| MINI2 Regular | smaller pulley? please convince me i just cant get my head around this reduced pulley idea.. here is the thing. eventually i want to upgrade to 200bhp. works kit is very expensive and im very tempted to scew it and go for the lcs1 package. but the thing is this reduced pulley business worrys me.... surely reducing the pulley size will mean the supercharger is always working harder then its meant to, there for risking reliablility ??? and wll you loose out on top end power aswell( not that its important) after all the works kite gets a complete new supercharger so that must say something thanks tom |
| | #8 (permalink) |
| MINI2 Senior Join Date: Dec 2004 Location: Sittard (NL) Local Time: 03:53 AM
Offline | The pre-facelift MCS has a grey coating on the supercharger rotors. The Works supercharger on a pre-facelift has a dark coating on the supercharger. The dark coating gives a higher pressure and can withstand higher temperatures a a result of the higher rpm's and compression. All facelift MCS' have the ' Works' supercharger, the dark coating. Thus only the pulley is smaller. This is only a warranty question and pulling of a pulley can be very difficult. So if you have a facelift MCS there is no problem. I drove around with a pre-facelift compressor and a Works pulley size and just changed to a facelift compressor this weekend. My old compressor looked a 100% after 60k miles, no damage to the coating, but I have seen pre-facelift compressors with a damaged coating (resulting in pressure loss), but these were used at higher rpm's than a works. EB/W R53 MCS Highly Modified |
| | #10 (permalink) |
![]() cave capsicum Join Date: Mar 2006 Location: Crewe Local Time: 02:53 AM
Offline | The reason that the JCW kit has a new supercharger, is so that the BMW/MINI technicians don't have to pull off the s/c pulley and refit a smaller one. It's easier to fit a whole new assembly with the pulley already fitted at the factory - it is heat shrunk in place. Yes the s/c is working harder, but so many people have 15 or 17% pulleys it's really not an issue. Any major problems would be obvious by now. ![]() |
| | #11 (permalink) |
| MINI2 Regular Join Date: Mar 2003 Location: EllicottCityMaryland Local Time: 09:53 PM
Offline | No problems on mine with 17% for 3+ years. "I have no data yet. It is a capital mistake to theorize before one has data. Insensibly one begins to twist facts to suit theories instead of theories to suit facts." - Sir Arthur Conan Doyle |
| | #12 (permalink) |
| MINI2 Regular Join Date: Aug 2006 Local Time: 02:53 AM
Offline | JCW Suppercharger Hi, I have a JCW 2005 Mini Cooper S THE SUPPERCHARGER IS NOT THE SAME AS THE STANDARD The One in the JCW has not only a reduced pulley some were between 14-15% IT HAS ALSO BEEN POLISHED I BELIEVE |
| | #13 (permalink) |
Offline | The JCW pulley is 14,6% You can write capitols if you want but the JCW supercharger is not polished. EB/W R53 MCS Highly Modified |
| | #14 (permalink) |
Offline | JCW supercharger, which has coated rotors, is the same as those fitted to the MCS post July 2004, with the exception of the pulley size. There is a rumour however, that the drive ratio to the water pump might be different, but I've seen no proof either way. ![]() |
| | #15 (permalink) |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 02:53 AM
Offline | The JCW conversion supercharger is exactly the same as the post 04 standard chargers,it is not easier to replace the charger than replace with a smaller pulley,It does however allow a greater price to be charged for the conversion! Many pulley changes have been done on the cooper s and the 15% still remains within the max speed of the charger at full engine rpm without major long term issues,smaller pulleys work fine provided the max rpm is not continually used as in a track car-this will ultimately reduce the life of the charger Luckily the large number of JCW conversions carried out has meant that replacement chargers are fairly cheap and available,like wise for the cylinder heads ,although in time this will not always be the case |
| | #17 (permalink) |
| MINI2fosi Join Date: Nov 2001 Location: MINItorque.com Local Time: 02:53 AM
Offline | Basicly what he said, BUT... Original 163bhp S, has an Eaton 3 Supercharger (No coating to protect the fins). The original JCW conversion to 200bhp replaced the supercharger with an Eaton 4 Supercharger (coated fins) which also had a smaller pulley. The Facelifted 170bhp S got the eaton 5 Supercharger (better supercharger (not sure why) and coating on the fins) New 210bhp JCW Conversions also have the Eaton 5 Supercharger with a smaller pulley. So basicly if you have a facelifted S your laughing ![]() ![]() |
| | #18 (permalink) |
Offline | He might be referring to the 225bhp John Cooper Motorsport conversion for the 210bhp JCW. It also contains a whole new supercharger. No mention of the pulley size, but that IS ported or polished or something of that nature. ![]() |
| | #19 (permalink) |
Offline | Good lad ;-) I was looking at the 16% M7 Pulley, simply due to its bigger protection it has over the Alta for preventing the pulley slipping. However the Alta Pulley version 2.0 desposes of that as it to has the same protection ![]() ![]() |
| 17% smaller pulley | G40lew | Engine & Drivetrain Tuning | 10 | Nov 11th, 2007 01:24 PM |
| smaller supercharger pulley | DEBORAH LEIGH | Engine & Drivetrain Tuning | 1 | Apr 25th, 2006 03:04 PM |
| fitting a smaller pulley | parsey83 | Engine & Drivetrain Tuning | 12 | Feb 1st, 2006 08:13 PM |
| BBR smaller pulley | Mini28 | Engine & Drivetrain Tuning | 3 | Feb 28th, 2005 11:27 AM |
| Smaller Pulley | scottybhoy | Engine & Drivetrain Tuning | 1 | Dec 3rd, 2004 10:59 AM |
