| MINI2 Regular | GTT Idler pulley size Hi guys Is the GTT idler pulley the same size as the stock BMW one? Would it be smaller due to the smaller belt? I have a rattle on the pulley side of the engine. Only on idle and sounds like metal "buzzing" together. BMW seem to think its the idler pulley. Cheers Andy |
| | #7 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 09:46 PM
Offline | Hi Guys, the noise is possibly the tensioner bar buzzing slightly at idle (its definatly not the GTT Idler Pulley). The fix is a small bead of clear silicon sealant around the lower fixing/pivot. This 'damps out' the buzz without restricting the pivoting action. You can (or we can ) apply it using a small long screwdriver (or similar) to get to it. Ensure engine is off though! We now always apply silicon automatically when fitting. The GTT Twin Bearing Idler Pulleys are available in stock diameter or oversize, the larger one gives marginally more wrap on the drive side of the SC pulley; useful with small SC pulleys to give more grip. Best Regards Roland GTT ![]() |
| | #8 (permalink) |
| MINI2 Regular | Cheers guys The mini was in for warranty work on the passenger side wheel and the technician noticed it was making the buzzing. After explaining that i had the smaller pulley, belt and other bits he decided that its not worth doing. I too believe the buzzing to be the stop bar so i'll have a closer look with the silicone! Cheers for your help ![]() |
| GTT Twin Bearing Idler Pulley (help) | MiniBimmer | Engine & Drivetrain Tuning | 4 | Jan 31st, 2007 01:10 PM |
| Idler pulley knocking noise | Wurzel | Faults & Fixes | 12 | Jan 14th, 2007 10:50 PM |
| Idler pulley | Birdog | MINI Cooper S | 2 | Jul 25th, 2006 03:33 AM |
| Idler Pulley Failure after 394 Miles | jetstar1 | Faults & Fixes | 8 | Jul 22nd, 2005 04:39 AM |
| Idler Pulley | LordNikon | Engine & Drivetrain Tuning | 13 | Nov 17th, 2004 04:39 PM |
