Performance Torque
Old Jan 18th, 2007, 01:38 PM   #1
chrisflyer
Local Time: 09:47 PM
GTT Manifold V JCW Motorsport Manifold
Hi
I have an 05 JCW Cooper S and am considering the option of either the GTT manifold or the JCW motorsport manifold. can you advise me of the best. In particular is the JCW manifold better due to a closer match with the JCW head,s exhaust ports than the GTT.
England   Reply With Quote
Old Jan 18th, 2007, 01:58 PM   #2 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
A guy called Venox22 sodl me his GTT manifold so he could buy the JCW one. Would be worth contacting him and asking his opinion as he has tried both.
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 18th, 2007, 05:08 PM   #3 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
...also GTT260, (Karl) he sold his JCW to fit the GTT Manifold . For port sizes on the heads check out thread + pics I put up a while ago. The size of the ports on the manifolds (as apposed to the heads) are the same on the GTT & JCW. JCW is only mig welded ,GTT manifold uses tig welding.
Best Regards Roland GTT
Old Jan 21st, 2007, 02:34 AM   #4 (permalink)
Ant FR
so is anyone gonna tell us which is the bhest manifold of the lot. Lhen said the Janspeed was better than the Milltek as the janspeed had larger ports than the Milltek.
I am confused as hell.
Also is it recommended to buy a new Manifold Gasket when changing your manifold??
Old Jan 21st, 2007, 08:46 AM   #5 (permalink)
roland2003
Yes the Janspeed is good but the GTT one is better. It is made exclusivley for us by.....Janspeed . Even Janspeed will confirm the GTT is better. It should be was designed to be and costs us more than the stock Janspeed item.
-Yes use new gaskets top & bottom.
Old Jan 21st, 2007, 01:25 PM   #6 (permalink)
Ant FR
Bottom gaskets, Doh!!!! I only got top ones, any chance the oother one is a universal one at all.
So is the Milltek any good then Roland, cos i assumed would be best to stick to Milltek if i had the Milltek exhaust already, due to the fact thats what they would have tested it all with???
Old Jan 21st, 2007, 01:35 PM   #7 (permalink)
Parc77
Parc77's Avatar
I was going to get the GTT manifold a couple of months back, ive got a Milltek cat back, and thought it was blowing....turned out to be a hairline crack in the cat grrr! .....could this have been down to the fact that one of my engine mounts went? and thus put undue stress on the manifold/cat? or is it just bad luck? Ive had the small hairline crack welded and its now fine. Im hoping this wont have any negative effects when my MOT is due in a month or so? I.E emissions. Once ive done my brakes (discs and pads alround) paid for the MOT, the GTT manifold is next on my list
Old Jan 21st, 2007, 03:04 PM   #8 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
Can't talk highly enough about the GTT manifold - since I've fitted it to my MCS it feels like a different car.....................my advice - buy one !
Vroooom Vroooom
Old Jan 21st, 2007, 05:07 PM   #9 (permalink)
RVW
003 On a Mission
RVW's Avatar
GTT all the way Had mine on for approx 6 months, JCW back end and all I can say it`s AWESOME Inside the car is quiet when cruising, BUT when you put the pedal to the metal so to speak ---- it plays music to your ears
United Kingdom Male View RVW's Hot Chocolate & Silver 2nd Gen MINI Cooper Diesel Clubman Profile   Reply With Quote
Old Jan 28th, 2007, 10:26 PM   #10 (permalink)
Fabio
F43i0
Fabio's Avatar
Send a message via MSN to Fabio Send a message via Skype™ to Fabio
any sound clips?? GTT or JCW??
Old Jan 28th, 2007, 10:56 PM   #11 (permalink)
RVW
003 On a Mission
RVW's Avatar
Try this Think you will work out who is who
http://www.m1rvw.co.uk/Millau%20to%2...20Tur ini.WMV
Old Jan 28th, 2007, 11:19 PM   #12 (permalink)
Fabio
F43i0
Fabio's Avatar
thanks
it sounds great, great vid btw, some great roads up there.
Did it bolt striaght onto your cat, you havent had any trouble with your cat???
i'd still like to hear the JCW to compare
Old Jan 29th, 2007, 06:42 AM   #13 (permalink)
RVW
003 On a Mission
RVW's Avatar
thanks
No not had any problems with the cat. As to fitting others may be able to answer that as I had mine fitted at GTT by Roland. But i believe it is a straight forward job.
In the vid the Checkmate S is a JCW Works
Old Jan 29th, 2007, 11:50 AM   #14 (permalink)
PmP
GP 06 MCS 0380
PmP's Avatar
thanks
It will pop and bang more loudly with the JCW than standard GP setup.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 29th, 2007, 12:53 PM   #15 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Reminds me! Need to get a GTT Manifold!
Old Jan 29th, 2007, 05:18 PM   #16 (permalink)
miniboyblue
GTT........See Yah
miniboyblue's Avatar
Local Time: 10:47 PM
GTT GTT GTT I run the GTT manifold with the JCW back box and above 5,000rpm it is music to my ears !!!!
United Kingdom Male View miniboyblue's Hyper Blue & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Jan 29th, 2007, 05:25 PM   #17 (permalink)
Fabio
F43i0
Fabio's Avatar
is the GTT 4-2-1
Old Jan 30th, 2007, 06:38 AM   #18 (permalink)
sam_a156
Flying Finn
sam_a156's Avatar
Send a message via Skype™ to sam_a156
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 25th, 2007, 01:53 AM   #19 (permalink)
MiniBimmer
MiniBimmer's Avatar
Hello
I canīt hear sound clip (http://www.m1rvw.co.uk/Millau%20to%2...20Tur ini.WMV), RVW can you put back online please?
Somebody knows the MINI Madness manifold, is a good choise or GTT is better?
Best Regards
Portugal   Reply With Quote
Old Sep 25th, 2007, 06:54 AM   #20 (permalink)
RVW
003 On a Mission
RVW's Avatar
Quote: Originally Posted by MiniBimmer (original)
Hello
Best Regards
Hmm that does not seem to work
Try here
jcw motorsport exhaust manifold... m111nme Engine & Drivetrain Tuning 41 Sep 17th, 2008 07:09 AM
John Cooper Motorsport Manifold chrisflyer John Cooper Works & GP 3 May 17th, 2008 05:54 PM
MINI Motorsport manifold *Vikki* Engine & Drivetrain Tuning 67 Jul 30th, 2007 11:32 AM
Stock Manifold - JCW Manifold GTT 280 Engine & Drivetrain Tuning 1 Feb 3rd, 2005 09:34 AM
