Old Feb 27th, 2007, 07:08 PM   #1
george p
Local Time: 09:47 PM
jcw injectors and remap necessary
hi to all,
i was wondering if any of you guys can shed some light on a concern i have
i have a 2004 mini s with the following mods:
Alta 15%pulley
Alta induction kit
ngk iridium spark plugs
ecu by a reputable company and sponsors of mini2.
i recently installed the jcw 380cc injectors. the reason for doing so is that a few engines here in Greece have blown due to lack of fuel up high. in other words they were running lean with the known devastating results. i must admit that after installing the injectors the car feels more alive and pulls away alot smoother than before. i don't know whether this is due to the new injectors or because the old ones were dirty. bear in mind the previous stock injectors had done 60000 km. the car seems to be working fine but i am not sure if the ecu needs to be re-mapped to accommodate for the new injectors. the ecu has been programmed to accommodate for the Alta intake and the extra airflow along with the pulley of course.
will i cause any trouble to the engine having installed the larger injectors or will it be fine?
any advice will be much appreciated
thanks in advance
cheers from Athens
GEORGE
Greece   Reply With Quote
Old Mar 1st, 2007, 06:43 PM   #2 (permalink)
Shorty
Shorty's Avatar
Send a message via Yahoo to Shorty
Quote: Originally Posted by george p (original)
hi to all,
Alta 15%pulley
Alta induction kit
thanks in advance
cheers from Athens
I've been running the Works injectors on my GTT 220S without a remap for almost a year.
Roland at GTT advised me that a remap also wasn't reqd
England View Shorty's Solid Black & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Mar 2nd, 2007, 12:56 PM   #3 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 04:47 PM
Not required, but the performance level would benefit from it.
Global Moderator
United States Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 3rd, 2007, 10:46 AM   #4 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Ive had maps specifically scaled for the 380cc injectors ,and still find the stock injector map (but with the 380cc injectors) preferable for power & smoothness. Measured A/F ratio at WOT is practically identical except above 6-6.5K revs, where the 380's dont start to lean off.
-a good mod
Best Regards Roland GTT
Old Mar 3rd, 2007, 10:52 AM   #5 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
How much are the JCW injectors?
Easy mod to do?
Vroooom Vroooom
Old Mar 4th, 2007, 12:41 PM   #6 (permalink)
george p
the jcw injectors cost me 360 euro and they are east to install. thanks roland and the rest for the replies. the car runs smoother now and there is a slight difference at high revs . overall i feel more confident now and not so worried that the car will run lean at high revs. of course its not wise to thrash it constanlly but once in a while its good.... it keeps exhaust clean as well.... if you know what i mean...
GEORGE
How much? jcw injectors lucachiarelli Engine & Drivetrain Tuning 29 Oct 10th, 2007 02:17 AM
JCW injectors philly c Engine & Drivetrain Tuning 10 May 31st, 2007 07:26 PM
JCW injectors supercharged99 Engine & Drivetrain Tuning 1 Oct 12th, 2005 01:09 PM
Use of JCW 210 Injectors on Tuned MCS (non JCW) Amigo Engine & Drivetrain Tuning 14 Jun 19th, 2005 09:00 PM
