GizzmoUSA
Old Aug 13th, 2006, 09:43 AM   #1
venox22
only the brave!
venox22's Avatar
Local Time: 10:45 PM
Send a message via AIM to venox22 Send a message via MSN to venox22
Exhaust Manifold Design??
Just thinking away to myself yesterday........... and was just thinking about the varying designs in exhaust manifolds!! shape/pipe diameter/pipe configuration etc etc
I see the JCW manifold employs a 4-2-1 design, yet the GTT(janspeed) manifold employs a 4-1 design, what are the benefits of such contrasting designs???
United Kingdom Male View venox22's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 13th, 2006, 10:37 AM   #2 (permalink)
MINIMANIAUK
MINI2 Sponsor
Local Time: 09:45 PM
manifold design is unbelievably complex,pipe lengths,collector points,pipe diameters,wave theory,pulses,heat,pressure, flow,noise all come into play but the short answer is 4 into one is better at high rpm ,and high flow rates, and less concerned with peak torque. 4-2-1 is better at mid range flow and torque more suited to road use . on a track the engine is always kept at very high rpm and seldom dropped to the mid range so 4-1 better. the stock/jcw manifold have very short primary pipes and keep the noise down but are not a great design, hence the popularity of the aftermarket manifolds and more free flowing exhausts
Old Aug 15th, 2006, 07:40 PM   #3 (permalink)
Carlinho
Local Time: 06:45 PM
4-2-1 itīs a better choice if you donīt use it only in track...
Brazil   Reply With Quote
Old Aug 16th, 2006, 09:50 AM   #4 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
There are formulas available for exhaust manifold design which I used in designing the GT Tuning one to establish primary length & diameter and secondary length & diameter. You need to know valve overlap and other numbers to calculate. Ours isnt perfect (theres no space to get it 100%) but its a hell of a lot closer than any others Ive measured up and applied the same formula too.
Best Regards Roland GT Tuning
GTT Turbo Manifold Design roland2003 GT Tuning 7 Dec 28th, 2007 09:53 AM
Exhaust manifold 1andy MINI One 6 Jun 4th, 2007 12:50 PM
How to get the exhaust manifold OUT??? NFCooperS Engine & Drivetrain Tuning 9 May 7th, 2006 09:39 PM
exhaust manifold rhinolad Engine & Drivetrain Tuning 4 Apr 28th, 2005 10:38 AM
MS Design Exhaust arno Engine & Drivetrain Tuning 7 Jan 19th, 2003 06:59 PM
