Visit Lohen!
Old Jul 15th, 2006, 10:51 PM   #1
herbie hind
Local Time: 05:39 PM
what plugs?
okay who likes what plugs for the "s" ? ngk? denso? comments please it's almost that time .
Old Jul 16th, 2006, 03:41 AM   #2 (permalink)
obehave
Mini Mod
obehave's Avatar
Local Time: 04:39 PM
I have the Denso Iridiums.
They've done well.
Old Jul 16th, 2006, 03:43 AM   #3 (permalink)
herbie hind
cool thx
Old Jul 16th, 2006, 07:34 AM   #4 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Local Time: 07:39 AM
Send a message via MSN to St00ge
i have the denso ik22s. Its been about 4000km of hard and easy use, and they've been fine...
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old Jul 16th, 2006, 10:39 AM   #5 (permalink)
Baker
Being normal is not fun!
Baker's Avatar
I had a set of Denso Iridium IK-22's, but when I recently had a problem where I blew a plug through the head I had to get some plugs ASAP, could not get stock of the IK-22 so now I'm running the NGK Iridium, the same as they run in the JCW conversions.
Australia Male View Baker's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 16th, 2006, 03:01 PM   #6 (permalink)
herbie hind
was it due to plug failure? hope all is well now
.thx.
Old Jul 16th, 2006, 07:38 PM   #7 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Local Time: 10:39 PM
I don't want to get sued, so this is pure hearsay.
I have heard that Denso Iridiums MAY cause problems with blown plugs, as per the post from Baker.
So it my own personal opinion and with no proof that NGK are better than Denso, that I would personally prefer the NGK Iridium plugs. I would personally hate to run the risk of a blown plug, of any manufacture.
Other peoples opinions may differ.
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 16th, 2006, 09:00 PM   #8 (permalink)
herbie hind
i'm getting that impresion from other threads too thx .
Old Jul 17th, 2006, 12:24 AM   #9 (permalink)
Baker
Baker's Avatar
There are a couple of opinions on this, mostly coming from NAM. It was found that a certain batch of heads had a slight metalurgy problem, in which if they got too hot they basically allowed the plug to work loose, which then allows it to blow out the relatively weak thread. Originally this problem was being attributed to the Denso Iridium IK-22 plugs, but then it was found that similar things had also happened on other branded plugs (its just the majority of people were using IK-22's after getting a pulley installed by Randy Webb). It was even found, to a lesser degree, that people with stock cars were getting loose plugs due to the issue.
Personally I'm attributing it to a head failure, not a plug failure. If you look at the damage I suffered as well, it also destroyed three quarters of a spark plug lead!
On saying that; looking at the plugs externally the NGK looks nicer; having four points to create the spark from instead of just the one on the Denso. Will it help? Who knows; a dyno will not tell you, and you cannot trust the manufacturers to tell you. Down to personal preferance.
Old Jul 17th, 2006, 11:25 PM   #10 (permalink)
UKC4
MINI2 Sex God & etc......
UKC4's Avatar
I have a MC Standard engine compartment wise (No ECU Re-maps yet) all I have it a Milltek exhaust. Would it be ok for me to put Iridium plugs in to my car? And if it is ok can you tell a difference when they are in (Performance etc)?
Old Jul 18th, 2006, 02:19 AM   #11 (permalink)
Baker
Baker's Avatar
If you've got no engine mods there is no real point to putting Iridium plugs in, other than you get a longer plug life. You'll not get any difference power wise at all.
Old Jul 21st, 2006, 05:41 PM   #12 (permalink)
lemoncoke
Local Time: 05:39 AM
Cooler range plugs
What are the pros and cons about cooler range sparks plug??
thx
Milltek Cat-back..
KW V2
ES 100
Hong Kong   Reply With Quote
Old Jul 21st, 2006, 05:49 PM   #13 (permalink)
St00ge
St00ge's Avatar
not really an issue of pros and cons. You fit a colder heat range if you're combustion temperatures go up in order to dissipate some of the extra heat your making. In our case, that means a colder heat range is adviseable when you up the boost by adding a smaller SC pulley.
Old Aug 24th, 2006, 10:45 AM   #14 (permalink)
lemoncoke
White Cooper Ik 22
Dear all IK 22 user,
I would like to know is it necessary to regap the plug from 0.032 to 0.044? please advise.
Lemoncoke
Milltek Cat-back..
KW V2
ES 100
Old Aug 25th, 2006, 12:51 AM   #15 (permalink)
COOPER S KID
"Dare to be different"
COOPER S KID's Avatar
hi all !! just wondering those who are using NGK iridium's are they all the same as the jcw ones ???
Old Aug 25th, 2006, 12:57 AM   #16 (permalink)
herbie hind
Lemoncoke
i believe the manual says the hiher value. i'll look tomorrow.
Old Aug 25th, 2006, 01:24 AM   #17 (permalink)
St00ge
St00ge's Avatar
The JCW plugs are NGK, but not iridium. They are the right heat range for a pulley'd car tho
Old Aug 25th, 2006, 02:06 AM   #18 (permalink)
herbie hind
no ...looked in the manual and no gap to be found .but.. i'm sure i saw it somewhere ,check all over your car -under hood and door jams. it should be available.
Old Aug 25th, 2006, 02:07 AM   #19 (permalink)
herbie hind
oh... put antisieze on the threads and torque to 20 ft. lbs.
Old May 23rd, 2007, 10:58 AM   #20 (permalink)
Jenkins
Local Time: 11:39 PM
DIY IK20 instead of IK22
Sorry to reply on this rather old post. Just found it today, doing some searching on "iridium".
I.M.H.O., the IK22 is not the right Denso iridium plug. That should be the IK20.
Why did you choose the IK22?
Looking forward to your reply.
Best regards,
Jenkins
Netherlands Male   Reply With Quote
seat plugs addz Interior & Ice 1 Sep 19th, 2007 09:30 AM
plugs CC07ERS Engine & Drivetrain Tuning 4 Oct 25th, 2006 10:11 PM
Which spark Plugs? DWS MINI Cooper S 1 Jul 18th, 2006 11:57 PM
Spark Plugs venox22 Engine & Drivetrain Tuning 2 Jun 24th, 2005 03:43 PM
spark plugs again? MINIS2003 Engine & Drivetrain Tuning 1 Jun 25th, 2004 11:19 AM
