Adam's Polishes
Old Aug 23rd, 2006, 08:26 PM   #1
fozworth
Local Time: 11:43 PM
Have fitted JCW ,airbag light stays on??
Ive got JCW front seats in my mini and as they dont have airbags in them the computor thinks there is afault with the air bag thus the light stays on.How can i get the light to stay off.
Old Aug 23rd, 2006, 08:36 PM   #2 (permalink)
Scrogg
Run out of ideas...
Scrogg's Avatar
Send a message via MSN to Scrogg Send a message via Skype™ to Scrogg
Take the bulb out?
Cover it up with black tape?
Northern Ireland Male   Reply With Quote
Old Aug 23rd, 2006, 08:41 PM   #3 (permalink)
irishbackpacker
irishbackpacker's Avatar
Local Time: 10:43 PM
Send a message via MSN to irishbackpacker
you have to bring it back to the garage as they have to reset it with a code from bmw, just changed to jcw seats last week and this is what i had to do.....
Old Aug 23rd, 2006, 08:43 PM   #4 (permalink)
Scrogg
Run out of ideas...
Scrogg's Avatar
Quote: Originally Posted by Scrogg (original)
Take the bulb out?
Actually that's probably a much more sensible way to do it!
Old Aug 23rd, 2006, 08:49 PM   #5 (permalink)
fozworth
how much did it cost
Old Aug 23rd, 2006, 08:59 PM   #6 (permalink)
Rakey
Four Candles?
Rakey's Avatar
about £45 is the going rate, you need to sign a document, this gets sent to MINI, they issue the dealer with the code which remains valid for 48hrs and they upload it, not a huge job, but they will still charge you for it
Old Aug 23rd, 2006, 09:07 PM   #7 (permalink)
Scrogg
Run out of ideas...
Scrogg's Avatar
£45? And all that buggering about? I like my black tape idea even more!!
Old Aug 24th, 2006, 06:50 AM   #8 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
I thought the leads just plugged into resistors so the system thinks the airbag is connected. This is how mine are fitted???
The only thing thing that happens is if you turn the ignition on before you connect the resistors the airbag warning light lights and can only be turned off by your dealer.
It was acceptable in the 80's
Old Aug 24th, 2006, 07:50 AM   #9 (permalink)
fozworth
So where are the ressistors,THeres wires with plugs under the seats so what do i do with them.
Old Aug 24th, 2006, 07:58 AM   #10 (permalink)
Root Ginger
You would of had to have unplugged the wires to remove your old seat from the car then the wires plug into the connector under the JCW seat as this has the resistor in it.
However if at anytime whilst the connector was unplugged the ignition was switched on the airbag light will light. Even if you plug the connector in later it will remain lit and can only be reset by a BMW/MINI dealer.
Old Aug 24th, 2006, 08:07 AM   #11 (permalink)
fozworth
right off to a dealer then
Old Aug 24th, 2006, 08:10 AM   #12 (permalink)
Root Ginger
Hope you get on OK and they don't try and charge too much to reset the light.
I have a set of JCW front seats and the airbag light stays on can i just remove the fozworth Interior & Ice 12 Oct 12th, 2006 08:22 PM
Airbag Fitting and Airbag Light Reset Westy_1985 Faults & Fixes 3 Sep 30th, 2006 05:31 PM
Winking.... one light stays on? zhigadum Faults & Fixes 4 Sep 23rd, 2005 10:34 AM
Interior light stays on, window keeps retracting Neeshil Faults & Fixes 20 Dec 3rd, 2004 03:22 PM
Airbag Light Mini4000 Faults & Fixes 2 Feb 20th, 2004 06:21 PM
