Visit Out Motoring!
Old Jul 24th, 2006, 02:05 AM   #1
A13EX F Cooper S
A13EX F Cooper S's Avatar
Local Time: 10:43 PM
Send a message via MSN to A13EX F Cooper S
injectors
I've read somewhere that the injectors for the mini are different to normal ones as the jet is split into 2 and also angled.
is this true?
the reason I ask is I am considering a larger throttle body but dont want to max out the standard injectors and make th engine run lean would fitting a large throttle body mak it run lean?
I currently have the following fitted:
15% puley
intercooler
full exhaust
decat
manifold
iridium plugs
air filter
remap
finding second had jcw ones 380cc is like finding a needle in a haystack with no needle in it so are there any other injectors from any other car that will fit as i'll do a bit of scrap yard hunting if they are.
oh and one more question can i just plug them in or do i need to remap the car again?
Old Jul 24th, 2006, 10:02 AM   #2 (permalink)
Penguinracer
Local Time: 11:43 PM
Bigger Injectors
I'm open to being corrected if I'm wrong but my understanding is that the MCS has sufficient duty cycle in it's standard ECU/Injector combo to safely fuel the engine's needs until it's producing up to about 250 bhp.
Sure the injectors will be working hard - but they'll be okay until the MCS is reaching the outer limits of what is a practical road tune.
Didn't Roland dyno his car at 270 bhp with standard injectors & at 273 bhp with bigger ones - I hope this gives some perspective.
Old Jul 24th, 2006, 10:21 AM   #3 (permalink)
A13EX F Cooper S
thats what i thought 240+ needs bigger injectors,
my problem is i think i'm close to that figure and the throttle body might tip me over.
also a throttle body means more air ... more air needs more fuel ... more fuel needs bigger injectors.
I dont want to risk blowing up a second engine lol
Old Jul 24th, 2006, 03:24 PM   #4 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Local Time: 07:43 AM
Send a message via MSN to St00ge
I doubt a throttle body will give you much more power....New injectors can be a good idea, even with the mods you have. Remember, JCW fit their injectors to a car that runs 207 bhp, so, can't be a bad idea.
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old Jul 25th, 2006, 02:27 PM   #5 (permalink)
Penguinracer
Bigger Injectors
We must remember that because the JCW was offered with a full factory warranty it was tuned to run a similar air/fuel ratio to the standard MCS in the interests of cylinder head temperatures & valve seat lubrication.
I'd be inclined to think that the JCW uses larger injectors to run a little rich just to be on the safe side.
My car is at the point where it's not far away from needing injectors - I'm guessing it's getting on for 240 bhp using the following:
(1) Hartge Conversion (210 bhp);
(2) 8mm HT leads;
(3) Iridium Plugs;
(4) 40kV coil;
(5) GTT 63mm throttle body;
(6) GTT timing sprocket;
(7) Schrick cam;
(8) GTT Induction kit;
(9) GTT Intercooler;
(10) GTT catchcan & vent;
(11)GTT tension pulley;
(12) GTT tension stop;
(13) GTT Twin bearing idler pulley;
(14) GTT modified by-pass valve;
(15) Scorpion Exhaust manifold & metal sports cat (same as Prodrive Scooby cat);
(16) Scorpion exhaust system all the way back.
At the track it's doing about 10 -13 mpg, so I can't really imagine it needing much more fuel.
It may be a borderline case - I'm open to suggestions.
Old Jul 25th, 2006, 02:47 PM   #6 (permalink)
St00ge
St00ge's Avatar
England
Well as was mentioned, the stock injectors have handled roland's 270bhp car, so obviously enough fuel can be injected. The problem is the duty cycle. I think the injectors shouldn't be stressed to more than an 80% duty cycle, or so i've been told. Which would mean no more than 270cc/min on stock injectors. It might be able to cope, but not for long....
Old Jul 25th, 2006, 04:04 PM   #7 (permalink)
Penguinracer
Cross-Over Point to Bigger Injectors
A fair point - it pays to have a bit of headroom - the last thing you want is the engine running too lean when under stress.
Roland posted an interesting thread to the effect that the Mini's ECU is surprisingly capable & can monitor the fuel flow irrespective of the injector size.
Essentially it will seek to flow the required fuel whether that means working a smaller injector harder or running a larger injector well within it's rating.
It would be helpful if one of the tuners could give a definitive answer as to when an increase in injector size becomes necessary to maintain healthy safety margins.
Only the GTT 250 & 260 kits include larger injectors if that means anything.
Injectors help! ant1 Engine & Drivetrain Tuning 4 Jun 8th, 2007 09:55 PM
Why Injectors? Bootsy Engine & Drivetrain Tuning 2 Dec 24th, 2005 03:04 PM
Injectors Fisher Engine & Drivetrain Tuning 5 Nov 19th, 2005 02:58 PM
Fuel Injectors? Doctor Frost Interior & Ice 0 Aug 26th, 2005 03:55 PM
Which Injectors?? Rickys'S Engine & Drivetrain Tuning 11 Jul 10th, 2005 06:14 PM
