Tags: , , , ,
Old Sep 26th, 2006, 09:50 PM   #1
fozworth
Local Time: 10:53 AM
BBR phase 1 question
I found out to day that BBR who did a phase 1 220 conversion on my mini cs dont actualy change the charger pully ,but instead change the lower pully size so you can still use a std belt.So does this mean if i change the charger pully i will get more power.
Old Sep 27th, 2006, 02:21 AM   #2 (permalink)
Shinka
Shinka's Avatar
Local Time: 04:53 AM
I'm guessing they changed the crank pulley then? Yes, adding a pulley will add more power. The crank pulley sizes are usually about a 2% increase (but also dramatically reduce the weight). If you get a 15% reduction pulley, it'll still up the power. A 15% reduction pulley with a 2% crank pulley should be near the equivalent of a 17% pulley for boost increase, plus the added benefit of weight loss at the crank. (I hope I know what I'm talking about here).
United States Male View Shinka's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 27th, 2006, 09:23 AM   #3 (permalink)
stu(pid)
Are you absolutely sure they didn't change the supercharger pulley? On mine they changed the pulley and the idler. Changing the idler means you can still use the standard size belt. I know because I got all the parts back!!
Old Sep 27th, 2006, 09:45 AM   #4 (permalink)
Perm
Perm's Avatar
The BBR phase 1 conversion involves the following :
1. Installation of BBR Star*Chip EVO-2 Software which includes (new map)
2. Installation of BBR Supercharger drive pulley
3. Installation of BBR / Cosworth drive belt idler
4. Changes to the boost and intercooling delivery systems
As you can see the pulley is changed, however because they install a Cosworth idler the standard belt can still be used.
Hope this helps.
Perm
Old Sep 27th, 2006, 03:16 PM   #5 (permalink)
fozworth
ok thanks guys,unfortunatly i didnt buy this from BBr myself the mini came with it and i got a bit confused with what bbr were saying regarding ,when changing the belt.so now i no ,i can use a std belt due to the cosworth idler.Also what size pully do they use to up the power,can you safly go smaller to up it more or will it cook the charger.
Old Sep 27th, 2006, 03:37 PM   #6 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 02:53 AM
Wouldn't it be wiser directing these questions to BBR?
Old Sep 27th, 2006, 05:36 PM   #7 (permalink)
uncle albert
uncle albert's Avatar
Online
I've read in the past that BBR use a 20% reduction supercharger pulley on their 220 conversion.
James
England Male View uncle albert's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 27th, 2006, 08:02 PM   #8 (permalink)
T-bone S
T-bone S's Avatar
Local Time: 09:53 AM
James
WOW - that's hyper extreme!! there are alot of potential issues if that is what they are using!
MY05 MINI COOPER S - DS/B - GTT OPTIMISED- THANKS FOR THE RIDE - ENTER THE R56 JCW
Old Sep 27th, 2006, 09:54 PM   #9 (permalink)
Perm
Perm's Avatar
I believe they use a 19% reduction pulley...... This is the reason the BBR 220 conversion has
so much low end torque vs other conversions.
I do not think there is any inherent design flaws with the BBR 220 conversion, however I would strongly recommend that you do the following (this is true for all conversions) :
1) Only use 97+ RON fuel [ BBR web site says you can use 95 RON this is risky)
2) Check what spark plugs are fitted......BBR do not change the spark plugs which I think is wrong..... I would suggest you change them for a colder heat range Iridium plugs.
3) Do not try for the land speed record...... or go exploring the upper revs ranges for extended periods.
Hope this helps
Perm
Old Sep 27th, 2006, 10:30 PM   #10 (permalink)
fozworth
My car has now got many more mods and although its running with the bbr pully its now had MTH mapping to cater for the new mods.i.e. large valve head,piper cam,fidenza flywheel,gtt manafold,play mini exhuast,larger injectors,iridium plugs,Alta induction kit,GRS intercooler,etc etc.so i wounderd as its a long way from the bbr conversion wether a different pully would be benificial and safe for my engine/charger and give me more power,or should i keep it the same size,pully that is.as im due a belt change next week.
Old Sep 28th, 2006, 08:18 AM   #11 (permalink)
Perm
Perm's Avatar
Quote: Originally Posted by fozworth (original)
.........would be benificial and safe for my engine/charger and give me more power,or should i keep it the same size,pully that is.as im due a belt change next week.
Are you happy with your current set-up ? If yes why change anything? Driving any heavily modified car like yours is never going to be as "safe" as driving a standard MCS irrespective of what size pulley you have installed.
By the spec you have got a real monster........... Who did you get all the other tuning bits from maybe they could advise better? Who is changing your belt ? Remember the BBR pulley / idler combination uses the standard MCS belt and not the shorter versions as some conversions require.
Perm
Perm
Old Sep 28th, 2006, 10:06 AM   #12 (permalink)
fozworth
mini mainia in wales are doing it
BBR Phase 1 Conversion Mini28 Engine & Drivetrain Tuning 6 Feb 11th, 2005 09:55 AM
MCS BBR Phase 1 Review Perm Engine & Drivetrain Tuning 26 Jul 23rd, 2004 08:26 AM
BBR Suspension mod question DerekR Suspension 6 Nov 14th, 2003 08:10 PM
