| MINI2 Regular Join Date: Mar 2005 Local Time: 10:45 PM
Offline | Change settings JCW gear shift light??? Hi I installed a JCW gear shift light today at a MINI dealer. In the PDF file ( JCW Shift Indicator Install PDF) I can see: "The engine speed threshold can be set between 3500 rpm and 7250 rpm in steps of 250 rpm." My question is: How can I change this?? Do I have to remove the whole shift light to able to change the settings? Hope anyone can help me Thanks Maaij |
| MINI2 Regular Join Date: Dec 2004 Location: Iowa Local Time: 03:45 PM
Offline | The engine speed threshold is the speed at which the shift light starts flashing (after all lights have lit up). This threshold can be set by DIP switches on the bottom of the shift light--as described in the install guide. To access these DIP switches, you will have to remove the shift light from the dash. Another way to think of it--the first light on the shift light comes on when you reach 10% of the threshold. The second light comes on at 20%. Third at 30%...and so on. By the time you reach 100%, all lights are on and they start flashing. |
![]() 6X therapist | its not difficult to do, set it at peak torque for revs against the dyno curve for optimum performance, you'll need a rolling road or a while playing on real roads to get it just right. I've found anywhere between 4 and 5,000 rpm about right for comfortable driving thats around 80% of the available power band, anything higher gets a bit wild at times, of course you don't have to obey the shift lights anyway. |
| JCW Shift Gear Indicator | movit | 2nd Gen John Cooper Works | 1 | Jul 15th, 2007 01:20 PM |
| quick shift gear change | elvispresley7 | Faults & Fixes | 0 | Jun 6th, 2007 05:54 PM |
| jcw gear shift indicator | !!cam!! | Interior & Ice | 29 | Jun 1st, 2007 11:04 AM |
| Jcw Gear Shift Indicator Fitting Instructions Please | Jacked up | General Discussion | 11 | Dec 25th, 2006 02:48 AM |
| oil & filter change help with torque settings | S-Cooper | Maintenance & MINI Care | 2 | May 21st, 2002 05:57 AM |
