| The Power Cube | When installing the LSD, i have heard people having to machine metal from both the diff and the housing - is this correct????? Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| MINI2 Senior Join Date: Dec 2004 Location: Sittard (NL) Local Time: 03:32 PM
Offline | I've just had one fitted. That's only with the early used Quaifes which were for the Getrag six speed gearbox used in the Ford Focus and (almost) identical to the MINI gearbox. As long as you make sure you have the MINI Quaife it's okay. The Mini Quaife has an 'M' behind it's product number. EB/W R53 MCS Highly Modified |
| The Power Cube | Ah, that explains why they were talking about Ford dealerships and getting different bearing sets and seals then. They were trying to fit a non MINI sized part in the MINI. Many thanks for that. And phew that Quife now do one to fit exactly. BTW - is Quaife the only (and best) manufacturer of ATB/LSD units? Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
Offline | Ik had new bearings too. The numbers in that Quaife thread were not correct for my 2003 MCS. I had to read the numbers from the existing ones to get new ones. Quaife is not the only one, but the best from what I read. You also get lifetime warranty on the Quaife. Phantom grip is another manufacturer and I know Gripper makes them for a Cooper but I'm not sure if they have one for the MCS as well. It turned out that my 90.000 km gearbox was looking very good on the inside apart from one thing. It was leaking oil to the clutch because the seal on the main axle was leaking. I also replaced all oil seals (and installed a Sachs sports Clutch and M7 flywheel). EB/W R53 MCS Highly Modified |
| | #6 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 02:32 PM
Offline | Hi Guys, we always put new bearings in when installing the diff. The Mini diff has addituional clearance, so as stated no grinding of the casings. Quaiffe is a torque biasing diff, whereas gripper is a plate diff . The Quaiffe is less nervous for road use. Best Regards Roland GTT ![]() |
| | #8 (permalink) |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 02:32 PM
Offline | We've got over 120 6000rpm launches with the quaife diff now without a problem, we just recently took it down to quaife for them to inspect it, whenthey took apart they asked if we had actually used it. A testment to their product, also we havn't broken one driveshaft as yet. Clutch wise it depends whether you want an on /off clutch like a paddle or a sprung plate, we went on the mini2 Top Gear run last Saturday with the paddle and it was a pain at times. We're fitting the Exedy moly flywheel and clutch with the next engine upgrade which will see us into non nitrous 12 sec 1/4 miles. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| | #9 (permalink) |
| New Mini Specialists | Hi, Quaife - ONLY make ATB Differentials (which is: Automatic Torque Biasing), it is a completely gear based differential and it has no slip plates within its design. This makes it a better diff for the road as it will never need servicing. However the downside is that it still can let one wheel spin if it is completely offloaded and therefore not ideal for race use. (not sure if quaife are the ONLY, but they are certainly the Best known manufacturer & UK based) LSD - Limited Slip Differentials (a type of diff, not make), use slip (like minature clutches) plates to determine to which wheel the power will go once traction is broken. Even if one wheel is completely lifted, some power will still go to the opposite wheel to provide drive. Hence LSDs are perfect in race use where "riding the curb" (riding the rumble strips on the corners) often results in some grip loss while cornering. As LSDs use slip plates they may (almost definately if you keep the car long enough) need a service. There are a couple of LSD items already available on the market, and we have something very special arriving from Japan in the next week or so (so keep your eys peeled) & will be selling it shortly. You DON'T have to fit a flywheel or clutch when you change the diff, but due to the design of the MINI it is cost beneficial to do all at once (only if you are planning to do at all). What design/make you go for is once again dependant on your needs/costs. Bearings are best replaced when you chage the diff, as it far faster, than getting the standard ones off the old diff. Wise to also put good quality gearbox oil once the whole combo is back on the car. Andrey |
| | #10 (permalink) |
| The Power Cube | Yep. The Quiafe certainly seems to be the preffered choice....and it is one of those car parts that looks awesome just sat on the desk, but then most car parts are superb to look at, just a shame this one gets hidden away in the gearbox Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| | #11 (permalink) |
| MINI2 Regular Join Date: Oct 2007 Location: Glasgow Local Time: 02:32 PM
Offline | Talking about Diffs, can i assume that its best to fit a new fltwheel and clutch. so that would be about £400 parts, then about £650 for the diff so that over £1000 for parts. What about fitting costs? ![]() |
| | #12 (permalink) |
| MINI2 Regular Join Date: Sep 2007 Local Time: 02:32 PM
Offline | it would be wise to do the clutch and flywheel as the engine has to come out to do the atb quaife diff.i think you are looking at a good ten hours labour or so if you cannot do the job yourself.not a cheap mod but money well spent ![]() |
| | #15 (permalink) |
| The Power Cube | a new OEM clutch would not fair well in high torque engines over time and abuse, and would require being replaced incurring further material and labour costs. An OEM clutch/flywheel does not offer performance either. So i guess you pay for what you want ![]() Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| | #17 (permalink) |
Offline | Most money goes into fitting the Quaife, the whole subframe has to be lowered to be able to get the gearbox out and change the differential. I have fitted the Quaife and are very pleased with it. I got mine for 700 euro's unfitted, so 2200 Pounds seems a bit expensive. I also fitted the complete Sachs clutch and a M7 flywheel. EB/W R53 MCS Highly Modified |
| | #18 (permalink) |
Offline | Im sure the standard clutch is fine for a standard JCW mini. its not particularly torquie engine. Benifits from £1000 worth of clutch and flywheel are small to say the least. My only reason to replace these parts would be because it may save future labour costs. The performance benifits come from the diff with additional traction. |
| | #19 (permalink) |
| The Power Cube | The performance benefits are also realised in the lightweight flywheel - it is easier for the engine to rev, the stronger more accurate clutch - you can change gear faster and with more assurance and be confident it will not deteriorate/slip when WOT in 1st, 2nd gear with xxxBHP under the bonnet. The quaife is essential in delivering power out of a corner. You need to also remember the context of the costs, £1000 is not a lot of money for the product you get, and in relation to the money spent throughout the car already it is loose change ![]() I think for the low powered JCW and below, the OEM clutch is fine. If you are a track day addict, the it is a must. Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| Mini LSD versus Quaife | mobergy | 2nd Gen MINI Cooper S | 7 | May 17th, 2007 05:25 PM |
| Quaife LSD install thread | gowest | Engine & Drivetrain Tuning | 86 | Mar 7th, 2007 03:01 AM |
| Quaife LSD & A 6mile Supercharger F/S | Rickys'S | For Sale | 5 | Aug 3rd, 2006 06:24 PM |
| LSD Phantom vs. Quaife cause warranty issues? | MattMan | Engine & Drivetrain Tuning | 2 | Jun 3rd, 2005 03:33 AM |
| JCW and Quaife LSD | ALee | Engine & Drivetrain Tuning | 3 | May 18th, 2005 01:06 PM |
