Tags: ,
Old Oct 3rd, 2006, 09:14 PM   #1
kriation
The Roaming Gnome
kriation's Avatar
Local Time: 05:43 PM
Send a message via ICQ to kriation Send a message via AIM to kriation
Question ECU Tuning...
Folks,
I currently own a 2001 S4, and am in the process of deciding to order an MCS. I've been doing a bit of research lately to discover the tuning potential of the MCS from all perspectives. It seems like there's quite an aftermarket for the MCS. However, through my research, I haven't found a tool like the one from Ross-Tech that the VW/Audi owners use for diagnostics. Also, the S4 owners use a software tool provided by Revo to make changes to the ECU through the OBD port with. This tool does not directly effect the fuel/load tables, but enable us to make percentage changes based on the tables.
I understand that the MCS uses a Siemens based ECU. The S4 uses the Bosch M7.1, which may/may not be considerably different. Has anyone performed this level of research, or developed tools that enable this type of modification to the ECU within the MCS?
Any information would be much appreciated.
TIA!
-- Armen
United States Male View kriation's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 3rd, 2006, 09:29 PM   #2 (permalink)
Madeira Jon
Madeira Jon's Avatar
Local Time: 09:43 PM
In brief, the BLUEFIN makes changes to the ECU through the port under the steering wheel (Well on right hand cars anyway) I cannot state what it will do to MCS but on the ONE, which I know isnt available in the USA, it gives an extra 30bhp or thereabouts. BLUEFIN is a hand held gizmo which also allows you to return the ECU to the manufactures specs.
Madeira Male   Reply With Quote
Old Oct 3rd, 2006, 09:39 PM   #3 (permalink)
kriation
The Roaming Gnome
kriation's Avatar
Thanks for the note! It seems that the BLUEFIN is built by Superchips in the UK, and that they do have an application for the MCS. However, I'm looking for more of a software solution much like the product provided by Revo, without having to swap out the factory ignition control system with an aftermarket one.
Old Oct 4th, 2006, 07:38 AM   #4 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Currently I'm not aware of any such application like the one you are looking for.
It was acceptable in the 80's
England Male View Root Ginger's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 4th, 2006, 09:16 AM   #5 (permalink)
Blusox
Local Time: 10:43 PM
United Kingdom View Blusox's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 4th, 2006, 10:11 AM   #6 (permalink)
Root Ginger
Quote: Originally Posted by Blusox (original)
That looks pretty good Blusox. I emailed them to see what is covered for the MINI as looking at the coverage document it doesn't list any MINI R codes in it even though it mentions MINI at the top of the BMW software page. Could be limited coverage for MINI.
Old Oct 4th, 2006, 04:12 PM   #7 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Looks really interesting, however when I read this:
http://www.carsoftsales.com/dloads/Fly%20&%20Buy.doc
I get the impression it's perhaps not cheap to buy
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 4th, 2006, 04:16 PM   #8 (permalink)
MartinSullivan
MartinSullivan's Avatar
Andy at RossTech used to be a regular on here (might still be I just havent seen his name pop up) and they were working on a tool for the mini, but never seen a final copy of it.
Old Oct 4th, 2006, 04:19 PM   #9 (permalink)
Root Ginger
Well I've requested a price guide
Old Oct 4th, 2006, 05:06 PM   #10 (permalink)
Ryephile
Deals Gap Junkie
Ryephile's Avatar
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
There aren't any good ECU solutions on the market if you need to do an actual custom tune. Piggyback solutions like UNIchip, Shark, Apexi, or anything that plugs into the OBDII port all work for basic tweaking if your engine just has basic bolt ons, but lack the real flexibility to do hardcore tuning for esoteric applications.
I wouldn't expect anything from Ross Tech, they've just been blowing hot air for the MINI market.
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 4th, 2006, 09:21 PM   #11 (permalink)
MINIMANIAUK
MINI2 Sponsor
both DTA and motec have ecus with the capability you desire, both will cost ££££ and not necessary unless you are looking at seriously modded engines,both have been used on the MINI with success but still too early in the tuning scene with the MINI, There has to be demand for these things first,there have been so many projects shelved due to lack of interest but things are changing fast,
Old Oct 5th, 2006, 05:15 PM   #12 (permalink)
Root Ginger
Got a mail back from carsoft to say the price is £2,129.00 + VAT (although that does include two free yearly upgrades at £300 each ). However on the question of what is covered on the MINI it just says they have extensive coverage of this model but looking through the specs it looks like the only coverage they have is the manuals and workshop guides and you can't do anything with the MINI ECU and BCU with their product.
Old Oct 5th, 2006, 07:26 PM   #13 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Thought it must be expensive if they ofer free flights to Brussels. Ironically I'll be over there in 2 weeks time, but I won't have time to investigate their fine ECU software, only their fine Belgian beers.
Old Dec 18th, 2006, 12:42 AM   #14 (permalink)
blalor
Rabid Motorer
Local Time: 04:43 PM
Send a message via AIM to blalor
I'm surprised nobody's mentioned the MTH product. It's essentially a reflash of the ECU, done through the ODBII port. It's not something where you can make changes yourself, but if you buy the "tuner" product, you get a number (perhaps unlimited) of updated programs over the course of a year. Probably not worth it until you start adding an exhaust, pulley, and intake, however.
Old Dec 18th, 2006, 01:10 AM   #15 (permalink)
kriation
The Roaming Gnome
kriation's Avatar
DIY
Sweet! Thanks Brian! I actually have the OBD-II connector from RossTech that I had bought for the S4 a long time ago, and I'm glad it will still be useful on the MINI. Hmm... speaking of which, I might plug in with the RossTech software running just to see what I can get out of the MINI ecu. Regardless, thanks for the link. I'll try to do some more digging around, but it seems like right now, the price for ECU tuning on the MINIs is a bit more than what the regulars are willing to spend (including myself).
After a discussion that Adam and I had over lunch today at the BBQ meet, it seems like fuel mapping and ignition timing are the potential changes that one can make with ECU tuning. Boost pressure control is clearly done via the reduction pulleys. I'm sure with all the gearheads around, we can find ways to squeeze more power out of these engines.
Talar: 2001 Audi S4 (Stock... ok... maybe not)
Soffi: 2005 DS/B MCS (Stock... for now...)
Old Dec 18th, 2006, 01:42 AM   #16 (permalink)
blalor
Rabid Motorer
One of the biggest benefits to the MTH software, in my opinion, is the ability to dial back the amount of torque DSC removes when it kicks in (less of that sitting duck feeling when trying to pull out into traffic) and also being able to greatly reduce the "throttle hold" the ECU does for you between gears, where it keeps the revs artificially high when shifting. Both of those will improve the overall drivability of the car. I must note that I haven't purchased this mod for myself, yet, but my understanding is that it's a more approachable solution compared to something like the Unichip which, while supremely configurable, really requires working with a seasoned tech with access to a dyno (on top of the acquisition cost). So, from what I've heard, you get many of the benefits of the Unichip with about a quarter of the cost.
The dealer network for MTH is growing; my buddy Waylen of Way Motor Works has recently become a dealer. He's (currently) in Indianapolis, but he's one of the more knowledgeable MINI mechanics I've dealt with. He'll be happy to talk to you!
ECU tuning the ONE InvalidBoy Engine & Drivetrain Tuning 9 Dec 16th, 2006 11:25 AM
Aftermarket ECU tuning minigolf 2nd Gen MINI Cooper S 4 Sep 16th, 2006 10:00 AM
Adaptive ECU v. tuning Widgey Engine & Drivetrain Tuning 10 Mar 3rd, 2006 09:05 AM
ECU Tuning ! the_red_skin Engine & Drivetrain Tuning 19 Sep 19th, 2005 08:23 PM
Best ECU Tuning? joer-r Engine & Drivetrain Tuning 2 Jul 5th, 2004 05:47 PM
