![]() 217.4bhp / 364.7 nm R56 T Join Date: Oct 2006 Location: Preston, Lancashire Local Time: 07:15 PM
Online | Bluefin Superchip Question Hiya, I'm new to the forum and would like to say a big hello to everyone! I have been having a read through some other 'bluefin' threads, but none answer my questions. I have a Mini Cooper S, 53 plate 170bhp. Ok, On the lohen website, it says a bluefin superchip will add about 8bhp - has anyone added the bluefin and found an exact increase? I know each car is different, but I would like to hear from someone who has actually done this and, When you remap the ECU with the bluefin chip, does this process need to be carried out each time you start the car to remap the ECU to the Bluefin remapped profile, or does the ECU store the new 'remapped' stats? Many Thanks! |
| MINI2 Senior Join Date: Feb 2006 Location: Swindon Local Time: 06:15 PM
Offline | Hi There and welcome Unsure of the exact increases to be gained by the new map but once the bluefin has been up loaded the ECU will memorise the settings. Given that though i believe it resets the learning curve aswell so it takes a few hundred miles to totally settle in. Hope this helps Checkie Checkmate mad owner |
| What's Next? | Take a look at the Superchips website, should answer all your questions: Superchips - Superchips Applications. Surely if your car is a '53' plate it will be the 163BHP engine? If so, you will get a 6BHP increase. |
Online | That was another question I was going ask actually, the salesman told me that it was 170bhp rather than the 163, I actually asked him the question. After reading through on here it seems a 'facelift' occured between the 03 and 03 plates? Can anyone confirm what the differences are, and also what bhp my 53 plate is, bearing in mind I have been told its a 170? Thanks again ![]() |
| MINI2 Regular | the main differences I believe are a lighter crank pulley and a different ratio gear box and probably a little ecu fiddling. Also heard that the later superchargers were teflon coated inside to improve air flow efficiency, not too sure though. These changes kick in on the late 54 plate as far as I know. ![]() |
| | #6 (permalink) |
| MINI2 Master Join Date: Apr 2005 Location: Watford, Herts. UK Local Time: 07:15 PM
Offline | The salesman was wrong about a 53 plate cooper S having 170bhp, it has 163bhp. I have a Bluefin on my MCS and it has made the the engine so much smoother. I don't know if it has an extra 8bhp, but it does feel more powerful than before. It's also more economical as well. When i first uploaded the new Bluefin map onto the ECU, it didn't feel any different to start with, as the ECU has to learn how to use the new settings. But after 50 - 100 miles it felt way better than before. Once the bluefin is loaded it stays there until you reload the stock map back again. |
| | #7 (permalink) |
![]() cave capsicum Join Date: Mar 2006 Location: Crewe Local Time: 07:15 PM
Offline | Facelift was July 04, so applies to late 04 plate cars or if you could make the dealer wait until September 1st - 54 plate cars. Look for the car build date on the top of the drivers side wheel arch (you will see it when you lift the bonnet). Did you buy it from a BMW dealer? ![]() |
| | #8 (permalink) |
Online | No, I got it from a trader off autotrader magazine. I suppose his knowledge of Minis is likely to be limited, so he was probably wrong and it is actually the 163 model, but with a new air filter and possibly a reduction in pulley wheel size, I should make up for the lost horsepower anyway right? Cheers |
| | #9 (permalink) |
Offline | If your looking for cost effective tuning options then you could do worse than to take a look here: GT TUNING MINI PARTS & PERFORMANCE CONVERSION Fitted Performance Packages A pulley and ECU conversion will take you up into JCW territory at around 210bhp. ![]() |
| | #10 (permalink) |
| MINI2 Master Join Date: Dec 2004 Local Time: 07:15 PM
Offline | the diff between the 03 and 04 face lift models are a diff superchrager (teflon coated), revised injectors, and new gear ratios but a GTT stage 1 as capsaisin said would make up the differnace, or if you willing to fork out 3.5k the offical mini john cooper works conversion is a granteed 210 bhp (new superhrager, cylinder head, air intake, exhuast, engine map and injectors) |
| Superchip Bluefin | Simon220 | MINI One | 2 | Mar 15th, 2006 02:50 PM |
| Bluefin or Superchip? | GR33NIE | Engine & Drivetrain Tuning | 7 | Jan 31st, 2006 04:45 PM |
| bluefin question for hire??????/ | sexyred_cya | General Discussion | 1 | Jan 14th, 2006 05:03 PM |
| one superchip | maxdude | MINI One | 2 | Mar 29th, 2003 01:29 PM |
| Superchip question | 400bhpmini | Engine & Drivetrain Tuning | 3 | Aug 11th, 2002 05:22 PM |
