Old Aug 14th, 2002, 09:50 PM   #1
dukesantos
Moderator
dukesantos's Avatar
Local Time: 01:48 PM
Tire/wheel combo weights
In previous threads, Russ and Olddad have posted very helpful information on various wheel specs and weights, I can now add a few tire/wheel combinations. All are mounted, air filled, weights.
Base: 15 in., seven hole, R81, standard Cooper wheel with the Continental 175/65 R 15 CH95 M+S tire. Weight: 30 lbs.
Auto-X set up: same 15 in. wheel with 205/50 ZR 15 Kumho Ecsta V700. Weight: 36 lbs.
Runflat: 16 in. 5 Star, R83, wheel with 195/55 R16 Dunlop SP Sport 3000A DSST. Weight: 45 lbs.
Previous info was that the R81 wheel weight alone is 12 lbs. and the R83 wheel alone is 20 lbs. I did not weigh them without tires.
United States Male View dukesantos's Pure Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 14th, 2002, 10:59 PM   #2 (permalink)
WAY
Local Time: 07:48 AM
How wide are those 15's? I want to put 215's on my 6.5inch rims but am not sure if it will fit or if it is recommended.
Australia   Reply With Quote
Old Aug 14th, 2002, 11:14 PM   #3 (permalink)
dukesantos
Moderator
dukesantos's Avatar
The 205 Kumhos are approx. 8.5 in. wide. There is about half an inch of static clearance from the inside of the front tire to the suspension. I have read conflicting reports about the 215s. Some say it will fit, others say it rubs- probably depends on your wheel offset and tire brand.
Old Aug 15th, 2002, 12:20 AM   #4 (permalink)
Garfield
Garfield's Avatar
Local Time: 04:48 PM
There's lots of autocrossers running 215's on the 6.5, easy fit. I'm running a few mm less offset, but there are people running stock 16's, both styles, with 215/40R16's.
Keep in mind though, every tire measures differently, BUT, the Hoosiers are unusually wide and we're running them.
Brian
- 2005 G Stock '05 MINI or it's back to a Miata in C Stock
- 2004 G Stock 2nd place Pro Solo, 9th Place Solo II
- 2003 STX 5th place Pro Solo, 6th Place Solo II
- 2002 H Stock Pro Solo National Champion
Old Aug 15th, 2002, 12:30 AM   #5 (permalink)
dukesantos
Moderator
dukesantos's Avatar
Smile Thanks Brian
You have the best auto-X info.
Advice on wide 16" tire/wheel combo SoonToBeMini Wheels, Tyres & Brakes 4 May 6th, 2005 07:53 AM
Will this tire/wheel combo rub? paulmon Wheels, Tyres & Brakes 0 Feb 8th, 2004 02:37 PM
Best tire/wheel combo for street prepared autoX Strangelove MINI in Motorsport 8 Nov 6th, 2003 03:34 AM
Tire Weights MINIAC Wheels, Tyres & Brakes 0 Mar 7th, 2003 09:29 PM
Wheel & Tire Combo? Thoughts?? rmorin Exterior 0 May 24th, 2002 03:18 PM
