Carccessory.com
View Poll Results: Dump Valves?
cool 21 50.00%
chav 21 50.00%
Voters: 42. You may not vote on this poll
Old Oct 18th, 2006, 12:22 PM   #1
Rakey
Remember
Rakey's Avatar
Local Time: 09:46 PM
Dump valve
Will you be rushing out to get one fitted to the R56?
Are they cool or chav?
Old Oct 18th, 2006, 12:23 PM   #2 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Cool.......a mate had one on his cossie, they sound ace.
Global Moderator
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 18th, 2006, 12:26 PM   #3 (permalink)
:: Jon ::
:: Jon ::'s Avatar
Local Time: 10:46 PM
for scoobys and the like... ONLY
EMPTY SPACE NEEDS FILLING....
but it has to be something that wont get me banned
Old Oct 18th, 2006, 12:28 PM   #4 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Say's who?
Global Moderator
Old Oct 18th, 2006, 12:29 PM   #5 (permalink)
marx87
R56 MCS Works For Sale!
marx87's Avatar
is the r56 going to be turbo-charged?
Old Oct 18th, 2006, 12:29 PM   #6 (permalink)
Will_'S'
Stealth Cooper
Will_'S''s Avatar
no disagree think used in the correct manner they sound awesome
but anti lag system amazing
Old Oct 18th, 2006, 12:42 PM   #7 (permalink)
M1OY CS
Danger!Moddings addictive
M1OY CS's Avatar
If i was to get an R56 which wouldnt be untill they release the JCW i would almost certainly get one! They sound wicked!
Nearly fully loaded DS/B MCS GTT O.Z Superleggera's - TOYO T1-R Rubber - Aero Kit - Milltek Cat-back exhaust - GTT 220 - Competition Crank pulley - GTT Oil catch can - GTT Tensioner Upgrade pack - GTT Strut Brace - GRS intercooler
Old Oct 18th, 2006, 12:49 PM   #8 (permalink)
-=cHiLli=-
Banned
-=cHiLli=-'s Avatar
how embarrassing... great in the car but everyone outside will look at you like some chav idiot in a nova...
Not my taste....
I heard you get a free burberry roof decal with every dumpvalve purchase
i++()
Afghanistan View -=cHiLli=-'s Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 18th, 2006, 12:51 PM   #9 (permalink)
AidenL
Nice TTs.........
AidenL's Avatar
Send a message via MSN to AidenL
Chav for sure - no doubt about it
Global Moderator
Ireland Male View AidenL's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 18th, 2006, 12:52 PM   #10 (permalink)
Hat
ITS RAINNIN' SIDEWAYS
Hat's Avatar
why is it more chavvy than making a works exhaust pop? someone is bound to fit one
Old Oct 18th, 2006, 12:56 PM   #11 (permalink)
M1OY CS
M1OY CS's Avatar
very well said hat!
Do dump valves not go you extra H.P too?
Old Oct 18th, 2006, 12:56 PM   #12 (permalink)
*Vikki*
Winner MM best MINI ONE!
*Vikki*'s Avatar
no cool get one!
Old Oct 18th, 2006, 12:57 PM   #13 (permalink)
M1OY CS
M1OY CS's Avatar
thats it vicki someone with taste!
Old Oct 18th, 2006, 12:58 PM   #14 (permalink)
AidenL
Nice TTs.........
AidenL's Avatar
Its a bit ricer Pat, imo Has a whole set of connotations and perceptions attached to it - well I do get a picture of the car and driver in my head anyway, when I hear one blow
Someone might fit one, but I wouldn't I must admit
Global Moderator
Old Oct 18th, 2006, 01:01 PM   #15 (permalink)
Hat
Hat's Avatar
Quote: Originally Posted by M1OY CS (original)
very well said hat!
nope, not an ounce:
Dump valves are fitted to the engines of (usually older) turbo charged cars and sit between the turbo outlet and the throttle body. When transitioning from a boosted state to a closed throttle state (as in between shifts), due to inertia, the turbo continues to pressurize air, but the closed throttle prevents the compressed air from entering the engine. In this case the pressure exceeds the preset spring pressure in the dump valve and the excess pressure is bled off to atmosphere.
Even with a dump valve the compressed air acts as a brake on the turbo (slowing it down), because the pressure on the backside of the turbo is at a higher pressure than on the front side (and the air actually wants to flow through the turbo backwards).
A blowoff valve is a more elegant solution to this problem by allowing the turbo to "freewheel" when the throttle is closed (equalizing the pressure on both sides of the turbo). Unlike a dump valve a blow off valve can be used at multiple boost settings without reconfiguration.
Blow off valves (which may cause offence) are sometimes incorrectly called dump valves because they serve a similar function, however they are very different solutions to the same problem
i know what you mean but i remember dink having one on his RS Focus & it sounded pretty cool
Old Oct 18th, 2006, 01:02 PM   #16 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
It's no different to fitting an Air Filter and many of you who've called it 'Chav' have done just that if I'm not mistaken.
Global Moderator
Old Oct 18th, 2006, 01:14 PM   #17 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
The turbo MCS is almost certainly going to have a 're-circulating ' dump valve fitted as standard also known as a closed loop dump valve (my terminology circa 1991) or bypass valve. These recirculate the air back to the 'clean side' of the air filter rather than direct to atmosphere. The latter produce the whoosh. These valves have various (proper ) functions notably to reduce lag on gearchange ,as the compressor is no longer 'stalled ' by pressure build up on its outlet side due to snap closing of the throttle, and also reduced thrust bearing wear in the turbo for the same reason. They also give a more relaxed part throttle cruise (ie less on or off power delivery) ,working in a similar way to the superchargers bypass valve in this instance.
Best Regards Roland GT Tuning
Old Oct 18th, 2006, 01:15 PM   #18 (permalink)
Olly.
Overboosting.....
Olly.'s Avatar
I must admit, I wouldn't fit one.
Old Oct 18th, 2006, 01:18 PM   #19 (permalink)
Hat
Hat's Avatar
Quote: Originally Posted by roland2003 (original)
The turbo MCS is almost certainly going to have a 're-circulating ' dump valve fitted as standard also known as a closed loop dump valve (my terminology circa 1991) or bypass valve. These recirculate the air back to the 'clean side' of the air filter rather than direct to atmosphere. The latter produce the whoosh. These valves have various (proper ) functions notably to reduce lag on gearchange ,as the compressor is no longer 'stalled ' by pressure build up on its outlet side due to the closing of the throttle, and also reduced thrust bearing wear in the turbo for the same reason. They also give a more relaxed part throttle cruise (ie less on or off power delivery) ,working in a similar way to the superchargers bypass valve in this instance.
thanks for that roland
Old Oct 18th, 2006, 01:21 PM   #20 (permalink)
M1OY CS
M1OY CS's Avatar
so they are beneficial! thanks Roland!
Dump valve sound?? pardonator Engine & Drivetrain Tuning 1 Sep 5th, 2007 02:30 PM
Dump Valve miniman23 2nd Gen MINI Cooper S 3 Jul 12th, 2007 11:43 PM
Dump Valve? Pepper'D MINI One Diesel 30 Nov 8th, 2006 03:09 AM
dump valve deb cooper s MINI Cooper S 1 Oct 13th, 2004 10:37 AM
Dump Valve mini-dazza Engine & Drivetrain Tuning 15 Aug 29th, 2004 07:35 PM
