Think Mini
Old Nov 11th, 2006, 09:07 PM   #1
blaze1235
SMASH
blaze1235's Avatar
Local Time: 09:54 PM
Fitting GTT Manifold Help !!
The day started well
fitted gtt Cold Induction kit in around 10 minutes simple compared to the Alta fitting
this boded well for the impending job of fitting the manifold
started on the manifold everything came apart with ease
back section split from manifiold 2 heat shields removed manifold loosened and then released, O2 sensors removed.
after 6 hours 1 large pizza two small garlic breads packet of chicken strips and wedges
could we get the mnifold past the front antiroll bar could we stuff as like
anyone know the right trick to this without dismantling the front end please?
FEltt defeated and generally gutted
If i can't win i won't play......
Old Nov 12th, 2006, 11:43 AM   #2 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi David, you need to remove the big thin alloy shield underneath the car that sits in the tunnel against the body (8mm socket) . Feed the front lefthand end in first . This 'feeding in in' bit should take about 30 seconds ,just watch the gearchange linkage cables as it goes in.
Best Regards Roland GTT
Old Nov 12th, 2006, 11:58 AM   #3 (permalink)
blaze1235
SMASH
blaze1235's Avatar
thanks roland it was also the break lines that were bothering me
Also are we talking about the heat sheild that is roughly 12 inches long held in by two bolts. coz i already did that and still couldn't get it out.............
only had around 12 inchees 2 foot under the car on axle stands
or are we talking about all the shielding held in with tiny
Old Nov 12th, 2006, 01:21 PM   #4 (permalink)
roland2003
..Yes I mean ...'the shielding under with tiny.'..
You need the car higher too.
Old Nov 12th, 2006, 03:54 PM   #5 (permalink)
blaze1235
SMASH
blaze1235's Avatar
oops tiny bolts lol
a ha i see will i need new clips because some of them are the other way round?
Old Nov 14th, 2006, 02:40 PM   #6 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
I didnt remove anything when I fitted mine. Took me 6.5 hours and involved using a large lump hammer.
Brute force + ignorance = wins the day.
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 14th, 2006, 04:18 PM   #7 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Unhappy Ouch !
Cringe
Cheers,
K.
Old Nov 14th, 2006, 04:32 PM   #8 (permalink)
Will_'S'
Stealth Cooper
Will_'S''s Avatar
Local Time: 10:54 PM
6.5 hours slow coach i removed all the bits roland said and it took me about three hours i think more by luck as the manifold came out and went back in first time without causing any swearing and it was all on done on axle stands and ramps but i agree if it dont fit hit it with a hammer
Old Nov 14th, 2006, 04:41 PM   #9 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
I also had to jack the car up higher as my ramps werent big enough to allow the manifold to drop out the bottom. A BMW tech told me he could do it in 45 mins....
Old Nov 14th, 2006, 04:48 PM   #10 (permalink)
Will_'S'
Stealth Cooper
Will_'S''s Avatar
45mins i'd bet he'd charge you for 3 hours yeah i stuggled gettin it out but had a hydraulic jack so could get one side a little higher made the job so much easier
Old Nov 14th, 2006, 11:12 PM   #11 (permalink)
blaze1235
SMASH
blaze1235's Avatar
i had my hydraulic jack and axle stands but just a small one so the axle stands were on the lowest setting.
i took me 30 minutes to put it back together i reckon if i could get htis out easy i could do it in aboout 1 and half hours including jacking time.
Old Nov 14th, 2006, 11:13 PM   #12 (permalink)
blaze1235
SMASH
blaze1235's Avatar
Did you damage any of the clips in the heat shield tunnell when you did it and if not how did you get them out.
GTT Manifold V JCW Motorsport Manifold chrisflyer Engine & Drivetrain Tuning 24 Sep 26th, 2007 04:14 PM
GTT Exhaust Manifold Aberdeen Al Engine & Drivetrain Tuning 1 Dec 19th, 2006 08:25 PM
Do you have a GTT Sports Manifold? Wondaboy Engine & Drivetrain Tuning 6 May 4th, 2005 08:42 PM
