Visit Mini Mania UK
Old Oct 7th, 2006, 12:01 PM   #1
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 08:42 AM
DIY Getrag 6-speed gearbox
Hi all technical people...
I have read that the cooper S gearbox is designed to take no more than 210Nm of torque.
Do we know if this is the torque input or torque output?
I assume that the gearing inside would result in a torque output of higher than 210Nm if that was the rate provided from the engine?
A quick understanding of this would be greatly appreciated...
Cheers,
CSW.
Old Oct 7th, 2006, 02:34 PM   #2 (permalink)
Ryephile
Deals Gap Junkie
Ryephile's Avatar
Local Time: 03:42 AM
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
The rating is input torque as delivered from the engine. Our Getrag has a "manufacturer rating" of 155Lb-Ft. That said, it's the same gearbox that is used in the JCW and GP, and those have more than that. Beyond that, some tuners extract relatively big torque numbers from the engine, north of 300Lb-Ft, without grenading the gearbox. I run my Cooper S at 270Lb-Ft at the crank with the stock gearbox at and have 64k miles on it, with no weirdness.
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 7th, 2006, 05:58 PM   #3 (permalink)
supercoopers
supercoopers's Avatar
The weakest part of the geabox is pretty much the standard open diff. Replace that with a Quaife and you will have a very hard time trying to break the thing, unless you are into crunching through gear changes The Quaife is rated to 700bhp going off previous applications.
The Fireballed car runs a stock Getrag gearbox with a stock LSD on the drag strip no problems. 500+ bhp and more torque than will ever be possible to produce with the supercharger alone.
Cheers,
Henry
Getrag gearbox Philr MINI Cooper 10 Dec 31st, 2006 09:01 AM
Recall for 2005 MC - 5 speed Getrag gearbox RedMini Faults & Fixes 4 Oct 26th, 2004 07:56 PM
New gearbox Getrag Dende_GT MINI Cooper 3 Jul 24th, 2004 05:42 PM
Getrag GEarbox in a cooper? moonshine Engine & Drivetrain Tuning 13 Aug 7th, 2003 04:38 PM
Noisy Getrag gearbox anyone? Chips Faults & Fixes 6 Feb 12th, 2003 02:48 AM
