| MINI2 Senior Join Date: Nov 2005 Location: Aberdeen Local Time: 09:39 PM
Offline | Just fitted my GTT intercooler Hello All, Iv just fitted my GTT intercooler and my car is running like sh**t its coughing and spluttering and the revs are going wild. one minute there below 500 and it sounds like its away to stall and the next minute the revs are going really high without me even touching the accelerator. What could i have done wrong?? it was just a straight swap, one intercooler for the other so i dont understand whats up! a wee bit worried tho. Willie a l t a - j c w - e i b a c h - u l t r a - g t t m i l l t e k - s p e e d l i n e |
| | #6 (permalink) |
Offline | Okay thanks alot guys! i'll check the snoots etc when i get home! Fingers crossed that will sort it. a l t a - j c w - e i b a c h - u l t r a - g t t m i l l t e k - s p e e d l i n e |
| | #8 (permalink) |
| 8/10 on the Stoogometer | Willie, the boot on the left is very hard to check. If the problem doesn't go away, i'd suggest getting what's called a mechanic's mirror, which apparently makes it easier to check. The boot on the right is easy to get your fingers around and feel if it's air tight, where as you can't really get your fingers around the underside of the left boot, unless you're a pigmy. I usually lightly run a screwdriver around the bottom to make sure that it's wrapped around the SC-IC horn Black MCS |
| | #12 (permalink) |
| It's getting hot in here! Join Date: Jun 2006 Location: Northampton Local Time: 10:39 PM
Offline | I fitted one of these to my mates Mini only a few weeks ago. 1st: Make sure the boots are on correctly 2nd: Give the car a good run as the ECU is not quite sure what is going on, it soon settles down and runs like a dream. Matt |
| | #14 (permalink) |
| Being normal is not fun! Join Date: Jul 2004 Location: Newcastle, Australia Local Time: 07:39 AM
Offline | ..but a ***** to get on ![]() [Edit: Aww what, I can't believe that the name for a female dog is censored. Seriously, we are adults here, how many kids do you know that drive around in new Minis.] |
| | #16 (permalink) |
Offline | Thanks lads, got the problem sorted there was a huge gap at the bottom of the right hand side snoot boot. The GTT intercooler looks very sexual on the car i have to say Willie a l t a - j c w - e i b a c h - u l t r a - g t t m i l l t e k - s p e e d l i n e |
| | #17 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 10:39 PM
Offline | Hi Guys, the best way to check for an air leak on the stock bellows (or anywhere on the inlet side )is a blast of carb cleaner around the vacinity at idle.The high vacuum will suck the cleaner in through even the smallest of gaps with a noticable change in the idle speed . The snoot boots are easy to fit,if you use a bit of WD40 they are even easier than stock as the intercooler swings down into position and the boot just slides into position. No trapped fingers! PS we have another 20 sets of 'GTT Snoot Boots coming in on Tuesday Best Regards Roland GT Tuning ![]() |
| New intercooler GRS or GTT which is best? | speedman | Engine & Drivetrain Tuning | 19 | Aug 27th, 2007 01:48 PM |
| Just ordered gtt intercooler | lucachiarelli | Engine & Drivetrain Tuning | 17 | Aug 10th, 2007 10:46 AM |
| GTT intercooler rubbing on my ht leads | Ant FR | Engine & Drivetrain Tuning | 48 | Jul 27th, 2007 03:47 PM |
| Hole in my GTT intercooler | G-Man | Engine & Drivetrain Tuning | 3 | Jun 11th, 2007 07:20 AM |
| GTT Intercooler | G-Man | Engine & Drivetrain Tuning | 57 | Jan 30th, 2006 01:15 PM |
