Visit Derek Woodman MINI
Old Jul 31st, 2006, 02:34 AM   #1
Mx+Mini
Local Time: 02:37 PM
oil filter removal and install...
I did a quick search and didn't find the answer I was looking for. So... here's another oil change question.
I changed the oil in my wife's mini today, and the oil filter canister was tight. It was difficult to remove or install by hand. I had to use the wrench to help. Is this normal? I'm used to handtightening my oil filters, and I was concerned, I might wreck the threads on the canister using the wrench, but it was almost impossible to tighten by hand, and I think it's on right, because it sits flush against the seat and doesn't leak. So, is it normally this tight?
Also, the manual recommends 4.5L, but I only put in 4.0 L and it was already a bit above the max line on the dipstick, anybody else have this experience?
Thanks for responses all!
Canada   Reply With Quote
Old Jul 31st, 2006, 05:39 AM   #2 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Local Time: 07:37 AM
Send a message via MSN to St00ge
Very normal, i'd say you were lucky that you only had to use a wrench and not a herd of oxen attached to the wrench BMW really tighten it.
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Reputable & affordable place to get my oil/oil filter changed spmprnl MINI Cooper S 1 Feb 12th, 2007 04:39 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 05:20 PM
What oil filter, oil, and tools to use kgouin Maintenance & MINI Care 3 Sep 5th, 2004 04:16 PM
changing oil and oil filter MINIDoo69 Maintenance & MINI Care 3 May 9th, 2004 10:12 PM
changed my engine oil and oil filter today :D erichui Maintenance & MINI Care 15 Dec 23rd, 2002 09:56 AM
