was acceptable in the 80's
England Male View Root Ginger's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 16th, 2006, 01:44 AM   #2 (permalink)
Root Ginger
OK. From another bit of searching I think stock SC Pulley is 138.4mm.
Correct?
So a 15% reduction would be 117.64mm. Right?
Old Jun 16th, 2006, 01:52 AM   #3 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 01:40 PM
Online
Stock pulley is 2.58" ~ 65.5mm
Crank pulley is 5.46" ~ 138.7mm
Old Jun 16th, 2006, 01:58 AM   #4 (permalink)
Root Ginger
Ah cool. Glad I asked as I was thinking those measurements didn't add up.
Old Jun 16th, 2006, 01:59 AM   #5 (permalink)
Root Ginger
OK so a 15% pulley would be 55.7mm then. Correct?
Old Jun 16th, 2006, 02:07 AM   #6 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Online
Approximately
Old Jun 16th, 2006, 02:17 AM   #7 (permalink)
Root Ginger
It amazing when you work it out that there is only around 2.5mm difference between 15% and 19% reduction pulleys. Best get my vernier caliper out...
Old Jun 16th, 2006, 07:58 AM   #8 (permalink)
minti
minti's Avatar
Local Time: 11:40 PM
Charger Pulleys
Charger Pulleys:
due to my limited knowledge, with no warranty for correctness (dimensions are outer diameter in mm):
Cooper S stock: 65mm (belt 6PK 1388)
JCW & Kelleners(11%): 58,2mm (belt 6PK 1370 (oder 6PK 1374 ?))
Digitec(DT) & RMS: 57mm
Hartge &
hitec incl. MTH(13%): 56,5 mm
Minimania 15% (Ultrik): 55,6 mm
Alta (15%): 55,5 (belt 6PK 1370)
GTT 17%: ?54?53,2??
GTT 15%: 55,8mm (belt 6PK 1365)
Schäfer: 54mm
Alta (19%): 52,5 mm ??? (belt 6PK 1352)
M7 (16%): ?????
MCS JCW MTH GTT Alta H&R Bilstein
Germany   Reply With Quote
Reduction Pulleys... MiniLover247 Engine & Drivetrain Tuning 2 May 21st, 2006 05:58 AM
supercharger pulley reduction K9HNY MINI Cooper S 7 May 4th, 2006 05:24 PM
