Carccessory.com
Tags: , ,
Old Feb 19th, 2007, 10:28 AM   #1
Mini Demon
Local Time: 09:09 AM
Chip - Mini
Hi,
How can you tell if at all if a mini has been chipped and re mapped?
Old Feb 19th, 2007, 10:29 AM   #2 (permalink)
marx87
R56 MCS Works For Sale!
marx87's Avatar
Local Time: 10:09 AM
Test it on a dyno.
Old Feb 19th, 2007, 10:32 AM   #3 (permalink)
minicabrio
sick note
minicabrio's Avatar
Or check where your rev limiter cuts in... most units such as a bluefin or one-click extend your rev limiter by say 500 rpm.
Check where your rev limiter should be set, and then test to see where yours cuts in.
United Kingdom http://www.mini2.com/forum/Visit my Blog at the Motorcade Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 19th, 2007, 10:40 AM   #4 (permalink)
Paul_T
MCS Chilli
Paul_T's Avatar
Local Time: 07:09 PM
Do we know if BMW can tell when it's in for a service?
Australia Male View Paul_T's Hyper Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 19th, 2007, 10:55 AM   #5 (permalink)
deggles
deggles's Avatar
I'm sure they could if they looked. Not sure if they would actually notice during a routine service though.
2005 MINI ONE CONVERTIBLE | [click for spec]
England Male View deggles's Astro Black & Black 1st Gen MINI One Convertible Profile   Reply With Quote
Old Feb 19th, 2007, 11:18 AM   #6 (permalink)
Mini Demon
My rev limiter's red bit is set to 7 and half
Havent tried to take it round so it cuts out
Is everybodys set at just over 7 half?
Old Feb 19th, 2007, 03:19 PM   #7 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
You can't tell. A dyno might show up something, but the only sure way is to read the ECU contents and compare it against the standard BMW/MINI version.
If you need it set to standard, a BMW/MINI garage can do this for you at a price.
Why do you need to know?
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 20th, 2007, 07:44 AM   #8 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 05:09 AM
1666 is correct, there really is no commercial way to check.
Without a baseline, a dyno won't tell you anything.
Revlimiter is also hit and miss (lights on tach don't change) as it is hard to know "where" it cut in.
You could use Cartunes to download the current map and then open the fiel with notepad. At the bottom of the file (MTH for sure) there might be something telling you what map is running.
The service center can tell if you are running a map, but it is hard to tell and they have to be looking for it.
Global Moderator
Old Feb 21st, 2007, 08:53 AM   #9 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Yes, the MTH map has the 3 ASCII characters MTH at the end of the map file. The standard BMW file has BMW at the end.
Trim/chip to 03 Mini Cooper S Berger Engine & Drivetrain Tuning 1 Dec 27th, 2005 05:24 PM
chip a mini cooper? the prince Engine & Drivetrain Tuning 3 Mar 17th, 2004 07:53 PM
Mini Cooper chip napa2046 Engine & Drivetrain Tuning 2 Jun 21st, 2003 05:33 AM
mini one power chip sean rennie Engine & Drivetrain Tuning 3 Jan 12th, 2003 03:37 PM
cooper chip for Mini 1 red1 Engine & Drivetrain Tuning 8 Nov 19th, 2002 02:27 PM
