| MINI2 Regular | Digimoto and MTH? Ok i am in the process off buying digimoto and the interface from OBDII Software, Vehicle Diagnostics Software . I also want to purchase an MTH remap, anyone know whether i can use the digimoto interface to remap the car? Will this interface work at all with my car? Cheers Andy |
| MINI2 Newbie Join Date: Apr 2008 Location: Los Angeles, CA Local Time: 02:53 PM
Offline | Can anyone verify this? I have DigiMoto v5 and the mOByDic cable (from DigiMoto). I can get DigiMoto to work with their mOByDic cable, however I cannot get CarTune to pull my info from the car with this cable. Any thoughts? |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 09:53 PM
Offline | Well from my experience the answer is not likely but nothing ventured, nothing gained. I have found that very few interfaces will actually let you write data to the ECU. ODB data reading and writing isnt the same as reading and writing the EPROM data. Different pins if I remember correct as you need the interface to sit on the network. |
| | #6 (permalink) |
| Lovin' every MINI of it! | I looked at the cable on-line and it looks like a USB - serial cable. More than likely the Cartunes software is set to the wrong port. If I remember correctly you can select a drop down at the top of the cartunes software to change the port. If you are unsure of what port to set it to, you may need to go to your device settings in windows to see what serial port it is assigned to or you can continue to try each one. Global Moderator ![]() |
| mOByDic 2600 / Digimoto v4.03 | GTT 280 | Engine & Drivetrain Tuning | 13 | Dec 4th, 2006 05:35 PM |
| MTH Standard v MTH Tuning | mini.marvel | MINI One | 4 | Sep 22nd, 2006 11:22 AM |
| MTH Help | FunkyJMan | Engine & Drivetrain Tuning | 8 | Oct 24th, 2005 01:53 AM |
