Visit Lohen!
Old Jun 19th, 2006, 02:46 AM   #1
MNIMGK
ICMINI
MNIMGK's Avatar
Local Time: 09:22 PM
Intake Hose
Could this shape be used to replace the intake pipe
Australia View MNIMGK's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 19th, 2006, 02:57 PM   #2 (permalink)
obehave
Mini Mod
obehave's Avatar
Local Time: 05:22 PM
Very much depends on how flexible it is. MIght be possible but you would also have to add a inlet point for your PCV hose.
Old Jun 19th, 2006, 03:10 PM   #3 (permalink)
Scott G
Scott G's Avatar
Local Time: 10:22 PM
I was thinking about this myself as the std one must have the airflow characteristics of an accordion.
It might be worth speaking to Roland at GTT who did something similar by producing the replacement snoot boots? (just an idea)
England   Reply With Quote
Old Jun 20th, 2006, 04:15 AM   #4 (permalink)
Baker
Being normal is not fun!
Baker's Avatar
Local Time: 07:22 AM
Or, if you're not bothered about legality, you can add a little filter on the end of the PCV hose (as there is the possibility of *slight* vaccum there under some conditions), and vent the PCV to the atmosphere.
Australia Male View Baker's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 20th, 2006, 01:09 PM   #5 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi Guys, at idle & overrun there is alot of suck through the PCV valve ,use our OCC on this circuit. You can use a breather filter on the other connection of the cam cover though. Dont forget to plug the hole in the intake hose if you do though!
The stock intake hose does have 2 advantages over aftermarket ones that I can see;-
1) It has a step on the bore at each end. This step coincides with the parts it clamps to ,meaning there is no step inside (good) as they cancel each other out. With non stock hoses it steps down as the air enters the TB (not so good)
2) The ribbed reinforcement on this hose is there to prevent it imploding (collapsing) under WOT at full rpm. A restictive intake system will result in a negative pressure in this hose under these conditions. It doesnt take much negative pressure to get a hose to suck in. Youll never know its happening unless it completly collapes, the engine then just stalls (TT's can do this if chipped ).Of course partial collapsing = losing power as the restriction then becomes even greater. See our airfilter test thread for more info. Re-inforced ribbed hoses are still best for induction hoses IMO
Best Regards Roland GTT
Old Jun 20th, 2006, 02:07 PM   #6 (permalink)
obehave
Mini Mod
obehave's Avatar
Bear in mind the OEM hose is only ribbed on the outside. The ID of the tube is smooth.
Old Jun 20th, 2006, 04:01 PM   #7 (permalink)
roland2003
Good point obe, the best hose for the Mini I'd say holy smoke and its made by BMW
Old Jun 21st, 2006, 12:37 AM   #8 (permalink)
MNIMGK
ICMINI
MNIMGK's Avatar
Intake Hose
Hi guys thanks for your response. Just a quick question Roland, by fitting a breather filter to the connection of the cam cover and not having the normal hose running from it to the intake will this effect the cars engine in a negative way.
I have also attached a little picture of how i think it would hook up, please could you tell me if it is correct. Also i am looking at hooking up an oil catch can and i have also attached a pic of how i think it hooks up could you advise me on if it is correct.
Thanks Heaps
Perry
Old Jun 22nd, 2006, 12:08 AM   #9 (permalink)
alta2
In response to some questions people keep asking about the intake hoses on our intakes.THEY DO NOT COLLAPSE AND NEVER HAVE! Our silicone hose is very thick and is stiffer than the factory rubber hose by a small amount. Secondly there are gains to be had by the hose. Below are graphs of runs on a car from stock-ALTA panel-ALTA intake no hose-ALTA intake with hose.
This is real data not made up by anyone.
Regarding the breathers, since the ECU is a speed density type of ECU venting that to atmosphere is never going to hurt performance. The only thing bad it does is possibly make mess of the oil coming out of it, put these bad emissions in to the air.
Old Jun 22nd, 2006, 08:01 AM   #10 (permalink)
Joker
watchalookinat
Joker's Avatar
Local Time: 01:22 PM
oh oh! looks like things might get cleared up now(silicone hose collapse/failure) hello Jeff, fancy seein' u here.....
.................................................. ........///g0t PETR0L !? :o(
My boltz require more torque than ur Honda makes.........BUY a VW! .
xx03
Colombia   Reply With Quote
Old Jun 23rd, 2006, 10:07 AM   #11 (permalink)
roland2003
..Didn't know Alta were a Mini 2 sponsor??
Guys The PCV valve to SC inlet hose should have the OCC in its path. The other connection at the other end of the rocker cover can have a breather filter on it (going to the cam cover side ). Block off the hole in the induction pipe though.
Do not connect both into one oil catch can;you will collect mostly water! (condensation) . Check out our website for info on our GT Tuning OCC and why it works.Venting the PCV valve hose to atmosphere although not effecting mixture does effect throttle position at idle . Specifically it need to close more to maintain correct idle,this can make it a bit jerky,as is already almost fully closed
OEM Intake Hose Clamp MAD Always Engine & Drivetrain Tuning 3 Jun 22nd, 2007 11:59 PM
Removing air intake hose in order to fit cold air intake system Spoony Engine & Drivetrain Tuning 7 Jul 29th, 2005 02:41 PM
Alta Intake vs. BMP/Promini Intake jm6001 Engine & Drivetrain Tuning 6 Aug 28th, 2004 08:34 PM
Hose measurement on Throttle body intake? Silver "S" MINI Cooper S 1 Sep 1st, 2003 11:09 PM
MCS air intake hose diameter? Slant Engine & Drivetrain Tuning 5 Mar 8th, 2003 12:07 AM
