Tags: ,
Old Dec 5th, 2006, 11:45 PM   #1
Gr1zzLy
Crapping in the woods...
Gr1zzLy's Avatar
Local Time: 10:16 PM
Tuning without a remap
I'm about to venture into the world of MCS tuning, and have questions regarding the ecu maps. How important are they? Can I upgrade the parts on my car without going for a remap?
The mods I'll have are:
15% pulley, CAI, NGK sparks, Nology Hotwires, JCW exhaust, and considering a header (either MTH or Mini-Madness) and 380cc injectors and GRS intercooler.
So... if I do all that.. would I need a remap? I recognize that the car may not be working at it's most efficient without one, but also how long could I go without updating the ecu?
Thank you.
Australia Male View Gr1zzLy's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 6th, 2006, 12:26 AM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 04:16 AM
I don't think you need the larger injectors, but you'll need a remap if you go with them.
Old Dec 6th, 2006, 08:16 AM   #3 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
Local Time: 12:16 PM
I have a JCW with a Pully, manifold, CAI, GRS intercooler as well as a few other things from GTT. Didnt need a remap. I know Roland from GTT runs a standard map on his MCS, except it has a slightly higher rev limit, and hes running over 260bhp.
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 6th, 2006, 03:55 PM   #4 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
It all depends on the car. Roland will tell you that some stock cars maps seem to fuel modded cars far better than others...some require the standard map reflashed to get them to keep the fixture at a safe level but others don't. Also if you fit bigger injectors you don't nessiserily need a different map...all that happens is that the injectors can push more fuel in at a given time. The map will usually cope...but TBH a remap might give you that little bit more from the mods.
R
Old Dec 7th, 2006, 11:10 AM   #5 (permalink)
freespeed
You would need to have a new software in the ecu if you would like the Mini to work perfect with all these changes - specially when you do a pulley change......
Old Dec 7th, 2006, 11:57 AM   #6 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi Guys, yes we have about 12 different maps here for our car,but the one we use is stock with a bit more idle speed due to the Fidenza flywheel. Fuelling is excellent using JCW injectors ,maintains 14.7:1 in closed loop and 12:1 at full revs with WOT. You must use a wide band sensor/digital meter, mounted BEFORE the cat, and test on the real road/track to achieve actual loads,airflow,cooling etc.A sniffer up the tailpipe on the RR gives all sorts of false readings/delays. If you adjust 'to this' it could be miles out. Timing is the area that may /may not need altering. How do you know? you do the other mods first then try the car to see if (and at what rpm) the car pinks. If necessary the timing can be retarded. Or in some cases you can even advance beyond stock but is less common and has to be done in very small increments. Keep using the 99 Ron guys ,its not recommend for smoothness or power ,but engine protection under full sustained load. (and at present I have no shares in Shell V or Tesco 99)
Best Regards Roland GTT
Remap 1andy Engine & Drivetrain Tuning 1 Mar 2nd, 2007 01:57 PM
remap DEBORAH LEIGH Engine & Drivetrain Tuning 1 May 1st, 2006 05:00 PM
Which Remap? R0B C00PER Engine & Drivetrain Tuning 21 Feb 19th, 2006 12:59 PM
BBR Remap badboyzbadboyz Engine & Drivetrain Tuning 10 May 26th, 2005 12:55 PM
BBR or West Tuning or GT Tuning? spillers Engine & Drivetrain Tuning 81 Nov 16th, 2004 06:49 PM
