Old Oct 10th, 2006, 06:43 PM   #1
minioneandrew
minioneandrew's Avatar
Local Time: 02:25 PM
Send a message via MSN to minioneandrew
Question about strut braces?
Hi all!
Was just wondering if anyone had any experience with the upper and lower strut braces that you can get for your MINI? Are they easy for someone like me - i.e quite good at putting things together but have limited tools? And do they offer any improved handling?
Cheers Andy
Scotland Male View minioneandrew's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 10th, 2006, 06:51 PM   #2 (permalink)
James
James's Avatar
a strut brace will help to stiffen up the front end of the chassis, it will also improve the turn in response through corners as well as making the handling more predictable
Old Oct 10th, 2006, 07:38 PM   #3 (permalink)
stealth haggis
worth it ive got omp upper and lower and its a whole better kettle iof fish now for only 90 quid lower one needs ramps or jacked up to do upper one can be fitted with the 13mm spanner in the boot (only did once to get to the battery) but would advise a socket
Old Oct 10th, 2006, 08:16 PM   #4 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
DIY Pimp-ed
Pimped? what did you have done ?
Old Oct 10th, 2006, 08:21 PM   #5 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
England Rigidity
Quote: Originally Posted by minioneandrew (original)
Hi all!
Cheers Andy
You may want to pay special attention to the type of brace you are fitting. Some braces may be considered better than others due to their construction and adjustability.
For example, a strut brace that has adjusting bolts on it can improve the tension between the two suspension topmounts, whereas a very solid strut brace can improve the compression.
When you drive fast on bends left, right, left, right, your chassis is trying to flex and you loose some of that solid steering feel and thus the 'feeling' of the road. By fitting a really good brace you can prevent the chassis at the top mounts from flexing towards each other and flexing apart as would happen if you were whippingin and out of corners.
Personally, the best strut brace i have ever seen is the GTT brace - it's basically a girder!! but made of very light aluminium. Some braces are made of aluminium but are too flimsy and offer nothing in the way of compressional control - i.e. .like a wire rope. Other are made of steel and weigh heavy.
They'll all tell you that they are the best brace, but really, some are bad, some are good. be careful. Let's just say - JCW, looks nice, does nowt for compression!!!
Old Oct 10th, 2006, 10:56 PM   #6 (permalink)
stealth haggis
not much just braces and barkes but it dose sound better than lohen sligtly improved my ride
Old Oct 10th, 2006, 11:02 PM   #7 (permalink)
stealth haggis
although that dose sound quite funny sig changed
Old Oct 12th, 2006, 10:24 AM   #8 (permalink)
Fisher
Local Time: 03:25 PM
Send a message via MSN to Fisher
The best improve by strut is the lower strut brace from OMP.
It is the cheapest improvment for the MINI cornering. I have both from OMP lower and uper. The uper maybe it isn't the best choice but again it is not expensive.
Bye
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 12th, 2006, 11:01 AM   #9 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi Guys,-There is a GTT Lower Brace coming soon, its larger diameter than the OMP and TIG welded for strength rather than MIG welded, its also Stainless steel rather than mild steel. The OMP lower brace IMO isn't bad (we stock it too) but this will be stronger and a whole lot nicer . Theres also a second GTT 'rear' lower brace coming v.soon.This clamps in 4 positions (2 each side) through the brace ,subframe and floor pan using (the stock ) 4 xM12 bolts.The brace is 16mm thick by 50mm at the widest points solid high tensile T6 alloy.Its also powder coated in satin black.
-New thread coming soon !
Best Regards Roland GTT
Strut Braces Mins21 Exterior 0 Jun 28th, 2007 10:38 AM
Strut braces CC07ERS 2nd Gen Suspension 0 May 8th, 2007 09:38 PM
Strut braces Alicsone Suspension 7 Oct 6th, 2006 03:57 PM
Strut braces tom2005 Suspension 7 Jul 18th, 2006 10:45 PM
Question About Strut Tower Braces ncdave Suspension 7 Dec 2nd, 2004 01:24 PM
