| MINI2 Regular | How do i know if my GTT intercooler snoot boots are leaking boost? I have fitted my new GTT intercooler snoot boots to my GRS intercooler and wounderd how i can be sure i have no leaks.The car seems fine but i want to be sure ive got no loss of boost.The clamps are set over the correct areas although the wider boot does seem a little wide and therefore sits furher on the intercooler than the OE boots.but i guess if the clamps are in the correct place that wont matter. So does anyone know,?cheers guys |
| MINI2 Master Join Date: Apr 2005 Location: Hereford/Cwmbran Local Time: 09:50 PM
Offline | Well I suppose one way to check for minor leaks is to fit a boost gauge, but then you need to know what boost pressure you should be peaking at in the first place. ![]() James |
| MINI2 Senior | Put soapy water all over the seals where you suspect there are leaks. If there is an air leak you'll get bubbles and water spitting from the leak. It's pretty obvious when there are leaks! Most notable is a dodgy idle where the revs 'hunt' when coming to a stop. Cheers, Henry |
| | #6 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 09:50 PM
Offline | Hi , yes dodgy idle or hissing or low boost are all good indicators. Another easy test is with the car at idle, spray brake cleaner or carb cleaner around the edges . Any change in idle as you spray indicates a leak. -Also useful for checking for minor leaks in the intercooler core . -Just spray all over the intercooler . If the clamps are positioned correctly the SB's wont leak even on the GRS intercooler. Best Regards Roland GTT ![]() |
| | #8 (permalink) |
Offline | No it would underboost and run like a pig at idle. SC cars at WOT use all the boost , a turbo car can overboost only if you have a leak on the actuator supply hose . (heaven for tuning possibilitys, sadly ecu cutouts reduced throttle opening limp modes etc on modern cars make it not this simple) Best Regards Roland ![]() |
| | #12 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 09:50 PM
Offline | Well you'd know Loui ![]() Sorry mate, I just couldn't resist! So the engine hunting thing if it happens regular is it normally caused by bioost leaks?! My S has started to develop a hunting on tickover, especially after a hard blast or a high revs blast on the motorway on cruise. Is it likely that the boots (OEM) are leaking or that I have boost issues elsewhere or is it more likely to be something else?! Its not all the time, and a little rise in the throttle and then letting off or a blip seems to make it sort itself out, at least until the next time it stops ![]() |
| | #14 (permalink) |
Offline | Thought that was the most likely explanation for mine, but good to hear it possibly confirmed by someone who knows a bit more about it. The Cooper didn't really do it but the S is far more prone, especially since having the panel filter and the mani and miltek cat back on it. |
| GRS I/C with GTT Snoot Boots | Cooooooperslad | Engine & Drivetrain Tuning | 10 | Aug 14th, 2007 02:59 PM |
| Why you need GTT snoot Boots... | roland2003 | Engine & Drivetrain Tuning | 6 | Jul 30th, 2007 12:56 AM |
| How tight do i do the intercooler snoot boot clamps up? | fozworth | Engine & Drivetrain Tuning | 2 | Dec 26th, 2006 07:42 PM |
| Who sells Alta intercooler boots in the UK | fozworth | Engine & Drivetrain Tuning | 3 | Dec 8th, 2006 12:30 PM |
| New GTT Silicone Intercooler/Snoot Boots + Pics | roland2003 | GT Tuning | 76 | Aug 22nd, 2006 09:35 PM |
