| MINI2 Regular Join Date: Aug 2003 Location: sheffield Local Time: 10:37 PM
Offline | Hi peeps, Yesterday i had a new milltek exhaust fitted to my S, it sounds spanktastic, but i have a couple of questions. I also have the mth tuner file on my car, do i need to get this updated straight away? and will not having the map updated with a new mod on my car cause any worrying problems. Also, when I set off in my car there is quiet a bit of rattling at the back, sounds like a tin can rattling, is this normal on a newly installed exhaust, the rattling stops once the car is under way, its just when you first get going. On a different subject, anyone from sheffield, do you know any garages in the area that will fit a 15% reduction pulley, tried all my local garages and none of the would touch it. many thanks for any help pubert |
| MINI2 Master Join Date: Dec 2004 Location: Sittard (NL) Local Time: 10:37 PM
Offline | I think you don't need an updated MTH tuner file just for the exhaust, better update the file when you get a 15% pulley. Here's a long thread about my milltek, some had the same problem as you have. The tips might touch the edge of the black trim on the back. You can cut the trim away (or it wil melt away in time), or slide the milltek a bit to the front to create more space around the tips. EB/W R53 MCS Highly Modified |
Offline | cheers berthill, goin to have a look now, when i've had a read through your thread. Update Just checked the exhaust, seems to have plenty of clearance around it, although it is slightly angled to the left as you look at the car from the back, just taken it on another test drive and it stills rattles like a tin can, so its going back to the garage that installed it. After reading your thread berthill, i'm wondering if its one of the hangers? cheers pubert Last edited by pubert : Jul 21st, 2006 at 02:13 PM. |
Offline | Could be, may be they have forgotton to tighten one of the hangers or the heat shield is to close to the exhaust. EB/W R53 MCS Highly Modified |
Offline | Heat shield, did'nt think of that, will check it out, its booked back in to the garage again for tomorrow so hopefully they should be able to correct it with a little prompting ![]() |
| Retro fitting JCW exhaust tips to MCS Exhaust | Cooooooperslad | Exterior | 13 | Jul 3rd, 2007 02:33 PM |
| Milltek Exhaust Fitting (gaskets etc) | futureal33 | Engine & Drivetrain Tuning | 4 | Jan 24th, 2007 06:59 PM |
| AMD Fitting my Milltek | wilmanlee | Engine & Drivetrain Tuning | 13 | May 6th, 2006 09:18 PM |
| Milltek Exhaust Fitting | wilmanlee | Engine & Drivetrain Tuning | 2 | Apr 25th, 2006 07:44 PM |
| Fitting a Milltek Exhaust | Richard M | Engine & Drivetrain Tuning | 1 | Apr 8th, 2005 01:18 PM |
